Westinghouse 42" LCD w/1080p Part II, MSRP ONLY - Page 260 - AVS Forum | Home Theater Discussions And Reviews
post #7771 of 7783 Old 07-19-2010, 11:37 AM
seanpmi's Avatar
I am getting occasional audio popping (all input sources) on my LVM-42w2. Other than that, my monitor is flawless. I may have to get an HDMI switcher as I have 3 capable HDMI outputs and can only use one...the other 2 go in via YPbPr inputs.
seanpmi is offline
post #7772 of 7783 Old 07-19-2010, 11:46 AM
dubphotek's Avatar
So after about four years of admirable service the backlight gave out. Powers up but no display of any kind and screen remains power-off-black. It's headed for dispsal.
On the bright side there are some awesome prices on 42" plasmas these days so I picked up a Panny TC-42U2 to replace it and I'm happy.
dubphotek is offline
post #7773 of 7783 Old 07-19-2010, 04:12 PM
bobkunkle's Avatar
You could get hdmi-dvi adapters or hdmi-dvi cables. A benefit of the switcher is pseudo discrete inputs since you have to toggle the tv's inputs.
bobkunkle is offline
post #7774 of 7783 Old 07-20-2010, 10:15 PM
ChrisW6ATV's Avatar
dubphotek-
If you have not already got rid of your Westinghouse, I am interested in it. Please send me a message here. Thanks-
Chris
"It's [expletive] lame to watch Jaws, a film that uses the 2.40 ratio as well as any ever produced, in the wrong format on HBO." -Steven Soderbergh, Oscar-winning director
ChrisW6ATV is offline
post #7775 of 7783 Old 08-03-2010, 12:10 AM
Jakeklem's Avatar
After searching the forum this seemed like the most appropriate place to post. If I am wrong please move this post somewhere better suited.
I have acquired a westy tx-42F970z which has a cracked inner screen. I have heard many times that its not cost effective at all to replace the screen, but I could not even find anywhere to buy one (just curious to see what they go for). One of the tags indicate its a Chi mei V420H1-LH5 Rev. C2.
I was planning on parting it out and did some searching for part numbers on the boards and have come up with very little. The closest parts I can find are used in an insignia, but they don't seem to be the same.
Westy PS: 715T2802-3
Insignia PS: 715T2802-1
The main boards carry the same #(E243951) and the boards look identical at first glance. However, the black connector in the top right of the board is different.
I'm assuming these components are very much the same, but the parts from the westy are newer versions. Can anyone shed some light on this for me? I'd like to get an idea of what I can fetch for the parts (everything but the screen) and maybe learn a thing or two along the way. Any help/info is much appreciated. I can provide pictures of the tv/parts/tags if needed.
Jakeklem is offline
post #7776 of 7783 Old 08-03-2010, 07:08 PM
ChrisW6ATV's Avatar
Jakeklem-
Welcome to AVS Forum.
This discussion topic is actually for one specific Westinghouse model, the LVM-42W2, that was made in 2006-2007. Your questions seem to be about the possible value of the parts in your broken set. I don't think you will get much of a response here about circuit repairs/parts. If you do want to try, though, you should check for a specific topic for the TX-42F970Z model, or start a new topic with the model number in the title (which is very important). This discussion is unusual because it does not have the model number, but when it was started, this was the only 42" Westinghouse model sold, and one of the few 1080p TVs of any brand.
You could also check completed sales on Ebay, searching for "westinghouse" and "lcd" and "power supply", for example. The quick answer, though, is that there is little value in broken flat-panel TV sets or their parts, except maybe for the better brands such as Sony or Samsung.
Chris
post #7777 of 7783 Old 08-03-2010, 08:52 PM
Jakeklem's Avatar
Originally Posted by ChrisW6ATV View Post
Jakeklem-
thanks for clearing that up for me Chris. I will start an appropriate thread.
Jakeklem is offline
post #7778 of 7783 Old 08-09-2010, 07:00 PM
n3znf's Avatar
Hello all,
I've had my westy since 2006. It has the 1.19 firmware. Before I post my question I'll throw out some information that might be useful.
I've had a WD HD TV Live for a while (which has frustrated me to no end, I still cant get my samba shares to work after that last 'upgrade'). I could never get it output 1080p to the westy. I even tried as far as a HDMI Gefen Detective Plus. I've recently upgraded to an Onkyo NR1007 and I am happy to report that the WD HD TV live shows up as 1080p at the display through the Onkyo.
Now for my question. Is there any recommendations as far as what Bluray player will sync up reliably? I'm sure the onkyo will be a big help in the process but the westy seems to get flaky when switching between modes. I tried using my laptop, and the only way itll run is using anydvd, when everything in the chain should be hdcp compliant. I probably have to mess with the onkyo more to get it to work, but this is a lot of headache for wonderful modern technology.
So in short is there any guaranteed good to go bluray players? Also does anyone have a copy of the latest firmware and a pinout for the serial cable? I'd definitely like to get my hands on that.
Martin
n3znf is offline
post #7779 of 7783 Old 08-29-2010, 05:21 PM
rb cline's Avatar
After several years of trouble free service my Westy still has a great picture from DirecTV but some annoying vertical bands have shown up over the last year or so.
Others on this forum have complained about this in the past but I never got a feel for if the condition is correctable or something we have to live with as the set ages.
Any comments.?
RBC
Eustis, Fl
rb cline is offline
post #7780 of 7783 Old 09-06-2010, 12:30 PM
rb cline's Avatar
Well its been a few days sence my original question so I did the following:
Put an HDMI to DVI adapter on the cable into the Westy and connected to DVI 2 input. The vert banding is present with this configuration as well but not nearly as bad as before.
Gonna ride with this for awhile and maybe try the DVI 1 input at some later date.
I guess there aren't many of us Westy LVM 42 owners still alive on this forum given the lack of response and low visiter count.
RBC
Eustis, Fl
rb cline is offline
post #7781 of 7783 Old 09-07-2010, 06:16 PM
rb cline's Avatar
Re to my last post reporting that a change of input from HDMI to DVI helped the vert. banding issue------ forgetaboutit. By the time I got all the parameters adjusted the vert. banding was back and largely unchanged.
So I'm back to my original querry. Is there any known and practical fix?
RBC
Eustis, Fl
rb cline is offline
post #7782 of 7783 Old 11-19-2016, 01:13 PM
RGrizzzz's Avatar
Thread back from the dead! My Westy is still going strong after years of living room use. It's migrated to the basement, as the gym TV, now hooked up to a Tivo mini. The HDMI is annoying me. Every time I turn the set back on, there's a green screen. If I restart the Tivo, all is fine, but it takes 5 minutes. I'm fairly certain a firmware fix is out there for it. Any chance anyone can point me to a download and instructions? Thanks!
RGrizzzz is offline
post #7783 of 7783 Old 01-28-2017, 10:39 PM
jfaudio's Avatar
Responding to your thread revival...
I still use the Westy , it's my only TV.
Got it back in 2005 and right away got the issue where the TV won't turn on after being turned off (not every single time but often). The trick is to unplug and replug from the outlet. Back in 2005 I had called for support (TV bought at Best Buy) and had some people come twice... They were never able to upgrade the firmware ( I think I was on the first release). They didn't know what they were doing and I even had to show them how to get into the maintenance mode (after intructions found in this forum I think).
I have since then lost those intructions but from what I recall, you could not upgrade the firmware yourself using a USB stick for instance, like on more recent appliances.
The only solutions I was given, back then, was to bring the TV down to Westinghouse somewhere in the LA area. I was living in the bay area back then and it wasn't worth the trip, especially not being sure the TV would be fixed...
Ironically, I now live close to LA and I could do the trip but I doubt they would still service it.
I recently got a roku and got some picture issues at 1080. By quickly browsing this forum today, it seems it's a know issue that some detected back in 2006. Not sure if a firmware eventually took care of it, too many posts to read.
I'll probably keep the TV for a couple more years, the time for HDR TV to settle down and become more affordable. Now given the lousy support I got back then, I doubt I'll get another Westinghouse...
jfaudio is offline
Reply LCD Flat Panel Displays
Westinghouse 42 Inch Ld 4255vx Led Hdtv
