Vizio L32HDTV10A vs. Westinghouse LTV-32w6 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-01-2006, 10:06 PM - Thread Starter
riiaku's Avatar
I need to know which one is a better pic, I've narrowed it down to these two, I am going to be using it primarily for PC gaming, web surfing, office, DVD's using the computer, and Cable TV from Comcast but with no box just the cable from the wall, its being used in my bedroom, i have a hi fi 5.1 sound system to go with it and a denon 2805 receiver so sound is no problem, just want the best picture quality with no ghosting. which one is better?
riiaku is offline
post #2 of 5 Old 07-02-2006, 09:14 AM
E-Coli's Avatar
Then you better go with the Westy if you plan on using it as a PC monitor for gaming.I haven't seen the Westy as a PC monitor but I had the Vizio10a and you don't want to go there.You'll find tons of post's from people claiming its great,its not!It doesn't have 1:1 pixel mapping/tracking end of story!Why add a phaze & clock control if it does nothing?I went with the Polaroid even tho its a 16ms panel and I use it only for PC gaming/Console gaming.
Cheers!
E-Coli is offline
post #3 of 5 Old 07-02-2006, 02:15 PM - Thread Starter
riiaku's Avatar
Cheers!
Which one did you get of the polaroid 3232 or the 323B? whats the difference?
riiaku is offline
post #4 of 5 Old 07-03-2006, 09:46 PM
E-Coli's Avatar
323B which is walmarts model number and 3232 is everyone else's.No difference other than the fact that you can't price match :rolleyes:
E-Coli is offline
post #5 of 5 Old 07-04-2006, 02:50 AM - Thread Starter
riiaku's Avatar
what about the Niko OTP-3211W vs, the polaroid. how would that compare? cause on tigerdirect it seems to have a very good reviews
riiaku is offline
Closed Thread LCD Flat Panel Displays
