LCD/Plasma issues with mounting over fireplace?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-02-2006, 03:36 PM - Thread Starter
Mikeoz's Avatar
I'm wondering if anyone has had any issues with the heat generated from fireplaces with you lcd/plasmas mounted over the fireplace..?
Is this really a concern w/ the heat generated over fireplaces? I'm looking to mount an lcd/plasma over a fireplace but want to see if this is really going to be an issue.. Seeing as how many people have this done, it shouldn't be, but I just wanted to make sure. Are there any simple things that can be done to help prevent any problems w/ the heat from the fireplace?
Any input is appreciated. Thanks.
Mikeoz is offline
post #2 of 6 Old 07-02-2006, 04:08 PM - Thread Starter
Mikeoz's Avatar
I did a quick search and didn't find any huge discussion, but people generally saying that it was ok..
Has anyone actually had a plasma/lcd failure due to the heat above a fireplace? Is there really a lot of heat directly above the mantle?
I forgot to mention.. the fireplace is a gas burning fireplace, so hopefully the soot/smoke should be a non-issue. Thanks.
Mikeoz is offline
post #3 of 6 Old 07-02-2006, 06:15 PM
Kevin. W's Avatar
Quoted: 118 Post(s)
Liked: 38
So I would assume that your fireplace has a fan that blows the heat away from the fireplace. I would suggest you by a thermometer and hang it in the spot where the plasma will be and turn on the fireplace and see what temp it reads. Heat rises, and the plasma probably uses fans too remove heat from the set, since the fans would be drawing air in through the frame off the set and out the top, they would be drawing the hot air coming off the fireplace. You probably get where I'm coming from.
Kevin. W is offline
post #4 of 6 Old 07-02-2006, 06:21 PM
adb
adb's Avatar
Most seem to think that if you have a mantle you're OK. I wouldn' think a gas burning fireplace would put out extreme heat.
adb is offline
post #5 of 6 Old 07-02-2006, 07:09 PM
assJack1's Avatar
Quoted: 54 Post(s)
I dont have a fireplace setup but was curious, so I googled and found this
Will the heat from the fireplace harm the plasma TV?
There are a few precautions to take before implementing this TV application. First, take a thermometer and tape it to the wall above the mantel (where the plasma TV will be placed). Then and build a fire, let it roar while. Check the thermometer. If the temperature is above 90 degrees then the area is receiving too much heat - either escaping from the front of the fireplace and rising up the face, or radiating through the chimney to warm the outside wall. In this situation it would not be advisable to run the plasma for a long period of time while its environment is hot. Though the Plasma TV has its own cooling system, the surrounding heat will force the Plasma TV to work harder to cool itself, thus shortening the life of the unit over time. The Plasma TV may still be run for short periods without harming the unit even with the environment heat at 90 degrees or above.
assJack1 is offline
post #6 of 6 Old 07-02-2006, 07:23 PM - Thread Starter
Mikeoz's Avatar
Thanks for the input everyone.. I would start a fire, but it's already 90+ here, and I think that might be a little crazy. :-P I'm thinking that I will be going w/ an lcd, and hopefully that should handle the heat a little better than a plasma. I guess it's a toss up regarding how much of an effect a fireplace will have w/ a plasma/lcd.. Thanks.
Mikeoz is offline
Closed Thread LCD Flat Panel Displays
