LCD buying help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-05-2006, 02:58 PM - Thread Starter
dsj
dsj's Avatar
I'm looking to buy a 17 inch LCD monitor and I don't know how to tell the more technical differences between them. All says 8ms, 1024*768 etc... so I'm finding it difficult to distinguish. Thanks.
dsj is offline
post #2 of 5 Old 07-05-2006, 03:30 PM
comptr's Avatar
Quoted: 161 Post(s)
Liked: 24
the 1024 by 768 is the resolution the display will output at.
comptr is offline
post #3 of 5 Old 07-05-2006, 03:45 PM
Stephanie M's Avatar
the 8ms is millisecond response time. Basically the time it takes the set to respond to the signal to display it, the lower this number the smoother the motion. 8MS is really good actually.
TV Authority, supporting the forum for the good of all AVS'er's!
Steph Infection: The leading cause of buyeritis for 24 years, get infected today!
Stephanie M is offline
post #4 of 5 Old 07-05-2006, 03:46 PM - Thread Starter
dsj
dsj's Avatar
Sorry that was a typo, it's supposed to be 1280*1024. I meant most of the specs for the different brands were the same so I can't tell exactly which one is better.
dsj is offline
post #5 of 5 Old 07-05-2006, 07:49 PM - Thread Starter
dsj
dsj's Avatar
By the way, which manufacture has the best dead pixel policy?
dsj is offline
Closed Thread LCD Flat Panel Displays
