Sony 40" KDL-40V2500 and 46" KDL-46V2500 HDTV Thread - Page 178 - AVS Forum | Home Theater Discussions And Reviews
post #5311 of 5322 Old 01-05-2011, 05:43 PM
MKtaulanga's Avatar
Originally Posted by JN99 View Post
I've tried a search but had no luck (I'm sure it's here somewhere) and there is also nothing in the manual, nice... I've tried Sony support too, and that was laughable. Can anyone tell me whcih if the multitude of holes on the back of a 40v2500 are for wall mounting brackets?
There are no less than 7 on each side that look like they could possibly be used. Three of these are unused so I am assuming it's likely going to be these that are supposed to be used, but which ones? How does one tell?
Also, I notice one of the scews tht is used, for what I don't know, sticks out past the case of the TV and interferes with the bracket regardless of which holes are used to mount the bracket. I don't know if these can be removed or not but from what I can tell they have to be or the bracket won't sit flush to the tv.
Thx
All the holes are for different brackets that are made. If the bracket doesn't sit flush against the back then you have to use the provided spacers. The spacers make the bracket sit tight but about a 1/4 in off the tv itself. You just have to look through the manual for the bracket and see what hardware to use for your tv. You WILL have a TON of extra hardware and it's only because every tv is different and they try to make the brackets universal. Hopefully that helps.
MKtaulanga is offline
post #5312 of 5322 Old 01-11-2013, 03:47 PM
jatwap's Avatar
How do I set up my Sky box (which I've got connected via HMDI (AV4) to automatically come on when the Sky box is powered up. Currently, I need to cycle through the AV channels to get to AV4 for it to display but I'd like it so that when I power the Sky box on it automatically 'tunes' to AV4 - is this possible?
jatwap is offline
post #5313 of 5322 Old 10-15-2013, 07:44 PM
Grubs92's Avatar
Quoted: 43 Post(s)
I still have this tv and it is still the best tv in my home. Despite being the oldest, the picture is just awesome
Grubs92 is offline
post #5314 of 5322 Old 10-16-2013, 04:05 PM
loggerhead's Avatar
I agree with you. My TV continues to perform excellently.
loggerhead is offline
post #5315 of 5322 Old 01-06-2015, 08:37 PM
shawnmos's Avatar
Anyone know what would cause darkness on the right side of the panel (mainly the lower right)? I thought it was a backlight issue but I think the backlights are usually arranged horizontally and not vertically, correct?
shawnmos is offline
post #5316 of 5322 Old 05-16-2015, 08:59 AM
Liked: 0
Hi was given freely old tv, that is kdl-46v2500. Has anyone figured out how make it display 1080p? It does display 1080i nicely.
I have it connected to pc with amd r290. It allows to sellect 25i,29i,30i all of those work fine, but 50,59 and 60 nothing is displayed not even wrong format :I At 1080i there sould be selection of display area options:full pixel but currently there is only normal,-1,-2.
Alar99 is offline
post #5317 of 5322 Old 05-23-2015, 08:58 PM
jlib's Avatar
Quoted: 20 Post(s)
I have it connected to pc with amd r290. It allows to select 25i,29i,30i all of those work fine, but 50,59 and 60 nothing is displayed not even wrong format :I At 1080i there should be selection of display area options:full pixel but currently there is only normal,-1,-2.
1080p is its native resolution. It can receive various resolution inputs but all would be converted to 1080p, the only resolution it can display. If you have a true 1080p source it is a good idea to set the screen setting to Full Pixel (no scaling, buffering, or overscan emulation, so only available with a 1080p input). That card should have no problem with that resolution unless there is some HDCP handshake problem or something. Are you using HDMI for the connection?
jlib is offline
post #5318 of 5322 Old 05-26-2015, 03:19 PM
kininn's Avatar
Is it possible to turn off the tv screen while listening to stereo using Sony amp via Netflix and Apple TV?
Hate to use all the nrg! if I can
-maybe save the TV, too.
kininn is offline
post #5319 of 5322 Old 05-27-2015, 12:34 AM
jlib's Avatar
Quoted: 20 Post(s)
Sorry, I'm not familiar with Sony amps, Netflix or Apple TV.
jlib is offline
post #5320 of 5322 Old 12-21-2015, 02:02 AM
Liked: 0
I've had superb performance from this TV that I've used virtually every day since mid-2007. It's awesome. Did you calibrate yours? I'm interested in best settings. Thanks
singit
singit is offline
post #5321 of 5322 Old 12-22-2015, 01:45 PM
jlib's Avatar
Quoted: 20 Post(s)
I dread the day I have to replace it with a modern reflective screen display. By the way, there was a Sony V2500 Calibration and Reference Information thread a few years ago. It is not active but there is probably some valuable archived information there.
jlib is offline
post #5322 of 5322 Old 10-02-2016, 06:39 PM
acrackl's Avatar
Hi, This is the only TV I have in my home (KDL 46V25L - Sam's Club Version) - purchased mid 2007. Is it time for me to upgrade? I have been ignoring the 4K hoopla - waiting for it to hit mainstream ....
acrackl is offline
Reply LCD Flat Panel Displays
