looking for best lcd for the money - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-01-2006, 07:05 AM - Thread Starter
rxtasy's Avatar
Haven't posted since I was researching for my 37inch philips LCD. It has been a great hdtv thus far (knock on wood) and I wanted to thank the board for all the help in selecting it.
Looking to get a hdtv for my folks. Here are the stats required:
budget: apprx 2K
size: opening in their entertainment center is 44inches
LCD preferred
any suggestions? thx
rxtasy is offline
post #2 of 6 Old 08-01-2006, 07:29 AM
andy sullivan's Avatar
Quoted: 773 Post(s)
Liked: 406
Since you say, "probably LCD", I would suggest looking at the following. Westinghouse, Vizio 42" and throw in the Vizio 42" plasma. Even the Vizio 50" plasma will fall into your budget.
andy sullivan is offline
post #3 of 6 Old 08-01-2006, 09:12 AM
HT_Aaron's Avatar
Samsung LN-S4041. Its a 40" but it will fit the entertainment center and budget.
HT_Aaron is offline
post #4 of 6 Old 08-01-2006, 10:18 AM
Bob Dycus's Avatar
The 37" LG LCD will fit.
Bob Dycus is offline
post #5 of 6 Old 08-01-2006, 12:58 PM
[Square]'s Avatar
There are a number of ways you could go. I'd take a look at the Sharp LC37D40U. I've always liked the 37" model and we'll probably get one here in a few months. You could really look at any of the top 5 brands and stay around the 37" (maybe 40") LCDs and not go wrong. Happy Hunting.
[Square] is offline
post #6 of 6 Old 08-01-2006, 01:01 PM
JackLT's Avatar
Westinghouse 1080p 42" should fit your needs and offer full 1920x1080 over 4 inputs!
Test Your Display,
Tips for Large Monitor Use
: 720p, 1080p Test Patterns, Tips Just Click Here
JackLT is offline
Closed Thread LCD Flat Panel Displays
