After using SwitchResX, Samsung LCD not working with my Mac Mini - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-01-2006, 07:17 AM - Thread Starter
stephanlongo's Avatar
Hello everyone,
I'm new here. Hope someone can help with my question.
I have a Mac Mini core duo intel, with a Samsung LCD TV (LN-S3252D)...everything was working great. That is until I downloaded SwitchResX. Now my Samsung is not recognized....the Mac shows at start-up, then the screen says "mode not supported". I'm using an DVI to HDMI cable.
Can anyone help with this. I would sincerely appreciate it. I'm using my old monitor to write this.
Stephan
stephanlongo is offline
post #2 of 3 Old 08-01-2006, 07:43 AM
Kupakai's Avatar
Probably, the setting you tried doesn't work with the TV. Try either safe boot or resetting the PRAM, and the try another resolution and timing settings if you want to try again.
Safe mode
http://docs.info.apple.com/article.html?artnum=107393
reset PRAM
http://docs.info.apple.com/article.html?artnum=2238
Since it sounds like you have access to another monitor that does work, you can also try the second part of this:
http://docs.info.apple.com/article.html?artnum=301345
Kupakai is offline
post #3 of 3 Old 08-01-2006, 08:55 AM - Thread Starter
Thank you for the solutions. I will try first thing when I get home from work.
Stephan
Closed Thread LCD Flat Panel Displays
