What to clean Westy LCD with? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-02-2006, 10:07 PM - Thread Starter
bigphill911's Avatar
Hey guys I have a westinghouse ltv 32w6 and I was wondering what I need to use to clean the screen off with? Let me know because I don't want to damage the screen in any way. Thanks and I appreciate all of the help!
Blu-ray... Beyond High Definition
bigphill911 is offline
post #2 of 5 Old 08-02-2006, 10:17 PM
bitemymac's Avatar
dampen/moist towel or paper towel does the trick. Just don't use any alchol or amonia base reagent. It can eat off panel coating.
bitemymac is offline
post #3 of 5 Old 08-03-2006, 04:04 AM
optivity's Avatar
I use this product to clean my PDP TV & LCD monitor screen(s): Monster Cable TV Screen Cleaning Kit
optivity is offline
post #4 of 5 Old 08-03-2006, 12:14 PM
wtr_wkr's Avatar
Do not use wood (tissue, paper,...) Use the cloth for glasses, lenes,...
HD-DVD is dead, so now I'm a Gary McCoy fanboy.
wtr_wkr is offline
post #5 of 5 Old 08-03-2006, 01:06 PM
madflava76's Avatar
I would use a damp microfibre cloth. Don't use paper towels, anything paper based can scratch. You can find good microfibure cloth's at any car store since they are the cloth of choice for applying and removing wax from car clear coat without scratching
madflava76 is offline
Closed Thread LCD Flat Panel Displays
