Official Sony 40",46" XBR2, XBR3 - Owner's Thread - Page 16 - AVS Forum | Home Theater Discussions And Reviews
Old 09-02-2006, 10:02 PM
rdilliker's Avatar
Originally Posted by amitt View Post
dude xbr2 and xbr3 are same tv in every respect with minor diffs
different remote
obviously diff color
and warranty on xbr3 is 6 months more.
so if you dont like xbr2, no way to like xbr3 ok
Nope, warranty is 12 months on the XBR3 as well. I called Sony customer service and the lady there said it was 12 months in her system too. She didn't seem to care that the Sony website said otherwise so I made her write in her system that the website is incorrect and needs to be fixed.
rdilliker is offline
Old 09-03-2006, 04:46 AM
luna5's Avatar
[quote=amitt]
Originally Posted by luna5 View Post
ive read people who leave the NR on on their xbr2/3 have blurred images sometimes. WIll using one of these systems allow u to leave NR off and have better image quality?
Only if your power line is picking up some kind of interference that is actually affecting the picture without a filter. I wouldn't count on any kind of power filter producing a better picture using a good source of power which I would guess that 99.9% of us have. I needed a good surge supressor anyway and at the price I paid for the APC I consider the filtering and AVR to be a bonus but certainly not necessary.
"I'm supposed to drive a flying car"
"I'm supposed to have a house on Mars"
"I'm supposed to live 200 years"
"Future"
Todd Rundgren "Liars" CD/DVDA
luna5 is offline
Old 09-03-2006, 04:53 AM
luna5's Avatar
Originally Posted by Total_Mule View Post
I have been through several settings on each cable box setting the output to 1080i, 480i or 1080i only, or 480i, 720p, 1080i. All yielding the same problems. I have tried the Utra 800 HDMI cable and traded it for the HMDI X cable from tweeter. No luck. I dig the tv, just worried. I've experienced the black fickering problem 3 times now. Like you, I turned it off and started back and it was a while before I saw it again. This past time it happened I let it run. With no resolve I rebooted everything. This time in the different order. I then discovered that when I booted the TV before the cable box I recieved a dialog that stated the TV is not compatibile with HDCP and needed to be hooked up through the component inputs. BAhh..where would I hook up my WII or my 360 .
Thanks for all your input.
Have you had the cable company send a tech and check out the problem? I had a cable box problem and when they brought a replacement the tech set it up and checked out the picture on the TV, he was very HD knowledgable which surprised me. They should know if the ports on the box are active and be able to help you get connected up properly with the equipment they supply. At least you'll know at that point if the cable company's equipment is working correctly before you return the set. I get occasional "dropouts" on my cable co's HD and "premium" channels and where the picture blanks out for a split second but I know it's the cable co's problem because I have the optical audio out from my STB (SA3250HD) directly connected to the optical in on my DD surround receiver and the sound drops out at the same time.
"Future"
luna5 is offline
Old 09-03-2006, 07:59 AM
ddusseld's Avatar
Could you pleas report back to the list what you hear from Sony?
I have a similar issue. Every once and a while the TV flickers. It is not terribly annoying but if there is an easy firmware fix that would be cool.
Originally Posted by Gad Zookz View Post
We will have to see if Sony Central Command is aware of any XBR2 firmware issues when they call be back on Sunday.
ddusseld is offline
Old 09-03-2006, 09:21 AM
kdk
kdk's Avatar
Couple questions from a newbie:
I requested an HDMI capable HD DVR box for my XBR2. Got Motorola 6412 from Time Warner. Its too deep for my stand!!! I noticed most of you have Scientific Atlantla 8300HD, could somebody please measure depth??? Plus I was wondering if its a better box since all you experts have them.
I have a sony VAIO AR170G laptop which has a HDMI port, tried to connect HDMI to HDMI got an error message "cannot support signal"
Plus, is the RGB supplied VGA or SVGA? Is there a difference? Plus, can the adio part of the RGB PC input accept optical audio?
I am getting wall mount from Magnolia, currently have HDMI connected to cable box, the second one will be for upconverting DVD, but I want to connect PS3 by HMDI later, without using side port for aesthetic reasons. Will I even need the upconverting player later after I get the PS3? (Wish they had more HDMI back ports)
kdk is offline
Old 09-03-2006, 09:25 AM
MrWeinz's Avatar
Originally Posted by necrolop View Post
Anyone notice that when you first turn the TV on the remote seems not to work, takes about 20 seconds untill the TV will take commands.
Well, the first 5-10 seconds is the TV warming up before displaying an image, but as soon as the image is displayed, I have control.
MrWeinz is offline
Old 09-03-2006, 10:12 AM
luna5's Avatar
[quote=kdk]Couple questions from a newbie:
Don't know about the other posters here but my cable company ( Charter) doesn't give us a choice of what cable box to use...they have only 1 model of HD cable box ( SA3250HD) and 1 model of DVR type box (also an SA I believe). If that's the case with your CC you won't be able to change it anyway.
"Future"
luna5 is offline
Old 09-03-2006, 10:18 AM
rdilliker's Avatar
VGA, SVGA, etc. has nothing to do with the connection interface, it is a function of your display.
Old 09-03-2006, 10:22 AM
mikenogo's Avatar
Holy crap, aren't these like the best quality picture or what!?!?!??!!?!?! :|
when i look at it more, it looks like those characters are going to pop out of my screen X_x
mikenogo is offline
Old 09-03-2006, 10:32 AM
rdilliker's Avatar
Care to tell us the source, i.e. make and model of DVD player?
Old 09-03-2006, 11:23 AM
shive's Avatar
I remember seeing these a while back ago when the XBR set had been released in Europe (to coincide with the World Cup). I believe these are the same pics from that original post (don't recall exactly which website, but not here). As for myself, I'm psyched to be getting my 46xbr2 (should be here on Tuesday). Is there anyone out there that has gotten one of these professionally calibrated?
shive is offline
Old 09-03-2006, 01:23 PM
Gad Zookz's Avatar
Will do.
It has not happened again for almost 2 days now so I am quite baffled. How often is it happening to you?
Never Fully Here
Gad Zookz is offline
Old 09-03-2006, 04:29 PM
3Gun's Avatar
I just got back from my local Magnolia AV retailer, where I was ogling the KDL-46XBR3 on display, comparing it to the A2000 SXRDs and the LED-DLP Sammy there. Just thought I'd mention that my sales guy showed me the KDL-52XBR2 in his system, marked as due in November, priced (now) at $6500 which I assume is MSRP.
Loved the 46XBR3, btw. Handled SD very well with some tweaking IMHO.
...this is going to be a tough call for me to make - a 52" XBR3, or 60" SXRD XBR2...jeeze! Nice to at least have a choice, but the waiting is killin' me, I tell ya...
-3Gun
3Gun is offline
Old 09-03-2006, 05:36 PM
ddusseld's Avatar
It happens every hour or so. The odd time it happens a couple of times an hour. I'm trying to determine if it is source dependant. I just watched a DVD and had no issues. Back to cable and I got a "flicker". I'll watch another DVD and see. I'm also going to try using a power/av filter/cleaner. See if this does anything.
Will do.
ddusseld is offline
Old 09-03-2006, 08:20 PM
Gad Zookz's Avatar
I was thinking of trying one of the line conditioners but do not know much about them except that they can get pricey. All I have ever used to date are good quality surge protectors.
I understand that some folks use UPS units as well but you have to get the right type or the back up power does not kick in fast enough.
Never Fully Here
Old 09-04-2006, 03:48 PM
boltjames's Avatar
I'm getting my 46" XBR2 next week (thanks to all in here for your excellent info) and now I turn to the DVD....
Are the built-in scaling and interpolating functions good enough to take a good progressive scan DVD player and make it look fantastic or does one need to invest in the likes of an OPPO upconverting DVD player? If there is a difference in PQ, just how dramatic is it on this Sony vs. a non-1080p panel?
TIA
boltjames is offline
Old 09-04-2006, 03:51 PM
ddusseld's Avatar
I think I discovered what my problem was. I'm using a SA8300HD PVR as my cable box. I had it set to auto-hdmi with the only available screen mode being 1080i. I switched it to allow 480i,720p and 1080i and the flicker has not re-occurred today.
Will do.
ddusseld is offline
Old 09-04-2006, 10:40 PM
PAYSHUNCE's Avatar
I ordered this set after reading these forums (Mugen's original thread). Once ordered I read through the accolades and criticisms. It finally arrived last Friday and I am very happy with this LCD. As many others have pointed out, this set like all sets are totally dependent on source. The way this set displays 1080i is unbelievable, the image is fantastic...and even the sound is excellent. SD is acceptable, not bad at all, but as with my previous set...not HD. I've watched SD, HD, DVD's (via an old Sony DVP-S7700 new Oppo 971HD arrives Tuesday, Sony Blu-ray arrives in November).
What I like:
HD awesome...best I have seen.
Colors are accurate, brilliant and sharp, something very hard to find on a plasma.
SD...okay, not great, not HD, but easily watcheable(I followed the settings used by a couple of posters (a little tweaking to this) and found the custom environment recommended made a difference when it came to SD http://www.avsforum.com/avs-vb/showt...&&#post8291186)
Design and build quality....excellent.
Remote...easy...straight forward
Interface...well laid out, easy to use, fast
Black's awesomecheck out the moon shot below...can you tell where the bezel begins?
What I don't like:
My set also takes a while before the remote will work....20-30 seconds this is no big deal, but it also takes about six minutes to allow me to remove the source display on the screen and lower or raise the volume on the set. Has anyone else had this problem?
I could have waited for HDMI 1.3, SED or whatever is around the bend but then why not wait for the next best thing after that too? I waited 3 years to buy a flat panel display. I waited until I could find a set which would display an image that fit my taste and this has.
Below are a couple of pic's for your review.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Circles on moon...they were not there until I put this photo on a server for posting.
PAYSHUNCE is offline
Old 09-05-2006, 07:02 AM
Vordak's Avatar
Well, I finally jumped into the HD world and bought the 46" XBR2. I wanted to wait for the XBR3, but too eager and don't need to spend more money just for the black bezel.
I was wondering, I bought this at Best Buy and didn't get the warranty. I heard others saying you could get the TV then buy the warranty from SonyStyle.com, has anyone else done this?
Vordak is offline
Old 09-05-2006, 07:38 AM
aroide's Avatar
I just bought an XBR2 46" from Best Buy. I'm going to purchase a RepairTech extended warranty. Much cheaper and longer period of time as compared to the one Best Buy offered. After researching, they appear to be reputable, use local service companies, and have good customer feedback.
You can purchase from lcdtvs.com and probably many others. You can also find them on Ebay.
Repairtech web site is http://www.repairtechinc.com.
aroide is offline
Old 09-05-2006, 07:40 AM
Vordak's Avatar
I will check them out, thanks!
Vordak is offline
Old 09-05-2006, 10:03 AM
visualguy's Avatar
The set can display decent blacks, but at the cost of a loss of detail in dark areas. It's possible to change the settings to get the detail back (see the settings of CarlosC), but then the blacks don't look so good. Plasma is still better at this.
visualguy is offline
Old 09-05-2006, 11:28 AM
Nascar Dog's Avatar
Quoted: 55 Post(s)
Liked: 60
Does anyone know if there is a section/option in the service menu of the XBR2 that shows the hours the TV has been used. The KDL-46S000 had this feauture in the service menu but I cannot find it in the XBR2 service menu. The 46S200 also has a GUI style service menu where as the XBR2 has a crude text based service menu.
The service menu I am accessing in the XBR2 is obtained by entering the following on the remote:
[PWR OFF] - [DISP], [5], [VOL+], [PWR ON]
Is there another service menu on the XBR2?
Nascar Dog is offline
Old 09-05-2006, 11:31 AM
trent3's Avatar
Picking up new Sony XBR3 on Friday and had some real basic questions on set up ... apologize ahead of time if answers are obvious, but could really use the help of those of you more informed on this type of stuff....
1. Do I need to order a new Comcast Hidef cable box? I have an older Motorola Hidef, but I think it only has a DVI versus HDMI connection. Is there one specifically I should ask for? When I called Comcast, did not get a very intelligent answer! Is there a real advantage to HDMI hookup versus component?
2. I have an NAD T973 and 163 pre and amp withno HDMI, Oppo 971 DVD Player, XBox 360.
Do not understand advantages of HDMI versus component all that well and whether to run through NAD or direct to TV.... Any suggestions on best way to hookup and/or HDMI cables to purchase appreciated.
3. Do I really need a "Line Conditioner"? Looks like ones recommended will set me back around $200.....currently have a basic surge protector.
trent3 is offline
Old 09-05-2006, 12:18 PM
GRXBOX360's Avatar
Preliminary Review
I too just got my 46XBR2 last Thursday. I spent a good chunk of the holiday weekend playing with it. Here are some of my early thoughts:
1) Black level = overall excellent. When I have any lights on in the room, the blacks look completely black. The more light the blacker, but this is true of any TV, including my old Sony XBR Wega 32" CRT (the "holy grail" of televisions). I have watched several DVDs in the complete darkness and at first I was quite dissapointed because the blacks looked bright/grayish with my initial settings, but after a lot of adjusting yesterday, I now have pretty much totally black blacks lights on or off. The biggest correction I made was to turn brightness down to about 42. While this results in the loss of some shadow detail, the blacks look a lot better. Just found out yesterday that my Toshiba HD-A1 has a black level enhancer built in but haven't played with it yet.
2) I too got lucky and have an August build panel with zero dead/stuck pixels. I ran Dead Pixel Buddy and Pixel Test from my laptop and have also checked whenever a solid colored screen comes up. I was worried because the dopes that delivered the TV banged the stand on my apartment door when they were bringing it in. It took about a 1/8th inch chip of paint/plastic off of the front of the stand but the TV seems to be none the worse for wear. The chip is one of those things that I can't really see from more than a foot away but it bothers me because I know it's there. I'm debating whether to ask Tweeter to order me a new stand - think I might.
3) I have not seen any of the problems reported about this panel as of yet (ie. macroblocking, pixelation, etc.). Keep in mind though that 99% of my viewing so far has been DVDs from my Toshiba HD-A1. However, I do notice on some sources that there is a moderate amount of what I think is called mosquito noise. Not noticeable in dark areas but worse in bright colored areas. Surprisingly, I noticed the worst amount of it last night when watching Full Metal Jacket HD DVD. Have watched other DVDs with little to no noise. I'm guessing it's the source/quality of DVD transfer. Turning on Noise Reduction to medium or high significantly improves it but causes some slight loss of detail. Right now I have NR set at low. I don't notice any detail loss with NR set at low.
4) When the TV is on but with no active source and a black screen (ie. while a DVD is booting up, etc.), I can detect the slighest amount of what looks for lack of a better description like "clouding" in the lower left 1/4 of the screen. It looks like cloud shaped "patches" of ever so slightly brighter screen, and I do mean slight. I really have to strain my eyes to notice it. The rest of the scren looks pretty uniform. I don't know if this is some light leakage or something to do with the liquid crystal substrate or whatever. Bottom line is I'm doing as critical review of this set as I know how and evaluating everything I find. Whatever this "clouding" is, it doesn't affect the active picture at all so it's a non issue for now. I didn't buy this set to watch blank screens.
5) I've watched most of the extended version of the Lord of the Rings and the upscaled picture from the HD-A1 is phenominal. Looks completely high def and better than Full Metal Jacket HD DVD which I think is a poor transfer or something because it didn't look that hot. Chronicles of Riddick HD DVD is also incredible. Braveheart also looks hi def now but I noticed a lot of black specs flashing, especially in brighter scenes. I'm sure it's the quality of the DVD and not the TV because I haven't seen this on any other source. It's just like the black specs you see in a movie theater which I think are caused by dust on the film. I'm sure they've always been on the DVD but were never noticeable until played on a true hi-def TV. Final Fantasy Spirits within looks hi-def.
6) The colors on this set are excellent. Skin tones, etc. are all very natural looking. It took a lot of adjusting to get the settings I like. Don't be shy to adjust everything as if you get too far afield you can just reset.
7) Regarding cable, I currently have Comcast basic (non digital) and it is barely watchable. I haven't tweaked anything for the cable settings yet because this week I'm getting Comcast digital with HD hooked up so I will reserve any further cable review until then. I hooked up the non-digital basic box to the TV just out of curiosity and it's bad. I'm assuming the step up to digital with HD will make a significant improvement, although I know SD cable will never look pristine.
8) My viewing distance is around 7.5 - 8 feet. I'm glad I went with the 46". I had contemplated waiting and getting the 52" but 46" is plenty big enough for me. It's very true when you hear people say that the TV looks bigger in your home than in the store.
9) I have seen no ghosting or motion blur even in the fastest most intense parts of LOTR, Chronicles of Riddick, etc. Haven't watched any sports yet though.
10) One final note, I think these new XBRs are selling like hot cakes. Best Buy was sold out of them when I tried to order and I've been in Tweeter twice since I bought the set and on both trips there were other people buying both the 40 and 46. I think Sony has a winner on its hands. While I'm still within my 30 days, I'm going to continue going over the set as critically as possible and then just sit back and enjoy. Can't wait for PS3. My heart sank when the day after I got the TV delivered Sharp announced the new 62U with 2000:1 contrast, 4ms response time, etc. But to tell the truth, after watching this TV all weekend, I can't imagine that the new Sharp will be better and will be a great set if it's even as good as the Sony. As far as style, when I first saw pictures of this set everal months ago, I hated the floating glass and thought the set looked way too artsy/contemporary. However, the look has really grown on me and now I really love the style. It's very classy looking and I love the illuminated Sony logo. Unlike some others, I don't find the glass or the metal strip around it to be distracting at all when viewing.
11) One addition to my novel, it's been my experience so far that there are very few "problems" that arise with this TV that can't be corrected with settings adjustments.
GRXBOX360 is offline
Old 09-05-2006, 12:19 PM
PAYSHUNCE's Avatar
You need a HDMI HD cable box....you can usually pick it up same day. Otherwise you will not have an HDMI input.
Old 09-05-2006, 12:25 PM
TommyboyCAN's Avatar
GRXBOX360,
Mind posting your picture settings once you have had time to fiddle some more?
TM
TommyboyCAN is offline
Old 09-05-2006, 01:18 PM
luna5's Avatar
If it has a DVI output you can get a DVI to HDMI cable to connect to the XBR2. The only thing different in the HDMI out would be that it carries audio and the video signal, DVI carries only the video. If you are using a surround receiver then you would just take the audio output ( hopefully a digital audio out) from the STB and connect that to the receiver. My STB ( SA3250) has a DVI out and optical digital audio out for DD surround and it works great. On my cable box I find that using the DVI out gives me a little better picture quality, the component out to the TV looks a little " softer" than the DVI output. Only way to find out would be to try both.
"Future"
luna5 is offline
Old 09-05-2006, 03:22 PM
spizzi's Avatar
Hey all,
This is my first LCD Flat Panel purchase; it replaces my old Toshiba 42H81 (one of my favorite projection TVs).
Initially I had gone back and forth between whether I should sell my Toshiba or just keep it until the prices for Flat Panels kept coming down. Well, after impulse, I decided to purchase the KDL46XBR2 as the salesman matched the price for the Samsung 46" LCD HDTV (LN-S4695D) which was already on sale; otherwise I would have purchased the Samsung based on the price point alone.
Having said that, I am disappointed with the picture clarity even with HD signals. I am not sure if I have a more critical eye or am just critical in general due to the fact that I expect higher quality for the price I paid.
Here is some history regarding my thoughts on the PQ: I thoroughly compared the KDL46XBR2 side-by-side with the Samsung LN-4695D on the floor. BOTH TVs were being fed the same high-definition Discovery Channel picture (not sure if the material was 1080i or not). BOTH TVs had some sort of grainy noise (not sure if this is the correct technical term) around the edges of objects; not only the text being displayed but also around people's figures being displayed. SINCE both pictures were doing the same thing with the "grainy noise" in the exact same spot around the objects being displayed, I figured it was the signal being fed to it and not the individual Televisions themselves; otherwise both Televisions were defective which I am speculating was NOT the case. Thus, I concluded that the grainy noise / hazy jagged edges (not sure if technicians would consider this to be "artifacts") was NORMAL.
Clearly I knew Standard Definition would be crap on any LCD/Plasma; it even looked crappy on my trusty old Toshiba 42H81. So I took this into consideration when being critical about the PQ. Therefore, I only used High Definition signals to judge the PQ.
Let's go into my areas of concern:
1. PQ with XBOX 360 is not as sharp as I had hoped. I consider the PQ to be very disappointing but don't get me wrong, it is NOT EVEN CLOSE to as bad as AndrewScott's XBOX issue. XBOX 360 system settings are set to 1080i using component cables and turned "game mode" on in the Sony XBR menu. In fact, it looked a lot better on my Toshiba 42H81. Game: MADDEN 07. It seems the picture on the XBR2 IS CRISP on certain areas of the screen (like the grass when the images are completely still) but the players had extremely hazy jagged edges in their uniforms and in the outline of their bodies. When the football players in Madden 07 actually start moving/running, the moving objects lose clarity/definition. I don't get it. And it does not seem to me like it is "ghosting" as it's just the object seems to lose definition (the image does not leave a "ghost image" in its wake). Never had this problem on my Toshiba 42H81 when playing Madden. What's more is the definition of the football players appears to be pixilated the further you sit away from the screen.
2. PQ with DVD Player running 480p (utilizing Faroudja chip and component cables) has the same "grainy noise" throughout the whole picture. HOWEVER, there will be RARE times when the picture looks very sharp. Sharpness seems to be less of an occurrence as compared to the number of occurrences where the PQ is just plain noisy (again, not sure if this is the correct technical term). I can clearly see these picture issues when sitting 4 feet away from the screen (I have a sectional couch and one end is fairly close to the screen as the room setup only allows for this close seating configuration). Obviously the issues are not as noticeable when sitting 8 feet away but even the untrained eye can see it.
3. PQ with ESPNHD coming from my ViP 211 Dish Network using component cables looks very good however I still get the same noise around certain objects such as people's bodies and text. The noise is especially noticeable in High Definition content around the Television Station's logo (such as the NBC bird or CBS eye in the lower right hand corner).
4. I expected PQ to be near perfect with cartoons/animated films as the colors are more basic and the definition is not as demanding as say the Matrix Movies with Keanu Reeves. To my dismay, I was grossly wrong. The Simpsons and Family Guy looked downright awful. The grainy noise was extremely evident and the picture was hazy around the edges/outlines of nearly every object being presented on the screen. It always seemed that whenever something moved on the screen whether it was a cartoon character, a football player in Madden 2007 XBOX 360 edition, or even an actual football player on ESPNHD, the definition would degrade by 15-20% (just a rough estimate but enough to be very very noticeable).
All-in-all, if I can get the grainy noise fixed, the picture would have a noticeable increase in sharpness and thus my satisfaction rating would go up. Is there a Service Menu I can use other than what is in the standard on-screen consumer menu?
Does anybody know how to fix this or do I have a defective television? Due to the fact that I saw the EXACT SAME issues with the Samsung, I am thinking this is a normal quirk with LCD flat panel televisions? I have found the picture not to be as outstanding as I had hoped. In comparison, dare I say my old Toshiba rear projection had better definition although it was a little more refined in terms of brightness when compared to the KDLXBR2.
I think the only thing I like about this television right now is the actual design of the television (physical form). I especially like the illuminated "Sony" logo in the glass. But I didn't spend near $4K to admire the lit up Sony logo; I paid for the supposed Picture Quality behind the price. Right now I feel like I should have waited for an improvement in picture quality but, realistically, how long would I have had to wait? The timing was right as far as me being able to sell my old rear-projection television (the much missed Toshiba 42H81 but the not much missed bulky size) and getting into a perceived "good deal" price point on the KDL46XBR2. But the quality of the picture makes me question if current generation LCD 1080p flat-panel really was the way to go.
NOTE: I am not bashing the KDL46XBR2 as I want to feel like it was a good purchase decision and I do intend on keeping it. I am just looking for this forum's advice on expectations of picture quality for this current generation 1080p LCD flat-panel display. Not sure if I am being too critical? Again, are noisy/smudgy edges normal? I would tend to think it is NORMAL because the Samsung picture showed the same areas of concern. Or is something truly wrong?
DOES ANYONE ELSE HAVE THE SAME PICTURE ISSUES I AM WITNESSING?
Thoughts, ideas, suggestions? And thanks in advance to a wonderful forum!
spizzi is offline
Old 09-05-2006, 03:23 PM
trent3's Avatar
If it has a DVI output you can get a DVI to HDMI cable to connect to the XBR2. The only thing different in the HDMI out would be that it carries audio and the video signal, DVI carries only the video. If you are using a surround receiver then you would just take the audio output ( hopefully a digital audio out) from the STB and connect that to the receiver. My STB ( SA3250) has a DVI out and optical digital audio out for DD surround and it works great. On my cable box I find that using the DVI out gives me a litter better picture quality, the component out to the TV looks a little " softer" than the DVI output. Only to find out would be to try both.
Thanks Luna5. As I would want to run the audio via receiver anyways, DVI to HDMI sounds like it should work perfectly!
trent3 is offline
Sony Kds R70xbr2 70 Inch Sxrd Xbr Rear Projection Hdtv , Sony Bravia Xbr Series Kdl 46xbr2 46 Inch 1080p Lcd Hdtv
