TOSHIBA 37HL95 - How to disable the TV Guide? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-05-2006, 08:47 AM - Thread Starter
jauburn's Avatar
I own the TOSHIBA 37HL95 LCD flat panel television. I hate the TV Guide feature of this set. Is there a way to disable it? If so, please tell me how.
jauburn is offline
post #2 of 7 Old 09-06-2006, 10:00 AM - Thread Starter
jauburn's Avatar
I wrote to Toshiba but they didn't respond either.
jauburn is offline
post #3 of 7 Old 09-06-2006, 01:15 PM
adb
adb's Avatar
I have a friend having the same problem with a 32" Sharp LCD. Someone suggested going into favorites or favorite channels in the receiver and it might be able to be disabled there, but I really don't know and haven't fooled with it. His receiver is the Direct TV h 20.
adb is offline
post #4 of 7 Old 09-07-2006, 05:32 AM - Thread Starter
jauburn's Avatar
No such favorites thing exists in the Toshiba. Really sucks.
jauburn is offline
post #5 of 7 Old 09-07-2006, 07:22 AM
easycruise's Avatar
Quoted: 113 Post(s)
Liked: 37
Over on the Pioneer thread they are saying to key in "00000" for your zip code on the TV Guide and that disables it. Hope it works for you. I've heard nothing but trouble about the TVGOS system.
easycruise is offline
post #6 of 7 Old 09-10-2006, 07:05 AM - Thread Starter
jauburn's Avatar
I'll try that. Thanks. Whoever thought of adding that stupid thing to a TV should be fire. I'm sure they got money from TV Guide for including it.
jauburn is offline
post #7 of 7 Old 03-09-2007, 01:21 PM
ranger8199's Avatar
I found something that worked for me on my toshiba, Bring up TVGOS, if you go over to the setup and down to general defaults, under that there is an option for general defaults. Press the enter/seelect on the remote and go down and turn auto guide off. This doesn't kill TV guide but it does stop it from popping up everytime you turn on the TV. I called in to Toshiba's Customer support and they got mine working, it is a helpful feature when using a CableCARD. I use it all the time now that TV guide got the signal issue worked out for my area.
hope this helps, it help me while my TVGOS was not working.
ranger8199 is offline
Reply LCD Flat Panel Displays
