OFFICIAL Samsung LN-S4095/4695/4096/4696 Owners Thread - Page 155 - AVS Forum | Home Theater Discussions And Reviews
post #4621 of 4627 Old 05-10-2016, 05:56 PM
lionelhuts's Avatar
Quoted: 17 Post(s)
Originally Posted by SmackitySmack View Post
I've got an LNS4095, and if there's no signal I get a pop-up message and blue background with no problems. If I do have a signal, it's got minimal sparkles on white background, green sparkles on black. They're actually short lines of noise all over the screen, focused more towards 1/3rd over on the left. Lines are continuous but they seem to be a gradient that ramps up ever 1.5", so the lines look like individual segments.
I've read that long HDMI cables can cause this. The cable is only 6 ft long.
Also read that a board needs to be replaced, but it's totally unclear if it's the t-con board or the main board. What do I need to do here? I've been reading about 60 pages of this thread and haven't come across a definite maybe solution yet.
Are you running the Just Scan firmware? Also, if you need a new board, a new and much better quality TV is basically the same cost.
lionelhuts is offline
post #4622 of 4627 Old 05-10-2016, 07:26 PM
Liked: 0
Yessir, Just Scan works great. I've ordered a replacement remote to try this:
Originally Posted by muttlover View Post
Originally Posted by rotkiv View Post
There is an easy fix to the green shimmering problem in the service menu. Go back to post #3244 and you will find the solution. It involves going into the service menu and adjusting the HDMI 1080p delay from 75 to 70 and it seems to have solved the shimmering problem with 1080p sources. It definitely worked on my 4095.
For those who don't want to do all that searching -
With TV off press mute 1 8 2 power on -- this is the service menu. Find the 1080p Delay and set to 70.
However the shimmering seems kind of extreme. I think it's 50/50 that it's the cause.
SmackitySmack is offline
post #4623 of 4627 Old 10-24-2016, 06:14 PM
Liked: 0
Hi all,
I know this thread has been going for quite a while! I am still using my 5296D and am trying to connect it to an antenna to pick up the local DTV stations. It won't seem to find any DTV stations on either Air or Cable connections. I know it has an ATSC tuner so it should! I am wondering if the firmware mentioned in this post would help at all. The links are dead, but does anyone still have it that they can email it to me??
Any help would be really appreciated. I would hate to have to buy a new HDTV to save money by using an antenna. . . the irony.
Kyanite286 is offline
post #4624 of 4627 Old 10-24-2016, 07:32 PM
lionelhuts's Avatar
Quoted: 17 Post(s)
Originally Posted by Kyanite286 View Post
Hi all,
Can't say for certain, but I doubt that the firmware would fix it. I'd try a factory reset first. If that doesn't work, I'd get a cheap, external HDMI OTA tuner.
post #4625 of 4627 Old 10-25-2016, 03:58 AM
Liked: 0
Thanks for the reply. Can you tell me how to do a factory reset? Is it in the normal menu options or in the service menu? Thanks.
post #4626 of 4627 Old 10-25-2016, 05:12 AM
Liked: 0
I would still like to get the firmware if someone has it!
post #4627 of 4627 Old 10-25-2016, 10:47 AM
lionelhuts's Avatar
Quoted: 17 Post(s)
Sorry, I don't have the TV anymore to say for certain. If memory serves correctly, I thought it was under the setup section of the regular menu. (Though that may have just been a settings default, not a factory default.)
Reply LCD Flat Panel Displays
Samsung Ln S4095d 40 Inch 1080p Lcd Hdtv , Samsung Ln S4695d 46 Inch Lcd Hdtv
