120Hz LCD's -- will it make a difference? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 10-13-2006, 12:18 PM - Thread Starter
falser's Avatar
We've been hearing about 120Hz sets either announced or preparing for release. Are they worth waiting for? There's been some talk about how it will eliminate frame judder from 24fps film content etc. But I'm wondering if this will really make much of a difference in our living rooms. LCD's have a built in refresh delay that may make the difference a non-issue.
I've seen judder for myself in some 1080i content when it's IVTC'd to 24fps. This being on a Dell monitor at 60Hz. But I do not see it, or at least I do not notice it on most content I watch. Maybe 1 in 10 or less movies suffers from this problem, and I'm not fully convinced it's because my monitor is running at 60Hz. I think it's probably because these films don't have a proper 3:2 pulldown flag encoded -- ie. bad/corrupted MPEG source.
Any thoughts?
falser is offline
post #2 of 15 Old 10-14-2006, 12:42 PM
wtr_wkr's Avatar
LCDs have a history of being poor with motion. 120Hz is suppose to solve that problem by no longer "smearing" the image. I read something about new VPs do motion de-interlacing and motion interpolation.
Chech out the reviews of the new JVC with 120Hz. And, this chip should be in sets in the future: http://www.micronas.com/products/trud/index.html#88337 Click on the demo.
I see judder with ~all motion. That include in a theater. I'm going to wait and check em out.
HD-DVD is dead, so now I'm a Gary McCoy fanboy.
wtr_wkr is offline
post #3 of 15 Old 10-14-2006, 12:48 PM
wxkid23's Avatar
They may make a difference. 60hz is still a bit lower than humans can percieve. I know that I can notice framerate issues up to 70-75hz before I notice little difference.
wxkid23 is offline
post #4 of 15 Old 10-16-2006, 07:14 AM
NYFOOTBALLGIANTS's Avatar
Check out the new Home Theater Mag for a review of the new JVC
NYFOOTBALLGIANTS is offline
post #5 of 15 Old 01-16-2007, 11:01 AM
Gstrein's Avatar
Does anyone know if you send a 120hz signal to an existing 1080p LCD from a scaler capable of doing such will it work or not. Obviously the lcd screen is not being changed on these models it is the electronics and but I don't know if there would be a weak link somewhere preventing the 120hz signal from displaying.
Gstrein is offline
post #6 of 15 Old 01-16-2007, 11:17 AM
phigment's Avatar
If I understand correctly, these 120Hz capable screens will NOT accept 120Hz signals. They will accept 60Hz (or 24Hz) signal and convert them to 120Hz. The conversion process depends on the algorithm they use. Some manufacturers will be doing motion compensated frame rate conversion, while others will use black frame insertion.
Personally I would opt for the black frame insertion.
phigment is offline
post #7 of 15 Old 01-17-2007, 11:33 AM
wtr_wkr's Avatar
Originally Posted by phigment View Post
...Personally I would opt for the black frame insertion.
Sharp 62 series is bfi. Sharp 92 series is frc. Same panel (4ms.)
Have you seen both? Side by side?
wtr_wkr is offline
post #8 of 15 Old 01-17-2007, 01:02 PM
phigment's Avatar
No I haven't seen either. Maybe I shouldn't have said that I'd opt for bfi. I will reserve final judgement until I see them. But it makes more sense to me to just use bfi to emulate the impluse nature of CRT screens and reduce the hold nature of LCD (which causes the blur to begin with).
I feel that the motion compensated images will introduce new artifacts that I may not be happy with.
But like I said, I will wait until I get a chance to see both before I say which is best.
phigment is offline
post #9 of 15 Old 01-24-2007, 11:27 AM
Jeff_DML's Avatar
I turned on Black Frame Insertion(Fine Motion) on my Sharp D62 and so far havent noticed any difference. I have only watched a few sitcoms so not a good judgement. I still seem to see some judder and turning it off/on doesnt seem to make a difference. The network shows are video or film based? maybe I am see 24frames judder not the LCD related judder? I still want to watch some fast action sports with a lot of panning before deciding if it works or not.
Jeff_DML is offline
post #10 of 15 Old 02-02-2008, 12:31 PM
Randomcreek's Avatar
"Some manufacturers will be doing motion compensated frame rate conversion, while others will use black frame insertion."
Why not do BOTH? I think for 24FPS video at 120Hz there would be 5 copies of each of the 24 frames displayed per second. You could use the first 4 and do algorithmic interpolation and the last as a black frame. Or insert black frame every other interpolated copy. Not sure if this would work- Just a thought, but potentially you could get a synergistic effect using both methods together that would produce a result better than either one used alone.
Randomcreek is offline
post #11 of 15 Old 02-10-2008, 11:21 AM
aznboi04k's Avatar
am i the only one that don't like 120hz lcd?
i went to circuit city to check it out on a samsung 120hz lcd playing the incredibles in bluray. the video was silky smooth when there aren't much motion going on, like people standing still and talking, but when the scenes starts to move, the video quality looks terrible! the frame rate look like it drop from 120hz to maybe 30hz. i thought it was very jarring on my eyes. it felt like playing games on a computer that slows down when too much actions occur.
i fine it better to have a 60hz lcd cause then your eye can compensate for the motion blur and it's not as noticeable when there are a lot of motion. am i the only one experiencing this phenomenon?
aznboi04k is offline
post #12 of 15 Old 02-21-2008, 05:02 AM
BBQTofu's Avatar
120Hz sounded good on paper. However...is liquid crystal's response time fast enough to support 120 FPS? Is the final front of screen performance really at 120Hz? Most of the current advertised LCD response time is measured from gray to gray in measurement of mS (Funny how nobody has ever specified from what % of gray.). Maybe 120Hz makes more sense for faster display technology such as plasma or DLP. For LCD, I'm skeptical on the real performance benefits.
BBQTofu is offline
post #13 of 15 Old 02-21-2008, 05:34 AM
MrEastSide's Avatar
Quoted: 25 Post(s)
Liked: 55
120hz to me makes everything look like it's in fast forward. Terrible if you ask me. In the side by side demo some of the TVs have going I thought the normal side looked much more natural and better.
Of course, I got it modified with the TK-427, which cheeks it up another, maybe, 3 or 4 quads per channel.
MrEastSide is offline
post #14 of 15 Old 02-21-2008, 06:57 AM
rocky01's Avatar
Why not feed a 1080p 120hz signal from videocard and watch signal playing a film?
rocky01 is offline
post #15 of 15 Old 05-05-2008, 10:09 AM
eyecon82's Avatar
Well...take a look for yourself and compare....i can see a huge noticeable difference b/w the 60 and 120hz lcd sets
eyecon82 is offline
Reply LCD Flat Panel Displays
