Official Westinghouse LVM-W4207 Thread - Page 24 - AVS Forum | Home Theater Discussions And Reviews
post #691 of 701 Old 12-04-2008, 08:50 PM
derson's Avatar
After searching everywhere for the full Extended Function Codes for the Westinghouse W4207 42" 720p LCD Monitor, I decided to run through the full code set myself and hope this will help others in the future (the first 256 codes that is)...
This TV has no ATSC tuner, but is a great monitor for connecting to multiple high def inputs. As there is no tuner, the remote is pretty limited in functionality, but at least most of the items have direct codes (except for discrete on/off codes).
Using the Sony TV device code: 0000 - www[.]hifi-remote[.]com/cgi-bin2/ueic.cgi?TV_0000 - as a starting point, I found many were different, some not listed, and a whole bunch not used.
As I'm using a JP1.1 remote, I'm listing all 5 digits, obviously you can remove the leading 2 zeros if you don't need them (these will provide full functionality of the RMV-01 remote included with this model)... the main reason I dug these up was because I wanted to map the button that changes the brightness onto my Comcast cable remote.
00002 Menu
00012 4
00013 8
00014 2
00015 6
00016 3
00017 7
00018 1
00019 5
00028 VGA
00032 HDMI
00034 Video
00035 DVI
00044 Right
00049 Sleep
00051 Left
00063 Down
00067 Up
00076 Volume Down
00078 Channel Down
00079 Power
00080 Volume Up
00082 Channel Up
00083 Mute
00140 Enter
00142 0
00146 9
00159 Svideo
00162 YPbPr1
00172 Exit/Back
00176 i-Display
00210 Brightness
00211 Screen Format (Standard/Fill)
00220 Pip
00221 Pip Swap
00239 Input
derson is offline
post #692 of 701 Old 12-21-2008, 10:29 PM
rockaway1836's Avatar
Quoted: 67 Post(s)
Liked: 101
Originally Posted by boomstick View Post
I was wondering if someone here would be willing to sell me their original stand that came on the TV. I no longer want to use a wall mount but I seem to have lost mine. If not, does anyone know if I can order one? Thanks in advance.
If you are still looking, check your PMs
rockaway1836 is offline
post #693 of 701 Old 02-19-2009, 03:01 PM
speedfrk's Avatar
Buy.com has these is stock again for a very good price. Mine is 2 years old now and has been flawless with a HTPC into DVI1 and a PS3 in the HDMI port. Only complaint is that it doesn't do a good job of auto-detecting which device is on, but all in all a great monitor.
http://www.buy.com/prod/westinghouse...tml?adid=17654
speedfrk is offline
post #694 of 701 Old 03-01-2009, 06:40 PM
PerfectCr's Avatar
Just want to say I've been using this set as a secondary HDTV for the wife and it's been going like a champ since Nov. 2007 (BF Deal at BB).
PerfectCr is offline
post #695 of 701 Old 01-13-2010, 09:38 PM
Burgoo's Avatar
I have had my W4207 for over two years. Worked perfectly until today and then while watching TV the screen just died but the tv was still one, or at least the blue led was. Now when ever I turn the TV on the backlight flashes once and then nothing. Anyone have any idea whats wrong? Is there hope or should it get the dumpster?
Sorry if this is the wrong place to put this.
Burgoo is offline
post #696 of 701 Old 01-14-2010, 12:18 AM
royrose's Avatar
Sounds bad. Have you checked whether westinghouse has a help line? Mine's about 2 years old and working fine.
royrose is offline
post #697 of 701 Old 01-18-2010, 08:41 PM
Burgoo's Avatar
I took it apart and the circuit boards look fine. Also the audio itself still works. I haven't tried calling westinghouse yet. Sadly I leave on business soon and don't have time to deal with this. If I get it fixed when I get back I will post an update saying what was wrong.
Burgoo is offline
post #698 of 701 Old 02-04-2010, 08:28 PM
menonan's Avatar
I just had the same issue. Wife and son were watching and suddenly the TV just went blank. The blue LED is still on. If anyone else was able to figure it out, please share
menonan is offline
post #699 of 701 Old 02-08-2010, 06:21 PM
ataxic_dentist's Avatar
I unplugged the power cord from the tv for a couple of minutes and plugged it back in. I have done that a couple of times and it has worked for me!
ataxic_dentist is offline
post #700 of 701 Old 07-24-2010, 06:26 PM
Analog-X64's Avatar
I picked up one of these used and its looks great. Now I was wondering if there are any new firmware updates for this unit?
From System Info Menu.
FW v1.4
20070425
SK-42H240S
LC420WX5
MCU FW v1.10
Analog-X64 is offline
post #701 of 701 Old 09-15-2010, 06:00 PM
N204life's Avatar
Please let us know. I have the same problem, i thought it was a backlight inverter board. So i bought a new one and replaced it and still the TV backlight turns on, and then right off. I noticed once i took it apart i saw 2 blinking orange LED's on the back flashing after it was turned on. LED #2 and LED #7. Does anyone know what that means??
N204life is offline
Reply LCD Flat Panel Displays
