OK! Your LCD! You Tell Me! Got a new one? post it here - Page 51 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
Old 02-20-2014, 09:56 PM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 622
1. The "Model" you have.
Sony KDL 40R450A
2. What convinced you to purchase this particular model.
Published reviews and prior Sony ownership '
3. What you like best about your LCD.
It has decent speakers good 5000:1 static contrast ratio
decent accurate color .
4. What you don't like about your LCD.
viewing angle is very narrow the panel could be a little brighter at max back light. .
5. What "Feature(s)" you wish your LCD had.
A panel calibration adjustment options in serv menu.
brighter back light
6. What advice or suggestion would you make to the "Manufacturer" about your LCD.
Brighter back light, color management options
7. What was your biggest "Surprise" after you received your LCD.
Use of 6bit + high FRC Samsung SPVA panel rather than an 8 bit panel
no color management control /calibration other than basic settings .
8. What "Problems or Issues" have you had with your LCD.
Picture quality required some adjustment back light while adequate could be brighter.
9. Do you really think that today's "Prices" are worth it.
prices are generally good historically speaking.
10. Any additional information that you want to add is encouraged.
good picture at it's price point after adjustment.
No picture or color management adjustments in serv .menu .
Sony KDL 40R450A Best Settings ,
Cinema mode + Cinema Scene select
All Eco settings @ OFF
Backlight @ Max
Brightness @ 57 - 61 or preference depending on program
Color @ 55 -57 to preference depending on program
Hugh /Tint @ G3 to preference depending on program
Contrast (picture ) @ Max
Color Temp @ Neutral
Cine Motion @ Auto
Screen settings
Wide mode @ Full
Auto Wide @ On
4:3 defailt @ Off
Auto Display area @ OFF
Dispay Area @ Full Pixel or +1 depending on source
These settings result in best overall results and best color accuracy
short of a professional measured calibration.
I was able to get a pretty decent HD picture competitive or better than
most similar price. I tried lots of different settings including AVS HD.709
and found the above settings to work best .
The narrow viewing angle is a weaknesses one should consider though .
tubetwister is offline
Old 04-14-2014, 06:22 PM
TheXav's Avatar
Sony XBR-X900A
Picture quality + Design
Picture quality is awsome
Nothing yet
Cheaper 4k movies would be great :-)
Netflix 4K support
Netflix 4K support
- How good the picture is
- How good the 3D from 2D is
None so far
9. Do you really think that todays "Prices" are worth it.
Yes
TheXav is offline
Old 06-19-2014, 06:29 PM
Dr.Shankenstein's Avatar
Quoted: 235 Post(s)
Liked: 142
1)What "Model" do you have?
Samsung UN55F9000 UHDTV
2)What convinced you to purchase this particular model?
Previous Samsung products and upgrade path with "One connect box/EVO kit.
3)What do like best about you LCD?
Picture quality featuring deep black,great shadow detail,stellar 4k upscaling and fantastic motion with film and gaming.
4)What don't you like about your LCD?
Average viewing angles and average input lag
5)What "features" do you wish your LCD had?
HDMI 2.0 and new 4k streaming codec HVEC .256
6)What advice or suggestion would you make to your LCD?
A discount on One connect box for early adopters
7)What was your biggest surprise upon receiving you display.
The very impressive "Edge dimming" employed,motion performance and upscaling 1080p-4k
8)What problem or issue have you had with you set?
Minor firmware issue causing flickering
9)Do you think with today's prices it is worth it?
I got mine on a stellar deal,so yes. If you are in the market for a 4k display spend little extra and get the 2014 HU8550 or if you can find one XBR-55X900A 4K Sony.
10)Any additional advice you can give on your display?
Check your local big box retailers for open item displays you'd be surprised how often you would find a great deal.
Dr.Shankenstein is online now
Old 07-02-2014, 12:43 PM
loopthrough's Avatar
Liked: 6
Sony KDL 40R450A
brighter back light
Backlight @ Max
Cine Motion @ Auto
Screen settings
Wide mode @ Full
Auto Wide @ On
4:3 defailt @ Off
Hi. I'm not sure where you got that contrast ratio info from, but it's wrong. The static c/r would be something more like 3000:1 if that and at a very low backlight setting. 5000:1 is only achievable on a very rare display, such as FALD with a VA panel (usually a Sharp U2VA).
It has great sound though because of the DLED backlight and thicker casing.
loopthrough is offline
Old 07-19-2014, 10:18 PM
Liked: 4
LG 47G2 (new to me)
Passive 3D is very good. Price on used market was extremely competitive ($550)
Passive 3D is excellent for family and guests, access to Google Play Store, 3 USB that can run HDD, USB hub, etc.
Remote is ref, not IR, so no LOS issues.
2d to 3d conversion is good, especially when set to around 14.
The primetime guide is pretty nice since I only have basic cable.
No ARC, isn't really compatible with anything in the play store, no flash support anymore after update. No analog inputs, without corded mini plug adapters.
*Flash*
*PVR functionality to external HDD *
Taking flash support out was dumb. Not letting me switch inputs without drilling thru menus dumb.
No analog input jacks, just a mini Jack pigtail solution.
Primetime app is more useful than I thought.
Having to wait 45 seconds to access anything but live/cable TV.
None really
At 550 it is a great buy, but I'd rather have the non-google model if I was paying much more than that, they are just more useful and flexible. Luckily my HTS is also LG and has the LG smart tv apps built in, so I get both versions.
I love the passive 3D, much more comfortable for everyone than active 3D... and my dozen or so pairs of movie glasses from the theatre really fit the bill (and my wallet) better than the LG OEMS.
fathereagle is offline
Old 08-06-2014, 12:54 PM
ThomasI's Avatar
Liked: 0
Sony KDL-48W605B
Sony KDL-48W605B
Bargain price (I think): what corresponds to USD 720
Great review here: http://www.hdtvtest.co.uk/news/kdl40...1404233740.htm
Low power usage: 45 W
Good picture. Easy menus. Low power usage. Very light
No real motion compensation
Virtually non-existent user manual
Motion Compensation ("real" Sony Motionflow)
Make a user manual somewhere (online, in the TV menus, on paper, whatever), that at least briefly describes the purpose or at least the functions of each menu option
No motion compensation. Unlike many others, I hadn't really bothered to look into whether or not the TV has proper motion compensation, so I do not feel cheated that Sony advertises the TV as having motion flow. And I still have about a week to decide if I want to return it for at refund. So I am no angry about this - just surprised that my 6 year old Samsung which I replaced beats the new Sony in this category.
I have had problems calibrating contrast to fit some test patterns. The picture certainly changes, but it seems like I am not able to hit the target in the two patterns I tried. Both were from an HTPC, which may complicate things, so I may just be doing it wrong.
For sure. Despite my small complaints here, it is great value for money. I think I paid something like USD 2000 for the old Samsung and the USD 700 Sony clearly beats it in almost every category.
Not really.
ThomasI is offline
Old 08-06-2014, 01:23 PM
Liked: 0
Hi guys! New to the forum!
Insignia NS-48D510NA15 48"
The OP of the Official owners lounge of this model on this site, the price, and the possibility of this having a Samsung S-PVA panel.
Image quality
Grey banding
Nothing extra, quite fine with it, was looking for a simple TV with a good panel for use with gaming consoles, and possibly an HTPC, but looks like my PS3 will do just fine playing videos from my ReadyNAS NV+.
Make the back of the panel out of sturdier materials or thicker plastic. It isn't horrible, but feels a bit flimsy when tapping on the back of the display casing compared to a Vizio at work.
The image quality and size once placed in my apartment. Plenty big, but I was surprised with the image quality once I played with the settings a bit using my PS3 as the source (RGB limited mode).
Playing Bayonetta on my display was a great experience with NO issues I could make out.
No problems so far, *knock on wood*, and I usually have the worst of luck with things.
I paid $399.99 (CDN) + environmental fees + taxes, and it came out to just over $500 with a printer I purchased for my father, on sale as well for $20.
SO YES, a BIG FAT YES, especially for this TV. Great value for what it is, and I honestly think it can rival much more expensive TVs for image quality, not features.
Plain Jane was what I was looking for and I got it.
I'm incredibly happy with the TV, and kept comparing the image quality to my Nexus 7 (2013) tablet and LG G2 phone. Yes I know, they're mobile devices what the heck are you doing? To me my LG G2's display on full brightness is beautiful and vibrant. I went with the settings provided by the OP of the owners lounge here, and then adjusted to my preferences, brightness at 51, one touch higher and blacks went "lighter" and had a glow, so that was my max. Contrast bumped up to 67 I believe, can't remember exactly, and sharpness turned way down, then it looked great to me.
The reds a bit orangey, but I can play with tint and colour later. The other colours seem pretty good, not over saturated, but not by any means dull.
I am one happy owner. I could've went with a 55" Samsung UN55H6350 for double the money, but I thought I'd save some dough.
Edit: Oh, and cheers, Mike.
Shampoo.kr is offline
Old 09-09-2014, 09:07 AM
Liked: 0
Sony XBR65X-850B
Old tv going bad and price drop to $3K with new Blu-Ray player.
Picture quality and easy setup.
The feet are not very sturdy, they are only held on by two small screws each. The camera dosen't fold back unless you unplug the usb.
Better low end sound, indicator that you are indeed watching either 4K or 4K upscaled.
Smoother edge lighting, better speakers for deep sounds.
That it turns on and switches input after placing in a DVD!
There are a couple bright edge light spots when playing letter box DVD video. Lava effect during some solid colors.
Getting better, full aray backlit is still way over priced.
Overall satisfied, I wish there was a "easy" setup feature for screen setup.
Imjaybird is offline
Old 09-09-2014, 11:53 AM
TravisBean's Avatar
Quoted: 132 Post(s)
Liked: 123
Sony XBR65X-850B
How does the passive 3d experience on this 4k set compare to active 3d on a 1080p set ?
TravisBean is offline
Old 09-19-2014, 12:24 AM
gh32's Avatar
Vizio M552i-B2
I was looking for the best value within a limited budget.
Great picture quality for the price!
I'd love darker blacks.
Gamma control would be nice, 20-point greyscale adjustment, tighter control of the local dimming feature
6. What advice or suggestion would you make to the "Manufacturer" about your LCD?
Nail down the local dimming feature and the set would be incredible.
The panel looks great on the wall. Aesthetically, it looks good.
None so far.
Absolutely.
Very happy with the purchase. Yes, there are things I'd like it to do better, but there's not a set that can beat it for the price I paid!
gh32 is offline
Old 10-20-2014, 07:29 AM
Ajay M Nair's Avatar
Liked: 0
Send a message via Skype™ to Ajay M Nair
Samsung 55H7000
High Contrast, low black levels and very good 3D
3D is just awesome.
Black level not as low as I expected. Motion resolution not as good. Using interpolation based motion smoothing settings results in artifacts.
Nothing
Decrease the price
TV looked larger than I thought as the bezels were extremely thing
I got my panel replaced with a new one because of backlight issue
Absolutely not. Prices are way too high! :-(
I just wish that my TV was larger now. Maybe 65" or higher!!!
Ajay M Nair is offline
Old 10-21-2014, 07:34 AM
FragTek's Avatar
Quoted: 17 Post(s)
UN65H8000
Non-4K curved screen, amazing clarity.
Image quality.
The base seems a little wimpy.
None, it has them all....
Supply a sturdier base and decrease the price.
Just how good the picture really looked.
Had to exchange my first set for very bad flashlighting and clouding. Replacement was perfect.
Absolutely not. 1080P sets should be half the current prices.
If you're thinking about this set, just get it. It's amazing in every way!
Sent from my SAMSUNG-SM-N900A using Tapatalk
FragTek is offline
Old 10-26-2014, 11:14 AM
Liked: 0
Micromax 40T2810FHD
Fitted my budget really well. Pretty good LCD as far as I can tell
Nice blacks.
The menu is horrible. Color Calibration is pretty off.
Better speakers, though I got externals. Sturdier build quality. Also I had a Sony 46EX520 for a night and I loved the Sync Feature.
Sturdier build quality, better menu system, basic color calibration.
The contrast ratio seems pretty nice.
My PS3 wasn't working at all in HDMI, had to turn Deep Color Off.
This one was at a really nice price point.
Initial impressions are positive. Dunno how long it will last though.
nitant is offline
Old 10-26-2014, 11:17 AM
Liked: 0
I just copy pasted that from the last post...:P
BTW can anyone help me with service menu codes for this TV? The menu is horrible and I really want to calibrate the colors.
nitant is offline
Old 11-01-2014, 09:49 AM
tjk3030's Avatar
Quoted: 53 Post(s)
Sony XBR-65XBR 4k
Prior experience with Sony & picture quality
3. What you like best about your LeD.
Picture quality
Nothing so far. But still new to me.
Nothing
Decrease the price
The size & picture quality
Non
Purchased at BB, had a coupon from Fry's they waive the sales tax on any 4K set, plus 24 months interest free, free delivery & took away old set.
Nope
This ain't no party, this ain't no disco
tjk3030 is offline
Old 11-02-2014, 06:42 PM
Albert Noel's Avatar
Insignia NS-40D510NA15 40" LED
I was looking for a decent budget oriented display to replace an ancient tube TV that my gf has.
The image quality is fantastic considering it's considered a "cheap" brand. I was not expecting such a good display for under $300. I also like the extremely thin bezel. It accepts and displays a 24hz 1080p signal (something I would have never expected on a budget set)
The stand feels flimsy and not exactly the most stable. Not a huge fan of the sound. (It sounds hollow and flimsy)
I wish it had more than two Hdmi ports.
I also wish it had the ability to play media from a usb stick. as of now, it only displays jpg images.
It would be nice to have a much more solid base instead of just flimsy plastic. It's not a deal breaker but would be nice.
Honestly, for a sub $300 set, the entire thing was a surprise. If you need a 40" set or smaller, you really can't beat it. It's got great image quality and not much else out there for the price can match the overall package.
none as of yet.
Absolutely! For a no frills LED set, with basic functionality (meaning, no smart features and a regular 60z panel) i would have happily paid more.
I feel like the best buy Insignia brand is often overlooked when it comes to the budget oriented buyer. If you aren't uber-picky about your image (i mean it's no high-end OLED set here) and just need pure functionality AND still have great image quality then i wouldn't hesitate.. Especially at this price point.
Albert Noel is offline
Old 11-11-2014, 10:49 AM
brad1138's Avatar
Quoted: 56 Post(s)
Liked: 24
Vizio E700i-B3 70" LED LCD
Price and reviews (Picked up for $1,379 & no Tax). Very well reviewed set for an entry level model, reviews as good or better than M series
Aside from price, the picture is very good. Built in color & gray scales. Low input lag. Overall very happy with TV.
No auto input sensing, menu a bit basic.
Really isn't anything I am missing.
None
My wife didn't shoot me
There is a glitch in the menu, cursor jumps around sometimes, but it is rare and not worth trying to get fixed.
Definitely on this set.
I think Vizio has come a long way. A few years back I wouldn't have considered getting one.
Home Theater: Emotiva UMC-200, Citation 5.1 running Mirage M-3SIs, Harman Kardon signature 2.1 running Mirage M-CSI (center) & 4x BIC V-52 (surrounds), 2 x Velodyne ULD 15 Series II Sub & Amp, PS3, PS4, XBOX 1, 2x Adcom ACE-515, Vizio E-701B-3
2.0 setup: Acurus LS11, Citation 5.1, Mirage M3SIs, Onkyo DV-CP702 (CD transport), Schiit Modi Multibit DAC.
brad1138 is offline
Old 11-15-2014, 03:28 PM
Liked: 1
Samsung UN75H6350
Prior Samsung ownership, user reviews and Samsung reputation.
The picture quality, the size and the design.
The chrome stand. It's too visible and distracting. A black stand would look better and blend with the TV.
4K for the same price
Stop the hype about refresh rates. Most casual viewers won't see the difference, if any, between a 120Hz and 240Hz. I certainly can't and my vision is not what it used to be anyway.
It is even bigger than I thought.
None so far.
HDTV Prices could always been lower but they've come down significantly
None
Phileq is offline
Old 11-15-2014, 06:30 PM
Mobutils's Avatar
Liked: 0
Asus PA238QR (x2)
Great Price, $239.99 @ Memory Express in Calgary
Great Hight Adjustable Stand with 90 degree rotation its fantastic for showing many lines of code (as a programmer its awesome a whole new experience)
One of the power saving features is that the screens have a IR sensor that detects if you are in front of the display... however with two of these bad boys if your not sitting in the right spot at your desk this feature can turn off the display when your using it.
This display comes with preset colour settings but unlike other pricer models it does not have some fine adjustments on the colour... its essential for me but would make this monitor better.
None really,
None, I did my research... although I did have a misconception that the USB hub that is integrated into this unit was USB 3.0 but in reality its 2.0... thats not really the fault of the display... more a fault of my memory.
None so far.
Yes
This is a great choice for my application of these monitors... I'm not a gamer... and if you were I would suggest getting a display with a higher responce time... but I'm not so not an issue for me.
Mobutils is offline
Old 11-16-2014, 10:00 AM
Person99's Avatar
Liked: 125
Vizio 64" M-Series 2014 (M652i-B2)
Price and good reviews (looking for "stop-gap" display until OLED affordable)
Nothing.
Poor picture quality including:
a) Banding
b) Though calibrated to accurate colors and gray-scale the picture is flat and lifeless compared to my old plasma
c) Poor picture uniformity
d) Motion looks horrible
e) Numerous artifacts
f) Dramatic loss of picture quality when viewed more than 10 degrees off axis
A watch-able image
I really thought it was great to try to support an American company, but you need to make decent products not just cheap products.
How bad the picture quality was considering the many decent review and owners praise of it.
See above picture quality issue.
No. I'm not sure if the problems of the LCD tech are surmountable. I know this is a cheap TV, but the picture should not be this bad! We can only hope OLED saves the day.
Am boxing it up to return. Will look at higher priced LCD sets, but I think the best bet is to grab one of the few remaining plasmas for now.
Person99 is offline
Old 11-22-2014, 03:23 AM
Quoted: 13 Post(s)
Liked: 0
Tell me the following:
Samsung 65" H7150
Reviews. I looked for awhile and this thing was rated really well. Also its PreBlackFriday sale for 1500.00 at Frys. Did I mention they paid the tax on it as well! 1502.00 out the door!
It's a Smart TV. I am coming from my first and only TV; a Coby 32" 720p.
Haven't installed it yet, but from what I have read: Viewing Angles
None. It seems to have everything. The curve would be nice, but out of my price range
Nothing I can think of.
The size. Jesus I didn't realize that 65" was insanely huge. But it may just be me coming from a crappy Coby 32"
None, yet to install
At 1500, yes. I don't have cable on Fiber Internet. So I stream everything, and with the Smart Hub it makes it 100x easier. I also have a media PC that I will be connecting to it.
It's for a great price right now! Frys will pay tax on it, Amazon has it for the same price with free shipping and tax free to certain states.
SgtGoldy is offline
Old 11-27-2014, 12:54 AM
el_Fernando's Avatar
Quoted: 13 Post(s)
Liked: 31
LG Electronics 55UB8200
Price was right and had the features I wanted
4k baby!
I wish I had the WebOS based TV
Fine the way it is
Get this damn thing up to 240 hz refresh
The "Smart" features actually work pretty well
None yet but I'm looking
Yep
Don't underestimate the power of stupid people in large groups.
el_Fernando is offline
Old 11-28-2014, 12:10 AM
Lost_Mind's Avatar
Quoted: 34 Post(s)
Originally Posted by vegout View Post
Just got a new LCD Flat Panel? Post it here ONLY. Please do not post projection models.
Samsung UN55H6350
Price and picture quality
Is not a Sony KDS55A3000 with a failing optical block
Easy to please, love it all...
The Smart Remote that the 6400 has...
Build a mid-range AVR to compliment it...
There have been none so far...
I bought this set on Nov 8 and after setting it up noticed some pixels blowing nothing but green on all sources. Took it back the next day to get it replaced @ BB and swapped it w/o a hitch. New set is cherry.
For the set I got and for the reason I got it for hell yeah! $799 w/ $100 BB gift card.
Samsung UN55H6350/Denon AVR-3806/PS4/
Klipsch Cinema 12/Panamax 5300-EX/DirecTv HR44-500/
Harmony 650
"There is nothing more creative than the human mind in the process of self justification..."
Lost_Mind is offline
Old 11-28-2014, 07:29 PM
Christine85's Avatar
Samsung 32" H5500
Comparison reviews and price
Smart hub, crisp pictures
Watching from the side gives off a red tint to the picture, sound from speakers sound like a tin can, quad core processor lags at times on the Smart Hub, the IR cable exposed is stupid. How come it couldn't be built in with the TV?
More composite inputs. My old set up was more compatible than this set. If anyone can help me with a new setup (DVD-R to cable, DVD-R to TV) without buying adapters (according to Samsung tech support), give me a holla!
Replace the universal remote with a keyboard or touch pad remote. I know you have touch pad remotes on your higher models but don't cheap around for your lower models.
Very light TV. I'm a petite female and I could lift the Tv with one hand, It looks so tiny compared to my older model Samsung A550. It's the thiner bezel that does it.
Trying to figure out the Smart Hub with the Comcast remote and Logitech wireless keyboard/mouse.
I paid $300 for it. Not a bad price for a TV comparable to the 6350 that is $300 more
Christine85 is offline
Old 12-17-2014, 07:11 AM
wtxgringo's Avatar
Quoted: 51 Post(s)
Liked: 63
Sony KDL60W630B
Best value for size non 3D
Picture quality, Great color deep blacks, ease of setup. Even has PIP. All that nonsense about plasmas being better than LED for black levels Ha!
Very lightweight considering I need to have a speaker shelf on top for my center channel. TV is super thin too, feels a bit cheap compared to the heavier plasma set I have. Remote looks/feels cheap; stand is matte silver, should've been polished chrome imho.
None that I can think of!
Upgrade the remote
How small the tv looks compared to the LG 60" plasma it replaced! Guess that's because it's thinner overall & sits lower on the stand than the LG.
Getting audio out with apps but figured it out. Just hook hdmi2 up & enable rihd in avr. Save picture adjustments via the "custom" setting.
For the most part. If you can get them on sale, had to pay full price for this as I missed the pre-Thanksgiving bargains
TV is nice overall, like the pq better than the LG plasma actually. Is sharper, clearer & hardly any reflective glare compared to the plasma daytime or at nite with a lamp on! Using the plasma was like watching myself watch tv! Thin bezel, flimsy frame, cheap remote but overall, a good tv so far.
Name:	2014-12-17 08.59.14.jpg
ID:	427306   Click image for larger version
Name:	2014-12-17 09.43.19.jpg
"To the journey..."
Sony KDL60W630B; Onkyo TX-NR818
Polk RTi A7 Mains; Polk RTi CSi A6 Center; Polk RTi A5 Wides & Surrounds
HSU VTF2-Mk4, Dish Network 722k, Iogear WiFi Hub
Teac PD-H600; Marantz BD7004;
Orbit TT Red Plinth, Acrylic Platter, Ortofon OM 5E Cartridge
wtxgringo is offline
Old 01-03-2015, 05:05 AM
sci0n's Avatar
Quoted: 26 Post(s)
Sony KDL W700B
Reviews and ratings
The input lag is very low so console gaming on it is a joy
viewing angle is pretty shallow and picture quality decreases depending on where you are sitting in the room
Slightly deeper blacks and better sound quality
Try to minimize the clouding on black pictures as much as possible
How good the picture quality looks in the day time vs the night
Some deformed blacks when colors switch from gray to black and the clouding on black screens
9. Do you really think that today's "Prices" are worth it. the prices today are amazing 10. Any additional information that you want to add is encouraged.
This is a beast of a gaming TV, very affordable and is really good for tv and movies if calibrated
Sony KDL W700B Best Settings ,
Game Original + Game Scene select
Backlight @ 6
Brightness @ 55-57 depending on lighting and time of day, Blacks test calibrated for best results. Window is behind couch and tv is across from it.
Color @ 60- adds more pop and gives a very vibrant picture for games and movies
Hugh /Tint @ 0
Color Temp @ Warm 2
Cine Motion @ Off
Screen settings
Wide mode @ Full
Auto Wide @ On
4:3 defailt @ Off
Sharpness @ 65
Gamma @ -1
All advanced settings off . Motion flow and all noise reductions off. . . These are amazing settings for games and movies and was partially calibrated with Disney's WOW disc and personal preference. These settings can best be utilized on the KDL w700b and KDL w800b series.
sci0n is offline
Old 01-05-2015, 07:37 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
1. The "Model" you have:
Sony KDL-55W800B
I bought it to use in my bright man-room where the vast majority of my viewing is news programming, documentaries, auto racing, sports, and some prime time shows - mostly during morning and daylight hours. I rarely ever watch movies in the man-room - we watch them in the den on one of my older Plasmas, and pretty much only at night. My plan is to move my Panasonic 55ST60 Plasma from the man-room to the den to watch our movies on. The LCD TV seems to be a better fit for my man-room viewing habits and bright daylight environment.
2. What convinced you to purchase this particular model:
Semi-matte non-reflective screen, very good black levels, generally favorable reviews, PQ looked good in the stores, lots of picture settings, sleek bezel, and it's not a Korean brand.
3. What you like best about your LCD:
Good Screen Uniformity, virtually no Flashlighting, no Blobs, no Banding of any kind when viewing content, Good Black Levels for an LCD (as long as i sit at or very near center), Semi-Matte screen handles bright-room reflections pretty well during the daytime, image is crisp and detailed, and colors look good. It looks better than i thought it would. I also like how it maintains it's screen brightness on bright scenes, where the typical Plasma dims a little when the ABL kicks in. I knew LCDs would be better in this regard, but it also made me dislike ABL even more than i already did (ABL is one big downside to Plasma). I don't miss ABL one bit.
4. What you don't like about your LCD:
The Contrast Ratio is not as high as my Panasonic 55ST60 Plasma (which i fully expected) but it still pops pretty good.
Black Levels are not as deep as on the ST60 (which i also fully expected) but are much deeper than on my older Panasonic G10 and PZ700U. If i make blacks blacker, they become a blob and lose all shadow detail. If i adjust Brightness upwards until i can see shadow detail, blacks are now more gray and the contrast ratio starts looking lower. It's not huge, but it is noticeable when the ST60 is in the same room (they're going to be side by side for a while as we figure out the den thing).
Narrow viewing angle - since it has a VA panel, the Contrast level starts to degrade when i move about 30 degrees off center and gets worse the farther over i sit and the image gets very washed out (typical LCD issue which was expected). Not a big deal for me since i watch this display pretty much straight on. It's perfectly fine for two or three people sitting on a couch FWIW.
Image is somewhat digitized and a little less natural looking compared to ST60, but further tweaking has lessened this effect and now it's looking pretty darn creamy.
5. What "Feature(s)" you wish your LCD had:
It already has plenty of features and i can't think of anything offhand. I have no use for 3D so i ignore that feature, just as i have on my Plasmas.
6. What advice or suggestion would you make to the "Manufacturer" about your LCD:
It would be nice if the Power input jack was located near the Inputs instead of all the way on the other side of the rear panel. A Scene Select button on the remote would be handy (an older Sony EX700 i was testing had this on the remote), and it would be nice if they offered a way to completely hide the internet Apps screen when i simply want to change some settings (only accessible from the Apps screen).
7. What was your biggest "Surprise" after you received your LCD:
How much better it looked at home connected to my own antenna and my own cable source compared to how it looked at the stores, and how well it stacked up against my Panny 55ST60 Plasma.
8. What "Problems or Issues" have you had with your LCD:
Just the usual LCD issues i listed in # 4, but no problems or defects at all. The TV is performing great !
9. Do you really think that todays "Prices" are worth it:
Totally, i caught this on sale at BB for $899 and i think it's a great value.
10. Any additional information that you want to add:
I initially set it up side-by-side with my Panasonic 55ST60 and adjusted the settings in an attempt to make it look as close as possible and after a lot of trial and error, i ended up getting pretty good results - maybe 95% as good as my ST60 (which is better than i expected actually). I posted my updated settings in the W600/W800B/W850B thread:
Sony 2014 W600B,W800B,W850B
___________________________________________
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
Last edited by RandyWalters; 05-04-2016 at 08:38 PM. Reason: updated info after spending more time with the display
RandyWalters is offline
Old 01-10-2015, 11:28 AM
delta50's Avatar
Sony KLD40W600B
Current owner of Sony Flat Screens and UT video of model, plus opinions here
Quality of picture and Black Bezel
The stand that came with it
None
Supply a Black stand
None
None So Far
I got it from Amazon for $370.34 “used” with free shipping / but it look's brand new and not a scratch on it or a fingerprint and it was still in the original box!
Amazing Picture !
delta50 is offline
Old 01-10-2015, 03:40 PM
miata's Avatar
Quoted: 65 Post(s)
XBR-70x850B
Sony XBR-70x850B
Demo in local store with great image after quick calibration, size = 70", price = $3,000
4K looks great and even 1080p provides more definition
Can't think of anything else I would want.
TV messages are too verbose when switching inputs -- audio switches back and forth, etc.
Easier way to switch inputs when watching NetFlix. You have to navigate out of NetFlixx with multiple steps before you can switch inputs. This makes it a little inconvenient for a universal remote.
Works very well as a monitor for my MacBook Pro laptop using HDMI.
The TV tends to black out frequently when in ECO auto off mode. I just turned that option off.
I got a great deal, so yeah.
The OPPO BDP-103D is the perfect complement for a 4K TV with its 4K upscaling, DVD interlacing, Darbee processing and ability to use it as a video processor for other sources.
miata is offline
Old 01-18-2015, 05:21 PM
Liked: 0
Model: Sony Bravia KD55X8505 LED 4K Ultra HD
Convinced By: My Research in various mags and online
Like it: 4K wow
Don't Like: Sony's instructions for stands
Features needed: has them all
Advice to Sony: Keep focusing on sound
Biggest surprise: Looks are stunnning
Problems or issues: none
Worth it:retail price 2100 got it for 1299
Additional info: I am overjoyed, its great
andrewtrudgett is offline
Sharp Aquos Lc42d62u 42 Inch 1080p Lcd Hdtv , Sony Bravia V Series Kdl 40v2500 40 Inch Lcd Hdtv
