OK! Your LCD! You Tell Me! Got a new one? post it here - Page 52 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1531 of 1546 Old 01-24-2015, 04:54 AM
8IronBob's Avatar
Quoted: 61 Post(s)
Liked: 24
1) The "Model" you have:
Sony BRAVIA KDL-55W950B 55" Ultimate 3D Smart LED-LCD TV
2) What convinced you to purchase this particular model:
Always wanted that Sony TV in the house, highest-end available in stock at the time, through store recommendation as well.
3) What you like best about your LCD:
Size of the TV, crisp picture quality, solid connectivity options, integration with other components.
4) What you don't like about your LCD:
Black levels could be a bit deeper outside of the "sweet spot" (although the initial firmware upgrade took care of it for the most part), not a 4K UHDTV (not an XBR), "Flick" remote could actually be a bit more responsive.
5) What "Feature(s)" you wish your LCD had:
A direct settings menu button, so I wouldn't have to travel through the "Home" Screen first, those big side speakers that the X900B has (although the HT-XT1 soundstand is great for making up for it).
6) What advice or suggestion would you make to the "Manufacturer" about your LCD:
I would certainly make better panel choices depending on how high-end the TV is. LG panels for the low-end, Sharp for the mid-range, and Samsung for the high-end/XBR range would be my suggestion. Albeit the LG panel is not AS bad in the W950B as it would be in some others models.
7) What was your biggest "Surprise" after you received your LCD:
Just how thin the bezel really is on the TV, how glossy the screen is, and just how big the screen is sitting in my bedroom.
Most certainly was built with the master bedroom in mind, imo.
8) What "Problems or Issues" have you had with your LCD:
Well, the PS3 I hooked up to it worked to start, then it seemed like the PS3 must have dropped the display connection to it, and the TV was complaining about not being able to display the INPUT. Perhaps it must be a bad HDMI cable, not sure, though. Other than that, haven't noticed any uniformity or significant black level issues with this, surprisingly. Nice overall set.
9) Do you really think that today's "Prices" are worth it:
Absolutely, if one is looking for quality in their 1080p or 4K TV, you should expect to pay a little more for that quality...albeit a lot of those TVs are on great sales now that they are rounding them up and ridding themselves of the 2014 models.
10) Any additional information that you wish to add:
I know there are those "naysayer" reviewers that claim that this TV suffers from those black level and uniformity issues, and I wish to tell them, please update your firmware on the TV, it WILL make a difference. I did so, and while the screen might not have SQUID INK black, it does, however, appear darker than the "out of the box" setting before I updated it. Also, it does seem to dazzle with SDTV signals, watching some direct cable on it, I really love what quality comes forth with it. I really have nothing too negative to say about it. It's not an XBR, nor 4K UHDTV, but for a 1080p, this seems to have more pros than cons.
Living Room: Samsung UN46A750 46" ToC 1080p, Yamaha HTC-6160 AV Receiver, JBL Cinema 480 5.1 Speakers, Magnavox HDD/DVD Recorder, Scientific Atlanta Explorer 8300HD.
Master Bedroom: Sony KDL-55W950B 55" 1080p, Sony HT-XT1 Soundbar, Xbox One, Scientific Atlanta 8300HD
Basement: Toshiba 32TL515U 32" 1080p 3DTV, PlayStation 3, Xbox 360, Bose Companion II Series 2 2.1 Speakers, Panasonic DMR-EZ28 DVD Recorder
8IronBob is offline
post #1532 of 1546 Old 01-27-2015, 06:10 AM
Rezman's Avatar
Liked: 0
1. The "Model" you have.
LG 65UB9500 - 65" UHD 4K SMART 3D LED TV W/ WEBOS (Replaced Vizio XVT553SV 55" LED 1080p 240Hz Smart)
2. What convinced you to purchase this particular model.
Picture, Sound (Harmon-Kardon speakers built-in) and price point (and the fact that it's not a Vizio)
3. What you like best about your LCD.
Picture, Picture, Picture. Holy moly is this thing beautiful.
4. What you don't like about your LCD.
Not digging the "magic" remote so much. If they'd made it a little bigger with a real number pad and a few more physical buttons I'd be happier.
5. What "Feature(s)" you wish your LCD had.
The ability to output audio to headphones while still using internal speakers. My father has slight hearing loss so he bought a set of "TV Ears" wireless headphones to use when he's visiting. So far I haven't been able to get these to work and still have the audio on for everyone else.
6. What advice or suggestion would you make to the "Manufacturer" about your LCD.
Maybe add a traditional remote along with the magic remote, and a firmware fix for the audio issue above.
7. What was your biggest "Surprise" after you received your LCD.
Seamless integration to my home network, it immediately picked up my XBMC server, and it's able to play huge mkv files over WiFi without missing a beat. Additionally, the 2D-3D conversion is incredible. We watched Winter X-Games and football with it on and you really feel like you're in the action.
8. What "Problems or Issues" have you had with your LCD.
When I added some new files to my XBMC server, I had to restart the server for the TV to show the new files. Should be an option to refresh or rescan the directory.
9. Do you really think that todays "Prices" are worth it.
Prices at the new model year are outrageous. As much as a decent used car is crazy. I specifically waited until after CES 2015 to pick up a 2014 model at half the original MSRP.
10. Any additional information that you want to add is encouraged.
Rezman is offline
post #1533 of 1546 Old 03-23-2015, 04:27 PM
Liked: 0
Cool
1. Sony KDL-55w800B
2. It was on sale at Futureshop and it had excellent reviews from almost every website I visited; best sub-$1000 55" LED TV I could find
3. Size, picture quality and thinness
4. There are too many settings and adjustments; I have to wait 30-40 seconds after turning on the TV before I can access the menu settings
5. I'm a beginner TV enthusiast so I'm not sure how to answer this one
6. I would suggest to make it easier to unbox the TV. I had to grip both sides of the TV fairly hard to lift it out of the styrofoam. It's only after reading the manual do I understand that this is bad for the TV.
7. The consistent picture quality
8. ECO mode seriously dims the TV and it's in a diff. part of the menu to turn off
9. Considering what you get for $1000, I think today's prices are amazing
10. Have a great day everyone!
Originally Posted by vegout View Post
Just got a new LCD Flat Panel? Post it here ONLY. Please do not post projection models.
Tell me the following:
dutd33 is offline
post #1534 of 1546 Old 04-04-2015, 09:45 AM
Gary61's Avatar
Vizio E40-C2
Price
Remote
Be able to play .mkv files and more HDMI ports
Support .mkv files.
Picture quality compared to my last TV
None
Yes
Gary61 is offline
post #1535 of 1546 Old 04-09-2015, 06:38 AM
GatorDave's Avatar
New Samsung 65HU8550 owner here. Looks like I lost the panel lottery with a QS04, but it still looks great to my eye. And since I won't be using it for PC gaming, and I'll never know the difference anyway.
GatorDave is offline
post #1536 of 1546 Old 04-10-2015, 07:29 AM
Liked: 0
I just purchased a Element 55 inch 4K HD LED from Target...clearing them here in Canada as they are cloasing.
My issue is that when watching a hockey game, there is a treak behind the players when they are moving fast. (Just like when the Flash runs on the TV show)
What could be causing this?
Thanks all
Gilles Belanger 2 is offline
post #1537 of 1546 Old 05-03-2015, 01:25 PM
Ov3rbyte's Avatar
Samsung UN50JU650DFXZA
I tried the HU6840 and had problems with flashlighting on the back panel so this was a newer model, had less issues in reviews. Also can rename HDMI inputs so that's also a plus.
Instant on is great, Wifi built in, and DLNA servers viewable as a source.
It doesn't support samsung's new smart remote.
I wish it supported the new samsung smart remote. Also wished that you could set favorites on the quick smart hub software like i could on the 6840. Also wish it was a true 120hz so I could get more frames out of PC games that I sometimes play on it.
Advertise it as 60hz native, quit lying to your customers about its refresh rate being 120 with Clear Motion Rates.
Didn't come with a IR remote extender.
None yet, had issues with the 6840 so I got this isntead.
Yes, I purchased a Sony LCD about 8 years ago for $300 more and it didn't have all the features that this one has.
I've tried the UN50HU6840 twice. Bought it at sam's club and had problems with the back light flash lighting in the corners. Thought it was a fluke on the first one so I returned it and got the same one. It was 55" and 100 bucks cheaper than my current UN50JU650DFXZA. But i'd rather have no problems with the TV.
Ov3rbyte is offline
post #1538 of 1546 Old 09-13-2015, 11:37 AM
Liked: 0
Samsung UN32J5003AFXZA
Good price for size and picture quality.
Picture Quality.
The sound is not the greatest.
Wish it had a headphone Jack.
Cut it out with the panel lottery.
How well it works as a PC monitor.
None so far
For the most part yes. A TV like this would have cost a lot more a few years ago. However, since it is not a smart TV it should probably be priced a little lower.
Be careful when buying that your getting one with a Samsung Panel. The version that has them is TS01.
fidelis1 is offline
post #1539 of 1546 Old 10-14-2015, 02:25 PM
Gold Ranger's Avatar
Liked: 1
Send a message via Skype™ to Gold Ranger
Vizio
E-Series
E500i-B1
My previous TV died.
I was in a rush. I thought I did enough research into this new one...
The Screen Size
Everything else.
The Colours are terrible.
The Reds and Whites are always blown out.
The Blacks are always crushed.
No setting has been able to fix it!
Better colour
Use better tech!
That the colours were very bad.
Just the colours.
No.
Do NOT get a Vizio save up a little longer and get something much better!
Looking to purchase:
- Jaws DigiBook
- 300 DigiBook
Gold Ranger is offline
post #1540 of 1546 Old 10-19-2015, 05:41 PM
jnnt29's Avatar
Quoted: 95 Post(s)
Liked: 121
Samsung UN65JS8500
My Panasonic 65VT60 died out
The overall picture when watching head on
Off center viewing
better off center viewing
add the number buttons to the remote
How cool it runs compared to the Plasma.
just the washed out picture when off center
Not really..
I would have loved an OLED, but they are too pricy and this TV was above what I wanted to pay. I was hoping to have my Panasonic for years to come, but it was not to be
My set up
Marantz SR-7008, Emotiva XPA-3
Samsung UBD-K8500 Ultra 4K Blu Ray Player
Klipsch RB-81II, RC-52II, Boston Acoustics Micro 120s
Klipsch SW-310, RPW-10, Samsung UN65JS8500FXZA
http://www.avsforum.com/avs-vb/showthread.php?t=1227096
jnnt29 is offline
post #1541 of 1546 Old 12-07-2015, 10:44 PM
testing123's Avatar
Liked: 0
Samsung 55JU7500
Flat panel review sites and my TV repair guy who favours Sammys and LG. This model is an excellent balance between price and quality.
Outstanding display, ease of operation, unique styling, low input lag, simplified remote.
Nothing so far that hasn't been corrected via settings.
Perhaps a custom mode setting for the user.
Too early to tell.
Great picture right out of the box. Darker blacks and better contrast than my previous plasma set.
Screen darkened occasionally in Standard mode but okay now after an Eco mode reset. Removed the dreaded "soap opera effect" with Auto Motion, though it seems to actually help when displaying 3D and sporting events.
9. Do you really think that today's "Prices" are worth it.
In my case yes, since the set was below dealer's cost. Lots of good bargains this time of year.
As with any major purchase, do your research before taking the plunge.
"Technology is a word that describes something that doesn’t work yet." – Douglas Noel Adams
testing123 is offline
post #1542 of 1546 Old 03-25-2016, 02:17 PM
tortoise's Avatar
Replaced my sony 34 xbr 960 today with a sony 65 xbr 950b. I'm hoping to get a similar quality picture with the benefit of greatly increased size. The 34xbr goes to my daughter and son-in-law and it's still going strong. Now, to load the 200 lb. monster on the moving dolly and place the 65 on it's stand. Will have to wait for help from my son-in-law.
tortoise is offline
post #1543 of 1546 Old 03-27-2016, 12:25 PM
Des_Eagle's Avatar
Quoted: 41 Post(s)
V2016 Vizio P65
Combination of attractive price, great impressions from other users on here, and the attentive customer service.
The picture quality is incredible, and so far I'm digging the tablet remote and think it really is the way forward.
Little glitchy on the software side, and I got a dud as well . Will be having it exchanged.
Honestly none, could always use more zones, etc. but for the price it is perfect.
I would include a much more extensive manual on the tablet at least, there seems to be very little information about the TV at the moment.
Watching Dolby Vision for the first time was honestly a mindblowing experience.
Well there is a yellow cloud on black screens, but it seems this was a defective unit and I will have it replaced.
For this TV? Of course.
BUY THIS TV
Des_Eagle is offline
post #1544 of 1546 Old 03-28-2016, 07:54 AM
quattroG's Avatar
LG 55UF6450
The price of a last years model 4k LED, and my love for my other LG 55LM7600 3D 1080p LED. And LG's picture quality.
It's a 4kUHD tv for the price of a HD 1080p tv.
Nothting yet.
I wish it was a 240 refresh instead of a 120.
I would include a much more extensive manual.
The speed of the using the smart features. My other smart tv's are relatively slow compared to this one.
None so far. Only owned this for a few weeks.
For this TV? Of course. (55" 4k for $650.00 at BJ's wholesale club)
If you want a 55" or above, you pretty much are going to have the biggest selection in 4k now. And this one was priced like a 1080p.
quattroG is offline
post #1545 of 1546 Old 04-08-2016, 06:29 AM
CBRworm's Avatar
Post Sony 55X850C
Sony 55X850C
I was looking for a really good 1080P set to replace a working Panasonic 50" 1080P Plasma. It appears from reading the entire internet that you cannot get a really good 1080P TV any longer (I could be wrong). I initially bought a Samsung JS8500 that had really bad light bleeding on both sides (really bright bleeding!). Also was unimpressed with the black level and wanted a TV with a high native contrast ratio - didn't want to spring for OLED yet. I was leaning towards the X810C but when I saw them both in person the X850 looked better in every way.
The picture quality is truly awesome if you are within about 5 degrees of the center of the set and more than 6 feet away. 4K sources look really amazing. I had no interest in a smart TV, but I am finding it interesting and somewhat useful.
If you are not in the sweet spot, everything gets washed out.
FALD would be nice. After owning it for a while, I guess a good IPS panel might be more useful despite the worse black levels.
More consistent quality. Mine has no bright or dark spots, no defects of any sort that I can see, but it seems that a lot of people are not so lucky.
How poor the picture quality is compared to my Plasma. There is nothing I can do to make the plasma look bad short of changing color settings drastically. This LCD, despite being calibrated, does not look as good with normal 1080i and 1080p sources. Skin tones especially are either too yellow or too red - or a combination of both. This TV looks great until you look at the plasma.
None
I'm not sure. I paid twice as much for a 40" 1080P Sony in '06 which still works. In all but the darkest rooms the old Sony looks better. I think for the money you are getting a lot of real estate now as well as a lot of features. I expected the new set to blow away the old set in a dark room as well as a bright room, so I was disappointed, but the defective Samsung I tried first was more expensive and seemed to perform worse. I think being able to buy a reasonably good 55" 4K tv for less than $1,200 is probably a pretty good value.
This TV looks great on the wall, until you look at the X900 series, but compared to my plasma which dimmed the lights in the house during bright scenes and would heat up the room, this TV is very slim and economical. If I didn't have the plasma to compare the picture quality to I am sure I would think this set is great.
CBRworm is offline
post #1546 of 1546 Old 04-08-2016, 10:52 AM
Liked: 3
2015 Vizio M Series UHD - M50-C1
Upgraded from a 42" 1080P TV I bought last June, the floor model was in perfect condition and I basically stole it for $440 with tax.
The picture quality is ridiculous, everything looks so good, even SD television looks good. I also really enjoy the design, the thin bezels, the gunmetal on the outside. I also love the 5 HDMI ports
I don't like that it's not an LG OLED TV
Honestly, I'm not too sure what I don't like about it other than the fact that the native Youtube App doesn't support 4K (but I hook my Macbook Pro up to it so that doesn't bother me)
None really, it's perfect for me, I use Chromecast and can hook up my computer as stated so I don't necessarily NEED the Smart TV features.
Just keep improving picture quality. KEEP the 5 HDMI ports, slim the bezels even more, etc etc.
How great the How To Train Your Dragon 2 Blu Ray looked, that's one of my favorite movies, and it looks astounding.
None so far
It was an $800 TV I got for $440, I can't honestly say haha.
I'm not quite sure I have any additional information to add, other than that if the legs are too wide, you can always buy a TV mount stand on Amazon which brings them closer to the center and allows you to raise and lower the height of the TV by remounting the stand to the VESA mounts.
teejayiscool is offline
Reply LCD Flat Panel Displays
Sharp Aquos Lc42d62u 42 Inch 1080p Lcd Hdtv , Sony Bravia V Series Kdl 40v2500 40 Inch Lcd Hdtv
taboola here
