Vizio 37" (VX37L) LCD HDTV Official Thread - Page 85 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #2521 of 2532 Old 02-04-2011, 04:14 PM
George5D's Avatar
Maybe a reset would be a good place to start? George
George5D is offline
post #2522 of 2532 Old 02-04-2011, 09:08 PM
SQKid89's Avatar
thanks for the replies.
no changes to sources or inputs and reset a few times, no change
Yamaha RX-V661
Oppo DV-970HD
Curt's TriTrix LCR, Zaph's B3S rears
Vizio VX37L
Xbox 360 w/ HD-DVD, Wii
SQKid89 is offline
post #2523 of 2532 Old 02-05-2011, 09:04 AM
gayle28607's Avatar
Have you tried to change the color, saturation, and brightness settings? I've usually done this with just the THX optimizer that comes with Finding Nemo - or another similar movie? (I can't remember which ones, but searching here will give you the names of DVDs that have this. It's on common DVDs.)
You might try this before, as you say, you spend more money on the TV. Here's hoping you'll find a simple solution!
gayle28607 is offline
post #2524 of 2532 Old 04-19-2011, 07:22 PM
amave's Avatar
I have had my Vizio VX37L for about 4 years now and am having problems with the HD channels.
My HD channels in the lower ranges do not show up, the SD channels work fine , i tried a different HD tv on the same coax cable and the HD channels work fine on that tv.
Do these tvs have problems with the HD tuner?
amave is offline
post #2525 of 2532 Old 04-19-2011, 09:47 PM
philherz's Avatar
Are you saying it's worked fine for 4 years, nothing changed, and now it's having a problem???
DirecTV Amherst, NY
philherz is offline
post #2526 of 2532 Old 04-19-2011, 10:02 PM
karrank%'s Avatar
Who's your provider, how do you get your TV signal?
karrank% is offline
post #2527 of 2532 Old 04-22-2011, 12:30 PM
viziodood's Avatar
Have you tried resetting the channel search feature, once in a while i lose a couple of HD channels and doing this locks them in again. Oh btw i've had my VX37L for about 4 years also, and knock on wood it's been working perfectly never a problem. Even though it's a 720P LCD i just love this tv, haven't had a need to replace it just yet. OTA HD channels and blu-rays look great on it, i plan on keeping it till it dies.
viziodood is offline
post #2528 of 2532 Old 05-07-2011, 02:54 AM
buntfu's Avatar
Through many threads, suggestions, trial an errors, days, weeks, months and now years of testing I believe I have found the ideal settings to get the most out of the Vizio VX37L.
Backlight = 0
Brightness =49
Contrast = 39
Color =40
Tint =0
Sharpness = 3
Color Temperature = Red =150 Green =146 Blue =114
Advanced Video:.
DNR = Strong
Black Level Extender = On
White Peak Limiter = On
CTI = Strong
Flesh Tone = Off
Adaptive Luma = On
Sound Settings:.
The speakers are ok but don't push them I usually leave them on 50/50 treble and bass with surround on. Sometimes it might be better to have the treble slightly higher than the bass to hear voices better. Room conditions play a big role.
Some posts say to turn off all the special features. I have found not only do they do a good job adding a little extra boost to this tv but also I feel like why not this TV is getting older now and needs all the boost it can get to keep up. To fully understand what these special features do read your manual or online here.
I've stuck by these settings religiously after discovering them over time. I thought even though this tv is older now I'm sure there is lot of them out there. These are the settings you should at least try. Hope they work out for you like they have me.
I use these settings on all input modes and in any lighting conditions. Seems to be the best overall settings for this television.
FINAL TIP:. Anything you hook up to this television, games systems, satellite, cable, etc etc make sure to use the native resolution of 720p. This TV is capable of 1080i however you sacrifice performance and quality to achieve it. It simply performs betters at its native 720p.
Ronnie
buntfu is offline
post #2529 of 2532 Old 05-16-2011, 06:31 PM
dougtv33's Avatar
vizio vx37l if there is text on the screen and scene changes to one with no text an after image of text remains for about 30 seconds. Image is ghost of previous text. DOM 08/2007 VX37L HDTV10A
dougtv33 is offline
post #2530 of 2532 Old 11-26-2011, 11:06 PM
skrapps's Avatar
a couple of months ago, i had my mainboard repaired because the tv would sit on a black screen and no sound or image would show
once i put the board back in, the tv turned on, but now the image will not stay put, it flips as if the horizontal hold is screwed up and i dont know how to keep it still. it seems it would stay still if the picture was bright.
it is capable of showing an entire picture, so i dont think its the backlight
i tried posting videos and urls, but this is my first post and it will not let me.
does anyone know what this issue may be?
skrapps is offline
post #2531 of 2532 Old 11-01-2012, 10:51 AM
tvdavid666's Avatar
Does anyone have a copy of the VX37L service manual? It's not available from pctechsva.com any more. I have the older LSPACAG version if it matters. Thanks!
tvdavid666 is offline
post #2532 of 2532 Old 11-01-2012, 11:49 AM
gayle28607's Avatar
I don't have a service manual, but have the manual that came with the Vizio VX37L10A. Is that something you are looking for, or too basic?
Reply LCD Flat Panel Displays
