Sharp LC-40C32U PC connection issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-07-2006, 05:16 PM - Thread Starter
ryder1650's Avatar
I have a Sharp LC-40C32U that I got from Costco.
I have my PC hooked up to it via DVI. When I select my output resolution as 1360 x 768 (native res for screen), the TV sees it as 1024 x 768 which distorts the whole picture. If I output at 1280 x 720 the proportions are fine but there is a massive amount of overscan (at least 1-2 inches are chopped off all around). Is there something else I need to do?
ryder1650 is offline
post #2 of 4 Old 11-22-2006, 09:44 AM
cyornaya's Avatar
Hey ryder1650: in case you are still looking for info, here is what I have done.
Connected my PC using DVI cable to the DVI input (#5) on the LC-40C32U.
I have set my PC graphics card resolution to 1360x768.
From the Sharp menu -> options -> input signal, set the signal to 1360x768. Getting the display fine, no overscan.
My graphics card is a PNY GeForce FX5700, and I am using the latest NVIDIA Forceware drivers downloaded from the NVIDIA website.
Hope this helps.
cyornaya is offline
post #3 of 4 Old 12-10-2006, 07:54 PM
floepie's Avatar
@ cyornaya,
I'm pretty much settled on this Sharp. Question: When changing the input from, say, a HDMI-connected STB to the computer via the DVI input, do you have to go into the menus each time to adjust the input signal? Or, is that a one-time setup?
floepie is offline
post #4 of 4 Old 12-10-2006, 08:23 PM
cyornaya's Avatar
Its a one-time setup. The TV had dedicated memory for each input, and so the signal type gets automatically adjusted when moving from input to input.
cyornaya is offline
Closed Thread LCD Flat Panel Displays
