OLEVIA 32" 2 Series LCD HDTV (232V) - Page 50 - AVS Forum | Home Theater Discussions And Reviews
post #1471 of 1490 Old 08-23-2013, 07:36 PM
Hate8's Avatar
Thanks for the reply. I have tried about twenty different resolution/Hz combinations. This is a known issue with the Olevia TV that some people say was fixed in a firmware update before the company went bankrupt and shut down its support sites. Unfortunately, I didn't get the firmware update. I had connected the TV to my Vista machine in the blind by memorizing where to move the mouse on a blank screen to select HDTV/720P standard mode (the only one that works without the upgrade), but on windows 8 it is too many steps to perform blind. If I can find someone who saved the firmware update (later than 17C) it should fix the problem.
Thanks again for you time.
Hate8 is offline
post #1472 of 1490 Old 01-19-2014, 10:39 PM
lastin1's Avatar
Does anyone have the latest firmware for the 232-S12?
lastin1 is offline
post #1473 of 1490 Old 04-12-2014, 11:43 AM
akatrauma's Avatar
I am also looking for the 232-S12 firmware too. I think I have a corrupt firmware, I can't get past the white/blue startup screen. Help! thanks in advance.
akatrauma is offline
post #1474 of 1490 Old 09-04-2014, 03:13 PM
Liked: 0
I have this TV also, i purchased it from my boss at work for 50$ works great.
I needed a cheap TV to use in my haunted house and this has been working good, but i have a question and i hope there is an answer.
I am using a trigger able video player with this TV. when the video player is not triggered it loops a video file over and over, then once the unit is triggered it plays the video, the problem i am having is the on screen display! every time the player is triggered [COMPONENT] shows up real big in the top right corner. I have been through the menus and i just can't find a way to turn this off. Is it even possible to switch off? i really hope so. If anyone has any info i would really appreciate it, trying to figure this out because I'm running out of time, halloween is creeping up!
you can email me at frightmare@atlanticbb.net
sorry i joined this forum today just to post this but i ran out of ideas.
.saint is offline
post #1475 of 1490 Old 09-28-2014, 03:09 PM
Liked: 0
Olevia 232-s13
Hi everyone,
I too am having an issue with finding the actual firmware update for my 32 inch TV. Every link I found so far on this forum is taking me to a spam ware type of download place that requires me to get a download manager. If anyone has the updated firmware for the Olevia 232-s13 TV i would greatly appreciate it being send to me., or a real link. I am new , so it will not let me put my e-mail address.
Thanks for any help,
Eric Romig
Eric Romig is offline
post #1476 of 1490 Old 11-18-2015, 05:33 PM
Syrinx111's Avatar
Originally Posted by Eric Romig View Post
Hi everyone,
Eric Romig
Does anyone out there have firmware for the 232-S12?
Syrinx111 is offline
post #1477 of 1490 Old 11-19-2015, 07:48 AM
romeyn's Avatar
I have a file named 232_A33-5-2.zip. If that's the latest, you're welcome to it.
romeyn is offline
post #1478 of 1490 Old 11-19-2015, 01:22 PM
Liked: 0
Yes please I would like the file. Can you drop the file here for all to dl, or pm me on how else to get it from you. Thank you.
xlenduroman is offline
post #1479 of 1490 Old 11-19-2015, 02:21 PM
Syrinx111's Avatar
PM sent!
post #1480 of 1490 Old 11-19-2015, 05:15 PM
Liked: 0
hi smoke_ring i also have Olevia 232-s13 /fm1-032000EGS55 s/n: vclk75282185
im running firmware version a34-10la20.pm24l.adx.t30
i have many hdmi issues, do you have the latest or newer firmware that would work with my tv?
tallpr24 is offline
post #1481 of 1490 Old 11-19-2015, 05:19 PM
Liked: 0
tallpr24 is offline
post #1482 of 1490 Old 11-19-2015, 05:20 PM
Liked: 0
i also have Olevia 232-s13 /fm1-032000EGS55 s/n: vclk75282185 im running firmware
I also have Olevia 232-s13 /fm1-032000EGS55 s/n: vclk75282185
i have many hdmi issues, do you have the latest or newer firmware that would work with my tv?[/QUOTE]
tallpr24 is offline
post #1483 of 1490 Old 11-19-2015, 05:21 PM
Liked: 0
tallpr24 is offline
post #1484 of 1490 Old 11-19-2015, 05:22 PM
Liked: 0
tallpr24 is offline
post #1485 of 1490 Old 11-19-2015, 05:23 PM
Liked: 0
i also have Olevia 232-s13 /fm1-032000EGS55 s/n: vclk75282185 im runniv
tallpr24 is offline
post #1486 of 1490 Old 11-19-2015, 05:23 PM
Liked: 0
i have many hdmi issues, do you have the latest or newer firmware that would work with my tv? my email is spiderman1978@gmail.com
tallpr24 is offline
post #1487 of 1490 Old 11-19-2015, 05:24 PM
Liked: 0
i also have Olevia 232-s13 /fm1-032000EGS55 s/n: vclk75282185, not sure what to do here
tallpr24 is offline
post #1488 of 1490 Old 11-19-2015, 05:30 PM
Liked: 0
tallpr24 is offline
post #1489 of 1490 Old 11-19-2015, 07:53 PM
Liked: 0
411!!!
Use the first link in post #1455 of this thread to dl the 19L and 26L firmware for the Olevia 232-S13.
Use the link at the bottom of post #1435 of this thread for the update instructions.
I downloaded the files and upgraded from 10L to 19L today and my HDMI FINALLY works!
Remember......Make sure your TV uses the "L" and not the "C" version firmware and it should work for you as it did for me.
Good luck all!
post #1490 of 1490 Old 11-20-2015, 07:22 AM
romeyn's Avatar
romeyn is offline
Reply LCD Flat Panel Displays
Olevia , Lcd Hdtv
