37" to 42" Plasma or LCD with Digital Audio In??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-29-2006, 04:13 PM - Thread Starter
tommylotto's Avatar
I have been searching for this awhile and have not been able to find one. I figure the guys on this board will know if it exists.
I'm looking for a 37" to 42" display that has optical or coaxial digital audio input. There are plenty of displays that accept digital audio through HDMI, but I need optical or coaxial.
I am distributing the video signal to multiple locations over cat 5 cable using baluns. I have found a single balun that can carry the three component cables plus digital audio over a single cat 5 run. Analog audio would require another set of baluns and another run of cable. That is why I'm looking for a display that accepts digital audio.
Thanks for any help.
tommylotto is offline
post #2 of 4 Old 11-29-2006, 10:00 PM - Thread Starter
tommylotto's Avatar
Have I stumped you guys?
post #3 of 4 Old 11-29-2006, 10:02 PM
c5chris's Avatar
My 42" Vizio Plasma has optical in.
c5chris is offline
post #4 of 4 Old 12-01-2006, 04:16 PM - Thread Starter
tommylotto's Avatar
Thanks, but I'm pretty sure that is an optical out from the internal tuner, not an optical in.
Closed Thread LCD Flat Panel Displays
