Which 26" LCD ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-01-2006, 09:42 AM - Thread Starter
kjfox's Avatar
I know most of this forum is dedicated to the larger LCDs. I am in the market for a 26" LCD for the bedroom. I believe I would like to stick the the following brands Sony, Samsung and Sharp. Looking for opionions from various users. I think I have the following models in mind and help would be appreciated:
Sony KDL-26S2010
Samsung LN-S2652D
LN-S2652D
LN-S2651D
LN-S2641D
Sharp LC-26D40U
Have I missed any? I imagine members have done this research before, and I value user opionions more than a salesman. Whcih TV would you vote for?
kjfox is offline
post #2 of 7 Old 12-01-2006, 12:20 PM
Boozie565's Avatar
i have that samsung lcd...the white version...beautiful set.
Boozie565 is offline
post #3 of 7 Old 12-01-2006, 12:40 PM
DanielCard's Avatar
New products will be available in January:
http://www.dailytech.com/article.aspx?newsid=5159
DanielCard is offline
post #4 of 7 Old 12-01-2006, 02:12 PM - Thread Starter
kjfox's Avatar
Can anybody tell me the difference between the following two Sony models:
KDL-26S2000 and the KDL-26S2010 ?
kjfox is offline
post #5 of 7 Old 12-01-2006, 02:21 PM
hitssquad's Avatar
If you choose the Acer, which has a resolution of 1920 x 1200, you will be able to use it as a computer-monitor up close.
hitssquad is offline
post #6 of 7 Old 12-01-2006, 02:58 PM
MrHicks's Avatar
A friend has the Samsun, I was amazed how clear it really was.
MrHicks is offline
post #7 of 7 Old 12-01-2006, 04:09 PM
thebard's Avatar
Quoted: 86 Post(s)
Liked: 50
I have the Samsung, & I am very happy with it for the most part. Other models I considered were the Philips (looked good on paper, but low refresh rate = lousy picture quality) and the Sony KDL. The Sony is actually a pretty nice set, but one thing that steered me away from it was the connection layout. If you plan on running RF into it at all, the only hookup is on the SIDE! I didn't see the point of getting a sleek new LCD panel, only to have a big ol' honkin' cable sticking out the side. All the connections on the Samsung are well placed on the back, with dual component ins, and even a built-in cable tie to keep 'em out of sight.
Plusses with the Samsung:
- Good input selection & layout
- Looks nice, speakers out of sight
- Great, crisp picture for the money
Drawbacks I've found with the Samsung:
- No HD tuner (not a problem for me as I use my cable provider's signal).
- No discreet input selection (this means you toggle or menu through input sources, so if you're using a universal remote, you can't use a macro to automatically select the input source).
Hope that helps,
David
Projectors: Where there's a wall, there's a way.
http://www.avsforum.com/forum/110-di...een-build.html
thebard is offline
Closed Thread LCD Flat Panel Displays
