Any 32" 1080p LCD's? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-01-2006, 06:43 PM - Thread Starter
Stankia's Avatar
Quoted: 20 Post(s)
I'm planing to buy a LCD that I could use as a PC monitor and as a TV. The 37" sets I think are a little to big for working with my PC.
Stankia is online now
post #2 of 10 Old 12-01-2006, 08:20 PM - Thread Starter
Stankia's Avatar
Quoted: 20 Post(s)
bump
post #3 of 10 Old 12-01-2006, 08:27 PM
doogiehowser's Avatar
I was told by a salesperson that the human eye can not tell the difference between 720p and 1080p if the screen is smaller than 42". I don't know if it is true. He said the only way to see the improved picture quality of 1080 was to increase the size of the screen.
doogiehowser is offline
post #4 of 10 Old 12-01-2006, 08:28 PM
CrashIV's Avatar
If there was a 32" TV that could display 1080p on it, the extra cost would be pretty much worthless. On a screen that small I'd doubt you would be able to the the different between 1080i and 1080p unless you're sitting about 5 inches from the screen. Even then the difference would be extremely small.
CrashIV is offline
post #5 of 10 Old 12-01-2006, 08:34 PM
cash banquet's Avatar
not worth it, you would never be able to tell the difference on that small screen
PSN: Edgecrusher
cash banquet is offline
post #6 of 10 Old 12-01-2006, 08:49 PM
DanielCard's Avatar
Yes, you can easily tell the difference you just have to sit closer.
DanielCard is offline
post #7 of 10 Old 12-01-2006, 08:54 PM - Thread Starter
Stankia's Avatar
Quoted: 20 Post(s)
Yeah, I know that it's not worth it for a TV, but 1080p looks awesome on playing games with my PC or PS3. And most of the time I would use this screen for my PC, I watch TV about an hour per day.
I tought about the new BenQ 24" Monitor with 1920X1200 resolution.
http:\\\\http://www.newegg.com/Product/Produc...82E16824014124
But it streches all singlas to 16x10 format, and with 24 inches it's probably to small, because my bed is about 15 feet away from my desk :(
post #8 of 10 Old 12-02-2006, 09:32 AM
DanielCard's Avatar
Originally Posted by Stankia
I thought about the new BenQ 24" Monitor with 1920X1200 resolution.
You'll be happier with the 27" 1080p that is coming in January. Perhaps 32" 1080p will come out then also.
http://www.dailytech.com/article.aspx?newsid=5159
Alternatively you might prefer a 37" 1080p. Weird that we have 1080p above and below 32" but no 32" 1080p.
post #9 of 10 Old 12-10-2006, 04:15 PM - Thread Starter
Stankia's Avatar
Quoted: 20 Post(s)
any ideas what should I get?
post #10 of 10 Old 12-10-2006, 04:16 PM
dallas27's Avatar
Quoted: 16 Post(s)
ya, it's called a monitor though, not a tv.
dallas27 is offline
Closed Thread LCD Flat Panel Displays
