Samsung VGA quality, 40inch LCD, why no DVI? - AVS Forum | Home Theater Discussions And Reviews
Old 12-01-2006, 07:32 PM - Thread Starter
pagusas's Avatar
Quoted: 44 Post(s)
Liked: 49
Im thinking of getting the samsung 40" 1080p screen, and was disapointed to see it had no DVI input, instead it had a VGA in. IS the quality noticeably worse via VGA? Why did samsung drop DVI support?
pagusas is offline
Old 12-01-2006, 08:22 PM
szys2002's Avatar
Quality over VGA is great, it is very much HD capable.
However, HDMI is backwards compatible to DVI so you can buy a simple DVI-HDMI adapter or DVI-HDMI cable to connect your TV.
szys2002 is offline
Old 12-01-2006, 10:04 PM - Thread Starter
pagusas's Avatar
Quoted: 44 Post(s)
Liked: 49
I understand that HDMI is backwards compatable, but i had heard that the TV overscans sources on HDMI, which is awful for PC display. Basically i will be using the set mainly as a monitor, and i've heard VGA starts falling apart at such resolutions.
pagusas is offline
