42" LCD. why does wide screen have the black bars? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-10-2006, 12:03 PM - Thread Starter
vettegofast's Avatar
I have a 42" lcd hd widescreen TV. My DVD player is set to 16:9. I am playing a widescreen DVD and theres still black bars on the top and bottom of the screen. I thought that would go away with a Widescreen TV. Please help me figure this out! Thanks.
vettegofast is offline
post #2 of 4 Old 12-10-2006, 01:17 PM
fireballz's Avatar
there's a bunch of topics on this. Here's one i found:
click
good luck.
fireballz is offline
post #3 of 4 Old 12-10-2006, 01:18 PM
Melon Jr's Avatar
It depends on the film itself there are a few different ratios. Here is what board member lmacmil said on the issue in another thread.
Somewhere on the back of the DVD box it will tell you what the widescreen format is. Many of the action movies are filmed in 2.35:1 which is the ratio of a wide theater screen. Some movies are filmed at 1.85:1 which is so close to 16:9 you might not notice. Once you get into the movie, you shouldn't notice the black bars.
Melon Jr is offline
post #4 of 4 Old 12-10-2006, 02:28 PM
RDO CA's Avatar
Try playing with the diff settings on this site and I think it will become clear to you
Roy
http://www.tvcalculator.com/
Nothing is so firmly believed as that which least is known
RDO CA is offline
Closed Thread LCD Flat Panel Displays
