Looking for great LCD HDTV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-11-2006, 04:25 PM - Thread Starter
Any suggestions for a flatpanel LCD HDTV if the following are required --
37" to 42"
1920x1080 resolution
HDMI input supports 1080p60 (1080p24 support would be a bonus)
1:1 pixel mapping capability
great picture quality
Been doing some research, but my head is swimming...
kjack is offline
post #2 of 4 Old 12-11-2006, 05:06 PM
PRMan's Avatar
Try http://www.product4me.com/hdtv...
You can at least find the first four requirements (including LCD flat panel) easily enough.
PRMan is offline
post #3 of 4 Old 12-12-2006, 08:50 AM
TNG
TNG's Avatar
Lots of sets out there in that size range. Sony, Sharp, Samsung, Vizio, Mitsubishi, Toshiba, and the list goes on forever it seems.
Get out there look at sets, prices and narrow it down. After all was said and done, I bought a Sharp 1080p set for the PQ. Up close the Sony was better side by side, but I don't view my set from 3' distance. I think the XBR sets trim looks awesome, but there was a price premium that Sony attached to their sets as well, so Sharp it was.
Also the SD was better with the Sharp than the Sony or Samsung IMO. Since most of my watching is SD still, this was a large factor.
TNG is offline
post #4 of 4 Old 12-12-2006, 10:11 AM
bosng's Avatar
if you want 1:1 on vga and component the sony's are out
i heard the latest samsung firmware will get you 1:1 on vga and component.
i think all hdmi are 1:1. correct me if i'm wrong
bosng is offline
Closed Thread LCD Flat Panel Displays
