Olevia 32'' 432v help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-11-2006, 08:53 PM - Thread Starter
breakboy's Avatar
for some reason I can't change the brightness or inputs or any other options on my tv is their a problem or im i just stupid
breakboy is offline
post #2 of 3 Old 12-12-2006, 10:37 AM
Timmy390's Avatar
My guess is you have it set to “showroom†or “demo†(can’t remember what it’s called) which will not allow you to change anything. I ran into this while trying to change the settings at the store.
Go into the menu and change the mode to Home and that should free things up.
Tim
Timmy390 is offline
post #3 of 3 Old 12-12-2006, 04:00 PM - Thread Starter
breakboy's Avatar
kool thanks ima try right now
breakboy is offline
Closed Thread LCD Flat Panel Displays
