Newbie with LCD - SD Questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-31-2007, 11:41 PM - Thread Starter
Lil BG's Avatar
Hello boys and girls,
So I've been researching for 2 months now and just wanna pull the trigger.
I've been looking at the 40" Sony (V2500) and 40" Samsungs (4051/4092/4096).
The only thing is that I wish the Sony had PIP. My deciding factor really comes down to what processes SD better? I'm in Canada, so I'm not going to go HD til they add more channels.
My question is what LCD processes SD the best?Sony? Samsung? Sharp?
I'm looking at the 40-42" sets.
Any recommedations?
Thanks guys!
Lil BG is offline
post #2 of 4 Old 02-01-2007, 06:14 AM
adb
adb's Avatar
Depends on which Sony. The best model has a better processor according to my local Sony dealer. Having a set with a good scaler is a major key to watching SD and some sets have better scalers than others. Best bet is to go to a store where they will show you SD on the different models.
adb is offline
post #3 of 4 Old 02-04-2007, 08:12 PM - Thread Starter
Lil BG's Avatar
Thanks! I finally pulled the trigger and went with the V2500.
Lil BG is offline
post #4 of 4 Old 02-05-2007, 04:18 AM
Huckster's Avatar
So how did it look in the store when fed SD?
How did the others look?
Huck
Huckster is offline
Reply LCD Flat Panel Displays
