Articulating arm wall mount for 60"+ inch - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-05-2007, 05:28 PM - Thread Starter
Oasys's Avatar
I'm thinking about buying an articulating arm mount for 60"screen. I figured it'd be nice to simply pull the screen out while still hanging in the air and do any cable adjustments if necessary without unmount the whole TV out from a wall. Could you recommend the best brands and the models? Which one would be the most sturdiest articulating mount out there? Above all how safe are they? It'll be secured on a concrete wall so weak wood studs are not a problem for me. Would the TV be still wobbly even if the atriculating arm can support what it claim to hold?
In particular, I was looking at two models available from Costco that support up to 60".
Item # 969056 and Item # 126884
which one would you recommend the most?
Oasys is offline
post #2 of 4 Old 02-05-2007, 08:23 PM - Thread Starter
Oasys's Avatar
bump
Oasys is offline
post #3 of 4 Old 02-05-2007, 08:54 PM
ViperATC5's Avatar
Sanus VMDD26B
ViperATC5 is offline
post #4 of 4 Old 02-06-2007, 11:16 AM
khoyme's Avatar
I have a Chief Manufacturing PNR-U that can support up to 200lbs. This thing is built like a tank. This one articulates out about 24" -- they have another model that extends out over 35" as well.
Ken
khoyme is offline
Reply LCD Flat Panel Displays
