1000 Contrast ratio vs 1600 contrast ratio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-26-2007, 05:40 PM - Thread Starter
Bunga99's Avatar
Liked: 39
Is there a noticeable difference between say....1000:1 contrast ratio on a 42in LCD and 1600:1 contrast ratio on another 42inch LCD by the same brand/company. Or do you only see a difference when you upgrade to something like 5000:1 or even 10,000:1. Also does any of these produce BTB and WTW.
Any help is appreciated.
Thx,
Claude
Bunga99 is offline
post #2 of 5 Old 02-26-2007, 06:11 PM
bfdtv's Avatar
Different manufacturers measure contrast differently, so you have to be careful what you are comparing. One manufacturer's 1000:1 is another's 1500:1. In some cases, you can't even compare contrast ratios for products from a single manufacturer, because the company's marketing "tweaked" the way they measure.
No LCD panel now on the market can disable its light output to display blacks. Current LCDs output light on every pixel 100% of the time. Since black, by definition, is the absence of light, you can't get that color -- you can only get very dark greys. The difference between the today's better LCDs and the best LCDs is how dark the greys get.
The first LCD to deliver "true" blacks may be the upcoming Samsung 81 series with LED backlighting and local dimming. Local dimming technology enables the display to selectively disable the light source in darker areas of a scene to produce true blacks, and hence much higher contrast ratios. Check out the forum's other threads on this display, which looks to be the first of its kind (hence, $$$). One year from now, this technology should be standard on all the higher-end displays from the major manufacturers (Sony, Sharp, Toshiba, etc).
bfdtv is offline
post #3 of 5 Old 02-26-2007, 06:17 PM
emg7777's Avatar
No LCD panel now the market can disable its light output to display blacks. Current LCDs output light on every pixel 100% of the time. Since black, by definition, is the absence of light, you can't get that color -- you can only get very dark greys. The difference between the today's better LCDs and the best LCDs is how dark the greys get.
The first LCD to deliver "true" blacks may be the upcoming Samsung 81 series with LED backlighting and local dimming. Local dimming technology enables the display to selectively disable the light source in darker areas of a scene to produce true blacks, and hence much higher contrast ratios. Check out the forum's other threads on this display, which looks to be the first of its kind (hence, $$$); one year from now, this technology should be standard on all the higher-end displays from the major manufacturers (Sony, Sharp, Toshiba, etc).
ya sure know a lot of stuff
emg7777 is offline
post #4 of 5 Old 02-26-2007, 06:51 PM
Nmlobo's Avatar
JVC plans to introduce 120hz sets with LED backlights sometime this summer.
Nmlobo is offline
post #5 of 5 Old 02-26-2007, 06:57 PM - Thread Starter
Bunga99's Avatar
Liked: 39
Cool thanks for the info...Much appreciated!
Bunga99 is offline
Reply LCD Flat Panel Displays
