Still Can't Decide - AVS Forum | Home Theater Discussions And Reviews
Old 02-28-2007, 09:47 AM - Thread Starter
Neijii's Avatar
I'm still having a hard time deciding which LCD to buy. I need it for DVDs, xbox 360 and cable television as well.
I need a 40" + size and don't really want to go over 2500..what do you guys recommend?
Neijii is offline
Old 02-28-2007, 10:12 AM
phipp01's Avatar
Olevia 742i
phipp01 is offline
Old 02-28-2007, 10:13 AM
bfdtv's Avatar
How close do you sit? And what is the lighting in your room like?
bfdtv is offline
Old 02-28-2007, 10:16 AM
Nmlobo's Avatar
Jvc Lt-40FN97
Nmlobo is offline
Old 02-28-2007, 10:16 AM - Thread Starter
Neijii's Avatar
8ft...and there is lighting, unfortunately.
Neijii is offline
Old 02-28-2007, 10:22 AM - Thread Starter
Neijii's Avatar
The JVC had bad reviews on cnet..do you agree with those reviews?
Neijii is offline
Old 02-28-2007, 10:26 AM
Nmlobo's Avatar
You need to read the user's comments. I have not read the CNet review. I own the LF-40FH96 and love it!! I've owned it a year. As for reviews, CR identified it #1 (Mar 07) over Sony and plasmas, for displaying HD.
Nmlobo is offline
Old 02-28-2007, 10:30 AM - Thread Starter
Neijii's Avatar
O, ok, i'll read up on it, and how would you compare the JVC to the Aquos..bestbuy has the 42" on sale for $1800
Neijii is offline
Old 02-28-2007, 10:40 AM
Nmlobo's Avatar
I have not viewed the Aquos so do not feel 'qualified' to give you an opinion on that set.
You might read this article before you buy any set: http://www.hometheatermag.com/hookmeup/1106hook/ I don't know if the Aquos is addressed but it should provide some clues as to what to look for......
If you are interested, here is another on the JVC
http://www.tvpredictions.com/jvc40120106.htm
Nmlobo is offline
Old 02-28-2007, 10:48 AM - Thread Starter
Neijii's Avatar
Gonna check that link out right now..I also came across the Toshibs Regza..seems promising.
Neijii is offline
Old 02-28-2007, 11:02 AM - Thread Starter
Neijii's Avatar
The LC-46D62U Aquos is considered the new Aquos, i just read reviews and it seems improved compared to the others.
http://hometheatermag.com/lcds/207sharplc46d62u/
Neijii is offline
Old 02-28-2007, 11:15 AM
Nmlobo's Avatar
Good luck with your search
Nmlobo is offline
Old 02-28-2007, 12:46 PM - Thread Starter
Neijii's Avatar
Thank you, I have a problem with JVC, the past 2 tvs were JVC and they always had problems..
Neijii is offline
