~Official Olevia 747i/742i owners thread - Page 170 - AVS | Home Theater Discussions And Reviews
post #5071 of 5096 Old 06-23-2014, 07:42 PM
Liked: 0
I need a firware update for my 747i
I'm having green and pink squares within a minute or two after turning it on. Not sure if I need a firmware update or what not. Can anyone help me out please. Can anyone give me the latest firmware update or info please?!?! Anything helps. Thanks
Chris
Christopher Costa is offline
post #5072 of 5096 Old 06-23-2014, 07:45 PM
Liked: 0
Firmware update please for 747i
I need a Firmware update for my 747i please! Thanks
Chris
post #5073 of 5096 Old 06-24-2014, 07:07 AM
CombatTom's Avatar
Use at your own risk; follow the instructions in the manual for installing. This is version 63.7.5, which, as of a couple years ago, was the latest version (but it was old even then).
https://dl.dropboxusercontent.com/u/...47_V63.7.5.zip
CombatTom is offline
post #5074 of 5096 Old 07-09-2014, 09:45 PM
Liked: 0
I'm new on here. I don't know if this thread is still alive. But I've been having troubles with my 747-B11. Turn it on might have sound for hours or just mins. Turn off back on same thing most likely just mins. "When it does work it's only playing out of one speaker." I've never done a firmware... Idk if that'll help? But I love this TV and don't want to trash it. SO PLEASE HELP!!! Thanks in advance!
seeme07 is offline
post #5075 of 5096 Old 07-10-2014, 12:18 PM
rarjar's Avatar
Doubt firmware update will fix your problem, but it sounds like you have little to lose. Latest firmware link is a couple posts up!
rarjar is offline
post #5076 of 5096 Old 07-11-2014, 06:54 AM
dfs88801's Avatar
Quoted: 41 Post(s)
Registered DP 1.2a compatible screen
How is that possible?
Standard DP 1.2a emerged after Screen production
http://www.anandtech.com/show/8008/v...s-move-forward
Has anyone checked that?
dfs88801 is offline
post #5077 of 5096 Old 07-25-2014, 08:58 PM
jmeltzer's Avatar
Liked: 0
Late to the game...
Hi everyone,
I've had my Olevia 747i since 2007 and it is still working nearly flawlessly. My issue is, HDMI seems to have audio dropouts on PS4 and the only way to fix it is to unplug the hdmi cable and reconnect it.
I am attempting to update the firmware from 747-B11_v63.7A17 to 747_V63.7.5, but I am getting no where. The TV goes through the install and says no update needed. Do I have the most current firmware for this TV? Thanks in advance.
jmeltzer is offline
post #5078 of 5096 Old 07-28-2014, 11:37 AM
rarjar's Avatar
Originally Posted by jmeltzer View Post
Hi everyone,
It is my understanding that the firmware update will only update what needs to be updated. Assuming you are attempting to use Firmware Version 63.7.5 (the latest and last firmware update), if it shows "no update needed," then you have the latest firmware installed.
rarjar is offline
post #5079 of 5096 Old 07-28-2014, 11:56 AM
jmeltzer's Avatar
Liked: 0
Fair enough. Do you think it would be beneficial to reset to factory defaults or format the C or D drives through the Service Menu and re-installing the latest firmware? Or do you think it could just be the HDMI chip starting to go. Basically, it seems to happen when a device goes into standby through power save settings. If not, I'll just live with the occasional unplug/replug of HDMI cables.
Thanks for the reply either way Rarjar.
jmeltzer is offline
post #5080 of 5096 Old 07-28-2014, 11:59 AM
rarjar's Avatar
I have no idea about resetting to factory resets, however, I have a similar HDMI problem with an LG LED TV and LG advised me that a hard reset will often fix HDMI pairing issues, so on that basis, I think I would try the hard reset first.
rarjar is offline
post #5081 of 5096 Old 09-15-2014, 06:06 PM
gburfoot's Avatar
do you have the update program please have firmware thank you not install please help have 265 board have 747 tv please help tried for months any ideas how
gburfoot is offline
post #5082 of 5096 Old 09-15-2014, 06:19 PM
gburfoot's Avatar
do you have the update program please have firmware thank you not install please help have 265 board have 747 tv please help tried for months any ideas how @zoomin ternet.net
gburfoot is offline
post #5083 of 5096 Old 09-15-2014, 06:29 PM
gburfoot's Avatar
thank you
gburfoot is offline
post #5084 of 5096 Old 09-15-2014, 06:30 PM
gburfoot's Avatar
thank you again
gburfoot is offline
post #5085 of 5096 Old 09-15-2014, 06:30 PM
gburfoot's Avatar
just want to pm
gburfoot is offline
post #5086 of 5096 Old 09-15-2014, 06:31 PM
gburfoot's Avatar
just want to pm help please
gburfoot is offline
post #5087 of 5096 Old 09-15-2014, 06:32 PM
gburfoot's Avatar
just want to pm help please rarjar
gburfoot is offline
post #5088 of 5096 Old 09-15-2014, 06:33 PM
gburfoot's Avatar
just want to pm help please anyone else need help dont know what to post
gburfoot is offline
post #5089 of 5096 Old 09-15-2014, 06:38 PM
gburfoot's Avatar
can't up load firmware have no clue please help is there another program
gburfoot is offline
post #5090 of 5096 Old 09-15-2014, 07:24 PM
gburfoot's Avatar
please help with how to do and what i need 265 board 747 tv you sent bios but what else pullng hair help please you tell me list my email i will help other with same instructions and programs programs thank you again.
Garth
gburfoot is offline
post #5091 of 5096 Old 09-15-2014, 07:27 PM
gburfoot's Avatar
Garth
gburfoot is offline
post #5092 of 5096 Old 09-15-2014, 07:35 PM
gburfoot's Avatar
Hi everyone,
do you have firmware up date soft ware Gfaivre&zoominternet.net
gburfoot is offline
post #5093 of 5096 Old 09-15-2014, 07:40 PM
gburfoot's Avatar
please help with how to do and what i need 265 board 747 tv you sent bios but but need update software please help w gfaivre$zoominternet.net
Garth
gburfoot is offline
post #5094 of 5096 Old 09-22-2014, 02:57 PM
rarjar's Avatar
Garth, I sent you the latest firmware and instructions on how to update...or at least I think I did assuming your email is gfaivre@zoominternet.net
rarjar is offline
post #5095 of 5096 Old 11-26-2014, 11:23 AM
rarjar's Avatar
Chris
Chris, I doubt if it will help, but if you'll PM me your email, I'll send you the latest firmware. Instructions for updating are contained in post #5028 by S!TH!NATOR a few pages back.
rarjar is offline
post #5096 of 5096 Unread Today, 11:39 PM
Thud2's Avatar
RARJAR! I AM VERY SURE THAT DUE TO YOU OBVIOUS COMMITMENT TO THE OFFICIAL OLEVIA 747i OWNERS THREAD THAT DAD1153 (THE DEFACTO MAYOR OF THE OFFICIAL OLEVIA 747i OWNERS THREAD '') AND THE MANY CONTRIBUTORS TO OFFICIAL OLEVIA 747i OWNERS THREAD (including myself) WOULD AGREE THAT YOU, AT THIS POINT IN TIME ARE OFFICIALLY "THE MOST DEDICATED SUPPORTER OF THE OWNERS OF THE VENERATED "OLEVIA 747i TV THREAD AND THE OWNERS OF THE UNMATCHED OLEVIA 747. Plaese accept my most heartfelt thanks on behalf of the longstanding Olvia 747i Owners community. OY OY OY OY OY!!!
Thud2 is online now
Reply LCD Flat Panel Displays
Olevia
