Viewsonic VX2235wm Monitor Nintendo Wii Compatible? - AVS Forum
post #1 of 2 Old 04-09-2007, 09:35 PM - Thread Starter
Logansneo's Avatar
I have tested this monitor using an Audio Authority component-to-VGA transcoder and am able to get 480p signals through progressive scan DVD players, but when I used the same transcoder to convert the Nintendo Wii's 480p signal, I got a blank screen and then it auto shut off, indicating no signal. I have verified that this transcoder works on every other VGA-equipped LCD monitor I have and the Viewsonic VX2235wm is the only one that doesn't display the signal for the Nintendo Wii. Any ideas what is causing this problem?
Self-realization. I was thinking of the immortal words of Socrates, when he said, "I drank what?"
Logansneo is offline
post #2 of 2 Old 10-09-2007, 03:50 PM
gsshiva's Avatar
I connected Panasonic DMR-Ez475V DVD recorder's HDMI out to the DVI in of the VX2235wm using a HDMI/DVI adapter and the screen keeps on blanking out and in.
gsshiva is offline
Reply LCD Flat Panel Displays
User Tag List
