insignia blue light? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 05-02-2007, 11:51 PM - Thread Starter
krapow skater1's Avatar
i have the insignia NS-32LCD tv and the indacator light in the front which tell you if the tvs on or not dosent work
is like red orange when its off and blue when its on
when its off it works and its red but when i turn it on the light wont turn on
the tv works but its sees like it burent out
what should i do?
krapow skater1 is offline
post #2 of 11 Old 05-03-2007, 10:01 AM
BigJon7527's Avatar
Bring it back to BB. Since it is a BB private label, the store honor the manufacturer warranty.
Not all BB employees are idiots...
GamerTag - AirstripOne
BigJon7527 is offline
post #3 of 11 Old 05-03-2007, 05:01 PM - Thread Starter
well they said when i called them that since it dosent effect the tv its not under warentee
i even have the servace plan
umm i think ill just take it in
post #4 of 11 Old 05-03-2007, 05:22 PM
flatpanel's Avatar
That makes no sense. That's like saying if the gas gauge on your new car doesn't
work it is not a problem because it does not affect your ability to drive.
You only REALLY need the car's inside dome light at night, so that's not a problem. You can still
drive if the car even if the windows don't go up and down. You are just a complainer!
I bet you return moldy bread too!
flatpanel is offline
post #5 of 11 Old 05-03-2007, 05:24 PM - Thread Starter
ok
so what i want eveything to work
i payed for it right?
post #6 of 11 Old 05-03-2007, 06:10 PM - Thread Starter
dose anyone know how to fix this?
post #7 of 11 Old 05-03-2007, 09:15 PM - Thread Starter
come on anyonE?
post #8 of 11 Old 05-04-2007, 05:14 PM - Thread Starter
fine i gess no on knows?
post #9 of 11 Old 05-05-2007, 12:09 PM
flatpanel's Avatar
Return it. It should work as advertised.
post #10 of 11 Old 05-05-2007, 01:35 PM - Thread Starter
yeah i gguesss
post #11 of 11 Old 05-10-2007, 08:05 PM - Thread Starter
Ahhhh!
Reply LCD Flat Panel Displays
