Sharp D42U/D43U owners thread (32D42U, 32D43U, 37D42U, 37D43U, C3742U) - Page 21 - AVS Forum | Home Theater Discussions And Reviews
post #601 of 616 Old 04-15-2010, 11:06 PM - Thread Starter
ChrisC47's Avatar
I started this thread (including creating the FAQ in the first post) and I've never heard anything about a bad capacitor. Certainly it might be the case, perhaps in a tech bulletin put out by Sharp, but we've never seen it here.
Atlanta over-the-air digital TV reference table, now with Atlanta OTA FAQ:
http://www.avsforum.com/avs-vb/showt...7#post16732147
ChrisC47 is offline
post #602 of 616 Old 01-26-2011, 07:05 PM
ssybesma's Avatar
Originally Posted by ChrisC47 View Post
Ladies and Gentlemen -
We have not heard of any way to obtain or apply a firmware update.
Note: You MUST use a miniSD or SD card depending on the model.
(See back of the TV for a non-descript port that's covered by a plastic cap.)
I have both the firmware and the instructions upon request or you can look for D42UA123.zip or D42UA123.sdc (the binary file) online.
I was emailed the March 2008 ('C' version) of the firmware for free from a Sharp ASC, so I don't suppose it's that impossible to get it, depending on the attitude of the person providing it - in this case a manager who supports the idea that all firmware updates should be provided to customers upon request - my kinda guy.
The information for my current (non-updated) firmware is as follows:
Main Ver 1.20 (U 2007/05/24 1 A) <-- this is apparently the 'A' version
Monitor Ver 1.07
Boot Ver CFE-D42U 1.00 <-- note the D42U on a D43U set
Vmouse Ver --
EQ Data Checksum -- ROM
Hotelmode -- Off
POD - 000
I can't say this enough...
I VERY STRONGLY recommend plugging the TV into a UPS before attempting the flash. If the flash goes bad because of a power outage, well...you know the rest. It probably means having to bring it to an ASC and paying them. Better to spend the money now on a UPS than someone to do work you can do yourself.
ssybesma is offline
post #603 of 616 Old 01-29-2011, 08:04 PM - Thread Starter
ChrisC47's Avatar
I tried googling for "D42UA123" and the only result was in Spanish which I don't speak. Even with the help of a translation engine I couldn't figure out how to get to the file. If you can provide specific instructions to get to it I'll link it up in the FAQ.
Which is here, the first post in this thread:
http://www.avsforum.com/avs-vb/showp...27&postcount=1
ChrisC47 is offline
post #604 of 616 Old 02-07-2011, 10:36 PM
ssybesma's Avatar
[quote=ChrisC47;19918007]Thanks!
UPDATE:
Please send an email to steve (at) vwebr (dot) net if you want the firmware file for the LC-37D(or 32D)43U(or 42U). I don't know of any other way to get it to you.
I flashed my TV with the new version 1.23 firmware from version 1.20 successfully last night. Hey, it didn't magically offer any new functionality! (Wasn't expecting it to, haha!)
You must use a 2GB or smaller SD card formatted as FAT16 in order to be successful. The version of Linux in the TV can only read FAT16 of the M$ filesystems.
There was a detail I found when I flashed it that I need to correct. While the filedate of the firmware file is from March 2008, the actual date of the version is 8/8/2007. What I had was from May of 2007 (version 1.20).
This is the information about the 1.23 version I received from the Sharp Authorized Service Center person who emailed the update to me:
The new firmware can resolve the following occurrences:
1. Picture and audio may not be present when using a Set Top Box (STB) via HDMI connection (480i signal selection).
2. The channel OSD may flicker on and off when TV recognizes no HDMI signal input.
3. Black levels may appear poor when the Sony PLAYSTATION is connected via HDMI.
4. The display may flicker when using PAL-N or PAL input signal via component or composite.
Note: After doing an exhaustive Google search -- the template for the main firmware files are D42UA### (starting with '120' for the numbers) and for
the monitor firmware D42UM### (starting with '107' for the numbers) -- I could find no later versions mentioned at all other than the one I was provided.
INTERESTING SIDELINE:
Don't recall a mention of anyone having accessed the Public Menu (this is different than the Service Menu aka "Adjustment Process Mode"). This can be done with or without updating the firmware as above.
1. With the TV unplugged, hold down and <+VOL> (this is instead of and <-VOL> for the Service Menu/Adjustment Process Mode)
2. You will be prompted for a Public Mode password. The password is 027.
3. After a few seconds, the Public Menu will appear.
ssybesma is offline
post #605 of 616 Old 03-02-2011, 11:57 AM - Thread Starter
ChrisC47's Avatar
Thanks ssybesma!
ChrisC47 is offline
post #606 of 616 Old 04-24-2011, 07:12 PM
ssybesma's Avatar
Thanks ssybesma!
Glad to help.
Now if we can just figure out how to hack this file.
The file is in a GZIP format and expands to a slightly larger filename of D42UA123 which has an ELF header.
Clicking on that file opens up filenames 0, 1 and 2, which 2 having the vast majority of the code.
I tried a few disassemblers but no luck so far.
I would like to change some of the labels for the inputs (like Game, for instance, which is not one of the ones you can select).
The text for the labels does not appear in the file as a string, so my guess is that the ELF file is still compressed in some way.
ssybesma is offline
post #607 of 616 Old 09-03-2012, 09:06 AM
repherb's Avatar
Hi all! I need help, i have a Sharp Aquos LC-42D43U 42" LCD TV that has started showing a weird issue on the screen. Black colors are now showing up green and the RGB colors look like their gain is too high (ie:red has overpush to start showing pink in it and color bleeding). When i turn down the contrast and brightness the colors are still there like ghosts where the excess colors are. I will attach a picture to show you what i mean, I have access to the service menu and I am quite sure there is no hardware malfunction as i see it, it seems to be a RGB push or gain issue, however i am not a tv tech so i am no expert.
any help would be appreciated!!!
tad_sharpusa_black_messed_up.jpg 1530k .jpg file
repherb is offline
post #608 of 616 Old 07-28-2013, 06:43 PM
lufcyad's Avatar
Anyone ever get the firmware? I have the same issue as the guy above, and I cant get the firmware for anything.
lufcyad is offline
post #609 of 616 Old 07-28-2013, 07:33 PM
lufcyad's Avatar
This is what my tv is doing. Updating firmware had no effect.
lufcyad is offline
post #610 of 616 Old 11-16-2013, 08:33 AM
3m3rson's Avatar
I just calibrated my set (LC-C3242U / Costco) after many years of ownership using the AVIA disc and a Panasonic DVD-S35 (480P) via Component. Previously I was using picture settings recommended by other users. I was surprised to find that my settings were way off for Brightness and Sharpness. Here is what I am now using:
OLD SETTINGS
OPC on (dim light viewing) / OPC off (day time viewing)
Backlight -4
Contrast +30
Brightness +4
Color -8
Tint 0
Sharpness -1
Color Temp med-high
Black Ext off
Range of OPC
Max -4
Min -16
CALIBRATED SETTINGS
Backlight -4
Contrast +34
Brightness -1
Color -8
Tint 0
Sharpness +6
Color Temp med-high
Black Ext off
Range of OPC
Max -4
Min -16
Curious whether it is worth dicking around with firmware or factory menus. I'm pleased with the picture as-is.
3m3rson is offline
post #611 of 616 Old 04-07-2014, 03:05 PM
MBezeau's Avatar
Can you tell me the screw sizes required for the stand on the 37D43U?!  There should be 9 screws total.
We have misplaced them and the sizes are not listed in the manual.  Would like to be able to go to the hardware store to get them.
MBezeau is offline
post #612 of 616 Old 08-20-2014, 12:40 PM
mingus's Avatar
Quoted: 57 Post(s)
Monitor Ver 1.07
Vmouse Ver --
Hotelmode -- Off
POD - 000
does anyone have the 42u firmware file available? Thanks
mingus is offline
post #613 of 616 Old 08-28-2015, 09:40 PM
genseng's Avatar
Liked: 0
Old thread for a question on an old device. Anyone have any luck getting the digital optical output to work from the Sharp 37D43U with a Chromecast? I've tried with the settings linked previously in this thread for a PS3 but no luck with the Chromecast so far. I was able to test the optical input on my receiver with another device and it works so I think it's either something with the Chromecast or the TV. Unfortunately I have nothing connected to the Antenna/Cable input to test the optical output with that.
genseng is offline
post #614 of 616 Old 08-28-2015, 10:07 PM
2therock's Avatar
Sorry I have not tried it with a Chromecast. I am doing it with Comcast X1small additional bedroom box, which is wireless if you know what I mean.
Also when I went from the Scientific Atlanta to the X1 the TV was video look got really bright or blown out. I set my settings to default and BAM! nice.
Let us know, I was thinking of Chrome Cast too.
Thanks, 2therock
My Setup
2therock is offline
post #615 of 616 Old 08-31-2015, 04:55 AM
skimple's Avatar
I am using chromecast on this but haven't tried the optical out yet. I'll test it out when I get home and let you know if mine works.
skimple is offline
post #616 of 616 Old 09-07-2015, 02:29 PM
genseng's Avatar
Liked: 0
Any luck with this? I've since tried to reset the TV but had no effect.
genseng is offline
Reply LCD Flat Panel Displays
Sharp , Sharp Brand
