Official Samsung LN-TXX61F/65F/66F Owner's Thread III - with *updated* first post. - Page 655 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #19621 of 19640 Old 10-02-2014, 09:45 AM
4r4r4r00's Avatar
Quoted: 17 Post(s)
Originally Posted by SirDracula View Post
Kinda disappointed by my 4665F, blown capacitors, then power board replaced, back-lighting not uniform. But it's still usable after 7+ years and I just can't throw it out.
ashes to ashes
dust to dust
all good things ...
4r4r4r00 is offline
post #19622 of 19640 Old 10-07-2014, 02:33 PM
encendido5's Avatar
Quoted: 39 Post(s)
Originally Posted by bodotdot View Post
My LNT4665F is still our living room TV and it hasn't lost a step. Do you know if Chromecast will work with this TV, specifically? The TV has lots of USB ports but I'm not sure if there's something internal (software) that it needs to have.
I've used it on my 5265 without a problem. I don't see why it wouldn't work on the 4665.
My 5265 is still going strong since buying it in late 2007. The uneven backlighting is annoying though.
encendido5 is offline
post #19623 of 19640 Old 10-07-2014, 03:02 PM
bodotdot's Avatar
Sorry to hear that. I'm amazed that this thread is still around--every other year it seems I print out that Post #1499 from this thread and re-do the settings that someone decides to mess with--that post probably hasn't been updated in a while but it's still a good setup.
bodotdot is offline
post #19624 of 19640 Old 10-07-2014, 05:21 PM
encendido5's Avatar
Quoted: 39 Post(s)
Yeah it's really only noticeable in really dark scenes but still
post #19625 of 19640 Old 10-24-2014, 05:05 PM
SirDracula's Avatar
Quoted: 172 Post(s)
Does a discrete IR code exist for the LNT4665F that can switch to the TV input and select the *digital* tuner? My Harmony remote has a discrete code for InputAntenna but if I switch from HDMI1 to it, the TV input is always on analog channel 8 even though I last watched a DTV channel and only have DTV channels (using an OTA antenna). Is this a bug in that the TV doesn't remember the last used tuner? Any special menus to disable the analog tuner completely?
SirDracula is offline
post #19626 of 19640 Old 12-09-2014, 09:52 AM
encendido5's Avatar
Quoted: 39 Post(s)
Have any of you LNT owners upgraded your sets? I recently won a contest at work and am looking to buy a new TV with my winnings. Ideally, I would want a plasma or an OLED, but plasma is hard to find (at least the F8500 is) and the OLED is way too expensive.
post #19627 of 19640 Old 12-12-2014, 04:05 PM
justerik's Avatar
Official Samsung LN-TXX61F/65F/66F Owner's Thread III - with *updated* first ...
Wrong thread
justerik is offline
post #19628 of 19640 Old 12-13-2014, 01:33 PM
encendido5's Avatar
Quoted: 39 Post(s)
Sorry, I figured I could get opinions from people that own the LNT so the expectations are the same.
post #19629 of 19640 Old 12-27-2014, 08:48 AM
kcrossley2's Avatar
I did a service reset of my Samsung 4661F not realizing that doing so would reset the number of hours on my LCD. Is there anyway to get that info back?
Also, after doing a service reset, what settings do I need to tweak?
And finally, should I upgrade my firmware? My current firmware is as follows:
T-TULPAUSO-1037 October 30, 2007
T-TULPAUS5-1011
kcrossley2 is offline
post #19630 of 19640 Old 12-30-2014, 01:13 AM
theroys88's Avatar
Quoted: 163 Post(s)
Liked: 54
I purchased a UN65H6350. Definately a upgrade in picture quality. My 5265f is still going strong. Not one issue since 2007.
encendido5 likes this.
theroys88 is offline
post #19631 of 19640 Old 08-06-2015, 11:56 PM
pixelation's Avatar
"Not Available" / Volume goes to 0
Any owners still around here? I have the 4665F and starting this weekend I noticed that the TV pops up "Not Available". I searched the internet. And found this thread:
http://support-us.samsung.com/cyber/...name=LN-T4671F
Unplugging didn't help. But after changing the audio output to "Internal" (I used an external speaker). I see that "Not Available" is because the Volume is being adjusted to 0. I am not sure what caused it but it is not because of IR because I have tried blocking the sensor.
Any owner experienced something similar?
pixelation is offline
post #19632 of 19640 Old 08-22-2015, 03:06 AM
tk54911's Avatar
Quoted: 31 Post(s)
Samsung LN-T4661F gray semi-transparent “patches” periodically float around screen
Sometimes a gray “patch” appears which is usually rectangular and then it will grow or shrink on and off for awhile. Sometimes another patch appears and may overlap it. Sometimes the patch/es will grow to a cloud shape and cover most of the screen. The patches are always semi-transparent / I can mostly see through them to the picture behind.
They seem to start 30-60 minutes after the TV is turned on (not really sure how long), last between a few seconds and a minute or two, then go away.
While this is happening, I’ve switched between all inputs and the patches remain the same, so I know it’s not a cable or any of the input connections. The issue does not affect the audio at all.
Anyone have any idea what might be wrong?
I doubt I’ll be fixing it myself, but if I can get some idea what it is and find a TV repairman (do they even exist anymore?) to repair it, I’d like to go that route. It has a matte display which I like very much and in addition to the three HDMI inputs, it has two composite inputs, which I need. Neither the matte display nor the two composite inputs are available on a new Samsung, which is why I’m willing to spend the money to get it repaired. This is the only problem I’ve ever had with this TV.
Any input would be greatly appreciated. Thanks!
tk54911 is offline
post #19633 of 19640 Old 08-28-2015, 11:01 AM
pixelation's Avatar
Turns out the issue is caused by the volume key. The key might have stuck internally. I pressed them a few times and the problem went away.
post #19634 of 19640 Old 01-28-2016, 04:39 AM
theroys88's Avatar
Quoted: 163 Post(s)
Liked: 54
My lnt5265f still going strong. The panel on my set is almost perfect. No clouding, flashlights and uniformity is perfect. Of course a Samsung panel. When fed a clean blu-ray signals especially if was digitally shot, it shows a beautiful picture. Where it faulters is with poor cable, DVD ,Blu-ray sources. That is the improvement I see on my UN65H6350. Also having a 120hz panels helps with motion but the AUO panel in it shows clouding, minor banding.
post #19635 of 19640 Old 04-06-2016, 09:31 AM
steveh27's Avatar
My 4665 is still working well after 8 1/2 years.
steveh27 is offline
post #19636 of 19640 Old 07-29-2016, 06:29 PM
Liked: 0
I've had my LN-T5265F for about 9 years and never checked this thread until today.
What prompted me was a new Onkyo home theater receiver which supports HDMI (my old Pioneer, being a couple years older than the TV itself, had digital inputs but only coaxial and optical, which I used all the time). I always used HDMI with my TV through the TV inputs directly, and always experienced annoyances with the flaky connection, but it was always within the threshold of acceptability.
Now with the switching of HDMI inputs through the receiver, the HDMI issues of the TV kicked into high gear. So I downloaded the 1037 firmware update from a link in this thread and installed it.
The progress bar went to about 75 percent in 2 seconds, then got stuck there. After an hour I decided that the progress bar was not going to move any further, and had no choice but to unplug the TV. (It didn't respond to the remote or the buttons on the unit.) When I plugged it back in I was not sure what to expect, but to my delight it came back with the new firmware!
Now the HDMI connection is solid and my first impression is that the picture quality got better. My old firmware was 1009, and no matter what I did I could never get the black levels right without making the image too dark. Now I noticed that there's a gamma correction adjustment, which is great, but I didn't even need to use it because I was able to adjust the image (including black levels) without much effort using the other adjustments. This just wasn't possible before.
So I'm posting this in case anybody has a similar experience with the firmware update. If the progress bar gets stuck, don't panic. But do give your TV at least 60 minutes to make sure the update goes through.
diego99 is offline
post #19637 of 19640 Old 10-14-2016, 03:20 AM
fredskidoo's Avatar
Liked: 0
Hello
I have the LN-T466F1 with 1009 and recently updated from 1004 to 1037 firmware. I have a single red vertical line on the right hand side of the screen. Ill try to attach a picture below. Looking fort solutions oe experiences in resolving this problem. Thanks all...
fredskidoo is offline
post #19638 of 19640 Old 11-19-2016, 06:57 AM
Dookiethree's Avatar
After more that 10 years mine is still going strong. Did replace the capacitors. Still great picture today!
Name:	Monitor Audio 01.jpg
Dookiethree is offline
post #19639 of 19640 Old 11-19-2016, 07:02 AM
scsiraid's Avatar
Mine too... still looks great!
scsiraid is offline
post #19640 of 19640 Old 11-22-2016, 07:21 PM
Liked: 0
I have the LN-T4065F tv and I made the mistake of trying to look around in the "service menu" to see what it did and completely screwed up my tv. I still have picture but it's like it's zoomed in and I can't see the edges. I've tried changing aspect ratios with the remote so I know that's not the problem.
I guess my question is if I could reinstall the firmware would it reset the "service menu" options to default and correct my problem? I've had this tv since 2007, replaced the capacitors on it when it had problems years ago. Don't want to let go of this thing over some fudged settings in the service menu.
Does anybody know where I can even find the firmware? The links in this thread that I've found are all dead.
tmcm11 is offline
Reply LCD Flat Panel Displays
