Question: What is 24fps? - AVS Forum | Home Theater Discussions And Reviews
Old 05-21-2007, 05:57 PM - Thread Starter
haiku_aubade's Avatar
Sorry if this has been asked before, but what is the rave about 1080p / 24fps and what is 1080p / 60fps..
which is better and why?
haiku_aubade is offline
Old 05-21-2007, 06:02 PM
wraithetc's Avatar
24 frames per second - for tv this is basically the level of frames would portrays smooth movement etc.
60 would obviously be 60 frames a second which in theory would be more fluid than 24 but is probably not a huge improvement vide wise.
wraithetc is offline
Old 05-21-2007, 06:09 PM - Thread Starter
so i take it that 60fps is better? why would they make 24fps then?
Old 05-21-2007, 06:33 PM
Josh7289's Avatar
Most movies are filmed in 24 fps. 60 Hz TVs have to use a process called 3:2 pulldown (Wikipedia it) to display 24 fps sources, like movies. All the talk about this probably relates to the new 120 Hz TVs, which can display 24 fps (movies), 30 fps (TV shows and games), and 60 fps (games) "nicely" (in that 120 is the lowest common denominator of 24, 30, and 60 -- if you looked up 3:2 pulldown, you'd know why this is good).
Josh7289 is offline
Old 05-21-2007, 06:37 PM - Thread Starter
Thank you Josh for explaining this to me.. i'll Wikipedia 3:2 pulldown.
thanks again
Old 05-21-2007, 07:02 PM
Josh7289's Avatar
There might be some parts of my explanation that could be explained better, but I hope I got the gist across.
Josh7289 is offline
Old 05-21-2007, 07:50 PM
HDgloryhog's Avatar
Great explanation. Does the 52" Samsung LCD 1080P have the 120 Hz?
The Look and Sound of Perfect.
Beyond High Definition.
Format neutral
HDgloryhog is offline
Old 05-21-2007, 08:29 PM - Thread Starter
no i don't think the past and current Samsungs are 120Hz
the new 71 and 81 series i believe will have it
Old 05-22-2007, 08:46 AM
chrisherbert's Avatar
Quoted: 17 Post(s)
I think that most of the new 120hz TV will not help with judder. They either don't accept 24fps signals or they change it to 60hz then to 120hz, which makes it kind of pointless.
I'll bet the next generation of 120hz TVs will be better in this respect.
chrisherbert is offline
