Official Westinghouse TX Series ( TX-42F430S, TX-47F430S ) Owner's Thread - Page 207 - AVS Forum
post #6181 of 6183 Old 08-28-2014, 12:12 AM
Woobieizer's Avatar
Quoted: 194 Post(s)
Liked: 75
I said T-Con inadvertently. It's the Master and Slave Inverter board where the obvious bad caps are. Thumbed below is the overview and cage where the PSU and Main board are housed..
I managed to get the PSU out for an inspections but could only take a picture of the main board thur an opening.
I'll guess it was assembled in 04/2007
Name:	Westinghouse overview.jpg
ID:	232929   Click image for larger version
ID:	232937   Click image for larger version
Woobieizer is online now
post #6182 of 6183 Old 08-28-2014, 09:50 PM
orgwood's Avatar
I went back to post 6121 for a picture of the 42" version like mine is and see that yours is definitely different. Are you certain that whole metal panel doesn't come off some how? It doesn't make sense that it wouldn't since you have to be able to get to the PCBs for repair or replacement. Give it a good look see before you start drilling out rivets. I don't see any through hole caps on your board from the picture you took so I'm wondering if you have the same board that we're talking about. You did replace all those bulging caps didn't you? Dave
orgwood is offline
post #6183 of 6183 Old 09-12-2014, 08:01 PM
Liked: 0
Smile 470uf cap
I have the TX42F430S tv with the same Amber light issue and a TV that would just not turn on. Thanks to everyone for this thread. After reading all the posts, ordering the 470uf 16v 105c cap from Amazon... for a very low price, I had fun tonight taking the TV apart.
I looked at all the caps and they looked in good shape. No tops bulging. So I went with the write up and looked for the 470uF cap above the 150 M64. It also looked good to me with no problems at all.... but after taking the TV apart I was not about to stop. So, I pulled out that cap and solder a new 470uf on anyway. AND IT WORKED!!! TV came right on all channels working. Thanks to all that took the time to add to this tread. I was ready to trash my tv and now it's back up and running. And I am no expert in soldering or working on electronics. It was very simple process thanks to the pictures and directions posted here.
Mica11 is offline
Reply LCD Flat Panel Displays
470uf cap , Westinghouse Tx 42f430s 42 Inch Lcd Hdtv , westinghouse tx-47f430s
