Official Olevia 237T Owner's Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 06-04-2007, 01:05 PM
bigmakstudios's Avatar
I was thinking over the weekend - three more HD channels in our line up and I would never have to watch SD again! (we have all the networks, Fox Sports, TNT, Discovery (though they need their normal programs in HD), and ESPN - I want SciFi, Animal Planet, and FX).
What's the difference in cost between basic analog cable and basic analog cable with additional HD channels?
bigmakstudios is offline
Old 06-04-2007, 01:12 PM
Why would someone want to price match their current price? For only 20.00 more they could get a 537H
Price match plus brings the price down 10%.
I'll try to remember to post a picture or two tonight. Should have Discovery HD now. Will be flipping between that and the Stros.
pics pls. <_>
Old 06-04-2007, 01:33 PM
Planet HDTV's Avatar
So do I. Especially Sci-Fi, you would think that considering the nature of their programming that they would WANT to broadcast in at least 720p. Sadly, it probably won't happen for another year though
Planet HDTV is offline
Old 06-04-2007, 01:40 PM
Originally Posted by goblues27 View Post
It doesn't work in HDMI Mode
Originally Posted by rbenotti View Post
I'd like to change the settings (black extender, etc), but can't via HDMI.
You can on the 537H, so it looks like you guys have discovered another 'difference' between the two models. On the 537H you can set it when the tuner is on Switch to tuner and see it it appears in the menu. If it doesn't then they muted that feature.
Old 06-04-2007, 01:41 PM
Contact your cable company. Where we're at there is no difference
Old 06-04-2007, 01:51 PM
rbenotti's Avatar
On the 237T it is available when using the tuner. It's not when you switch to HDMI.
When comparing manuals, there are other differences too. The RGB controls come to mind.
rbenotti is offline
Old 06-04-2007, 02:05 PM
That's because those settings are for tuner signals, not picture output signals. If I have time later I'll post a flow chart which will explain it better
I keep forgetting about those But that is indeed another difference
Old 06-04-2007, 02:08 PM
mm42's Avatar
Are you guys using the HDMI cables via a cable box? Or the tuner?
Maybe it's the box I have, or the HDMI cable itself.
I have tried just about everything, tuner, cable box via component, cable box via HDMI, DVD via component, DVD via HDMI, and in all cases the scaling was excellent.
I doubt your HDMI cable is the problem.
Does the SD picture look bad at 1:1 if you move twice as close to the screen?
mm42 is offline
Old 06-04-2007, 02:27 PM
See if this flow chart helps explain it?
Old 06-04-2007, 02:42 PM
rbenotti's Avatar
It does explain it. I guess the question is why? Oh well.
rbenotti is offline
Old 06-04-2007, 03:08 PM
phipp01's Avatar
They shouldn't be. Make sure you're on the correct source.
Yes IDEA should be disabled if you are using the HDMI port.
phipp01 is offline
Old 06-04-2007, 03:21 PM
A better question is why doesn't Olevia mention it ANYWHERE? Not in their manuals, and not even on their website I've contacted them about it to try to get more specific information on why. When I hear from them I'll post and let you know what they say, but they should at least mention it somewhere I've also noticed that they don't mention Director's Image anywhere in the manual either
Old 06-04-2007, 03:29 PM - Thread Starter
Yankee_In_TX's Avatar
The manual does stink - "how to turn "X" on" - never explains what "X" does or when to best use it.
As far as Director's Image, I assumed this was the varying available levels of zoom/aspects...?
Yankee_In_TX is offline
Old 06-04-2007, 03:36 PM
phipp01's Avatar
And thats why I never read manuals I just play around with things until I get them figured out
phipp01 is offline
Old 06-04-2007, 03:56 PM
According to their website we're not supposed to be able to adjust Directors Image. It says; "Watch programs with the rich colors and image enhancements as the director intended." That implies that we should be able to turn something on to see what "the director intended." Pretty much everything about the manual is poor. I hope next years products actually have a readable manual. Almost every single review on the net about Olevias mention the bad manual. Hopefully someone at Olevia is taking notes I wonder how much busier their tech support department is, just because people have to contact them about simple questions that should be in the manual. Hopefully they'll keep the people who made the manuals - away from the people who design the TV's
Old 06-04-2007, 04:57 PM
cliff2456's Avatar
I purchased a Sony DVP-NS75H HD upconversion DVD player today. It really enhances the picture! I put the HDMI and Component inputs on the new player side by side on the TV and I was surprised to notice that the component was clearer in my opinion. This of course works out really well since my satelite box will be HDMI and there is only one HDMI input on the TV. Has anyone else tried upconverting DVD players? Just wondering how their luck was. I have been told before that XBOX 360's also run a better picture through component cables than HDMI as well. This surprises me though because HDMI is 1080i and component is 480p.
Does anyone know if there a way to select the input resolution? Like, can I pick 720p, 1080i, or 480p on my devices?
cliff2456
cliff2456 is offline
Old 06-04-2007, 05:06 PM
You might be looking for Picture > Mode > Input > Hi Def TV.
Old 06-04-2007, 05:07 PM
bobthepome's Avatar
Most upconverting DVD players ONLY upconvert over the HDMI output and not the Component. Its a copying protection issue. I believe the Sony follows this practice.
bobthepome is offline
Old 06-04-2007, 05:14 PM - Thread Starter
I have upconverted w/ the PS3. Movies look GREAT
Old 06-04-2007, 05:23 PM
mm42's Avatar
Upconverting DVD player improves the picture compared to what? The big improvement comes with progressive scan, so if you are comparing to a standard 480i DVD player, most of the improvement is probably there rather than the upconversion.
mm42 is offline
Old 06-04-2007, 05:24 PM
jsf0656's Avatar
i agree! i cant even get my manual to come up on my CDROM on the computer. i've tried everything. BTW my SD channels look great but i'm using cable straight from the wall no box.
jsf0656 is offline
Old 06-04-2007, 05:48 PM - Thread Starter
An SD DVD upscaled to 720p looks better than the same DVD at 480i
Old 06-04-2007, 05:51 PM
phipp01's Avatar
If you cant get the CD to work why not just D/L the manual from olevias website?
phipp01 is offline
Old 06-04-2007, 06:23 PM
jsf0656's Avatar
yep thats what i did.
jsf0656 is offline
Old 06-04-2007, 07:42 PM
marksj's Avatar
I am having a little trouble with whites.I have done some adj but when there are a lot of white,like a hockey game,tv was on an hd channel and the jerseys etc look great but when they shoot the whole ice it almost blurs.I have done some adj but i cant get it set right when there is a lot of white in the picture.Any help for a noob?
marksj is offline
Old 06-04-2007, 08:38 PM
n4fw's Avatar
The manuals for the 237T and 237V are not available from Olevia's website.
The 237V manual is available here.
n4fw is offline
Old 06-04-2007, 08:51 PM
The brightness and contrast controls work off of each other. Sounds like you have one set way to high.
Old 06-04-2007, 09:37 PM
marksj's Avatar
so i need to set them at the same spot on the bar for the brightness and contrast as opposed to low brightness high contrast etc? thanks will try it now
marksj is offline
Old 06-04-2007, 09:57 PM
marksj's Avatar
Got levels reset contrast was real high,picture is much better but the picture is a little dark for my liking and if i bump either up just a bit the white seems to overpower(like when screen has direct sun in the background)but it is much better than i originally had it set
marksj is offline
Old 06-04-2007, 10:07 PM
cliff2456's Avatar
Are most of you running the "fullscreen" option? In what situations would you use the other options (1:1, panoramic, zoom, aspect)?
I'm curious as to what settings everybody "configured" their Olevia with. If you have any suggestions as to how to make the picture even better than it already is, please post your recommendations. I know that some people have experienced the best picture with high contrast, low brightness, and high color.
I'm also interested in those of you that have upconverting DVD players. I was wondering if you experience a better picture via HDMI or component cables. You can run a split screen and view both at the same time do compare. It's a beautiful option! My experience was that the component looked better, and I have seen this happening to many LCD TV owners via forum posts. Many posts say that "it depends on your TV" whether component or HDMI looks better.
