Vizio VX37L Tuner question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-29-2007, 09:18 PM - Thread Starter
igotgame's Avatar
I just setup my VX37L tonight gang and when it does channel scan it only finds 61 channels and no digital or HD channels over my basic cable line.
My Mitsu DLP in the living room picked up 4 OTA HD channels(fox, cbs, nbc, abc) when I did a scan with it.
Is there a particular reason the Vizio wouldn't pick up any of the HD channels my DLP does? Is there something I need to do to make it scan digital channels?
igotgame is offline
post #2 of 3 Old 06-29-2007, 09:44 PM
Rudy1's Avatar
Quoted: 1377 Post(s)
Liked: 1984
Make sure that you've set the TV to scan for cable channels....there is an option for ANTENNA or CABLE in the menu. If you have already done this and you are still not getting any cable analog or digital channels, move the TV into the living room and connect the cable line that is now on your Mits to the Vizio to see if it picks up the channels. If it still doesn't, there may be something wrong with the cable tuner in the Vizio. If it does pick up the cable analog and digital channels, then there might be a problem with the cable jack in the room where you have the Vizio.
There are two types of people in this world: People you want to drink with, and people who make you want to drink.
Rudy1 is offline
post #3 of 3 Old 06-30-2007, 05:43 AM - Thread Starter
igotgame's Avatar
Well it picks up abouit 61 Analog channels, but it always says 0 Digital on the scan. So its picking up cable channels, just not any HD ones or digital ones.
Oh well.....guess it won't matter since my wife wants a cable box in the bedroom anywayz. HD cable box will solve this problem.
igotgame is offline
Reply LCD Flat Panel Displays
