question? - AVS Forum
post #1 of 9 Old 06-30-2007, 01:09 PM - Thread Starter
fred9000's Avatar
hello every one ! i asking my self if there is a difference in vga cable signal
or lenght , i have bougt a quality vga cable (10 feet) and it suppose to support fullhd
wich it is and it have superb pq.
if i try this cable with my 7800gt in my htpc and my samsung lnt4061f
in the display properties it said 7800gt on default monitor and did not keeping 1920x1080 res every time i reboot
but if i take my basic vga cable from my viewsonic crt (6 feet) , the diplay propertie said 7800gt on samsung and when i put 1920x1080 the htpc keep the res every time i reboot.
help somebody
sorry for my bad english
fred9000 is offline
post #2 of 9 Old 06-30-2007, 08:23 PM - Thread Starter
fred9000's Avatar
fred9000 is offline
post #3 of 9 Old 07-02-2007, 10:13 AM - Thread Starter
fred9000's Avatar
bump
fred9000 is offline
post #4 of 9 Old 07-02-2007, 01:22 PM
chrisherbert's Avatar
Quoted: 12 Post(s)
There shouldn't really be any difference, but why can't you just use the cable that works?
chrisherbert is online now
post #5 of 9 Old 07-02-2007, 07:09 PM - Thread Starter
fred9000's Avatar
well , because the PQ is better , you can see it..
fred9000 is offline
post #6 of 9 Old 07-02-2007, 07:22 PM
alysenne's Avatar
The basic VGA cable must be really, really horrible if you can tell the difference. Then again, some people are really sensitive to differences that I would never notice.
Do you have the option to stick with a digital signal? HDMI or DVI? Definitely better to go that route if you're using a PC as the source.
alysenne is offline
post #7 of 9 Old 08-25-2007, 11:11 AM - Thread Starter
fred9000's Avatar
well a recently discover that with a basic vga cable (from my nec crt ) my 7800gt detect the screen as a samsung and it bot perfectly in 1080 res , but my problem is that i want to use a 10 feet cable ( because i want to put my htpc on the shelf of my audio rack )
anyway i try the 10 feet vga cable, and i cant boot in 1080 (the sceen is black and it tell me unsupported res or sommething like this) at first i tought it was the cheap 10ft vga cable that was the problem and try a good one , same problem
to be honest , there is not a big difference in quality of image , it is more important to find a way to use a 10 feet lenght because of the practicall matter
my samsung do 1:1 on vga and it is not the same story on hdmi (overscanning problem) + i prefer the PQ in vga
fred9000 is offline
post #8 of 9 Old 08-25-2007, 12:04 PM - Thread Starter
fred9000's Avatar
i hope i can find someone who had encouter the same problem so i can fix this
thanks
fred9000 is offline
post #9 of 9 Old 08-25-2007, 03:04 PM - Thread Starter
fred9000's Avatar
ho boy ! i finaly manage how to save a custom setting in the forceware with the normal cable , after that , i put the 10 feet cable and it boot correctly with the timming saved
it still detect my samsung as analogue monitor ( with the basic cable it was detct as samsung) but it work
fred9000 is offline
Reply LCD Flat Panel Displays
User Tag List
