Input Resolution vs Display Resolution - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-09-2007, 06:26 AM - Thread Starter
Thunderduck's Avatar
Quoted: 54 Post(s)
Liked: 25
Question about what is better to output to my new 32" HDTV (Samsung LN-T3253H.
I went from a 26" in tube HDTV that could accept and display all resolutions from 1080i down to the new 32" Samsung tv that can accept 1080p resolution input but displays it at 720p. Great tv by the way!
My output devices were all set to send 1080i resolution to the tv. They are still set for that resolution and look fine to me. My question is would it be better to reset them to 720p to match the display's maximum on-screen resolution or leave them as they are?
One other question. Why are HDTVs configured to accept a higher resolution than they can display? Why can many receive a 1080p signal but only display it at 720p?
Thank you for any clarification/suggestions provided.
Steve
Thunderduck is offline
post #2 of 7 Old 07-09-2007, 07:07 AM
tower101's Avatar
The panel only displays its native res, in your case 1366X768. The more resolutions it can accept and convert to its native res the better (makes it more versatile).
As far as what would be best for you TV try sending it different resolutions and pick the one that looks best to you, my guess would be 1080i/p.
tower101 is offline
post #3 of 7 Old 07-09-2007, 07:40 AM - Thread Starter
Quoted: 54 Post(s)
Liked: 25
Thank you very much. What you say certainly makes sense to me.
Steve
post #4 of 7 Old 07-09-2007, 09:07 AM
chrisherbert's Avatar
Quoted: 17 Post(s)
Because content is often distributed in resolutions higher than what is native to the display. You wouldn't want your TV to be unable to accept 1080i signals, after all.
As for all your components, it depends on what they are. If you have a cable box, see if you can set it to a "passthrough" mode than sends out the channels in their original resolution. That way the TV does the scaling rather than the box.
chrisherbert is offline
post #5 of 7 Old 07-09-2007, 09:34 AM - Thread Starter
Quoted: 54 Post(s)
Liked: 25
No cable box. Just regular cable service through an antennae directly connected to the tv's antennae input.
Other components are PS3 and HD A2 connect via HDMI and XBox 360 connected via component input. These three are connected via HDMI to the tv through a receiver.
post #6 of 7 Old 07-09-2007, 10:13 AM
Gmaxx's Avatar
On a 32" set you will most likely not notice a difference between say 720p vs 1080i/p being sent from your equipment. Just set up the 360, PS3 and hd a2 to 720 and be done with it. It will look amazing. If you want to you can try out the settings and look for a difference but I doubt you'll notice anything...
On the other hand your cable will already be delivering each channels native resolution to your set so you don't have a choice anyway. Enjoy!
Gmaxx is offline
post #7 of 7 Old 07-09-2007, 10:36 AM - Thread Starter
Quoted: 54 Post(s)
Liked: 25
Sounds like a good idea. I suppose the less processing (up or down) a signal has to go through the better.
Reply LCD Flat Panel Displays
