Panasonic LX70 and LX700 Series Owner's Thread - Page 8 - AVS Forum | Home Theater Discussions And Reviews
post #211 of 223 Old 03-26-2008, 08:46 PM
Dirac's Avatar
Right on time... I submitted that post on March 5th.
Dirac is offline
post #212 of 223 Old 04-07-2008, 02:55 PM
DaBones's Avatar
I have a question. I have a TC-26lx70, and I use it mostly for playing PS3. The picture quality is great, but I have one issue with it, in some games where there are lights shining off off metal, or sunlight etc, there seems to be like glare, and a little bleeding of the white. I was playing Army of two, and during the game there are alot of levels where they are outside, and wearing metal armor, and the sunlight reflecting off the armor, helmets, and weapons was very bright, almsot to the point that those items lost all level of their details. My picture settings are as follows
picture mode= custom
backlight= -30
picture= 0
brightness= +20
color== -5
tint= 0
sharpness= +5
color mode= cool
ai picture and NR= off
black level= light
are there any picture settings you can suggest that may help with this. I have tried turning brightness dow, as well as picture, ai picture, and NR on, black level to dark etc, all to no avail. I am hoping it's not just my tv, any and help will be appreciated.
DaBones is offline
post #213 of 223 Old 05-04-2008, 11:51 AM
TcoUpload's Avatar
No review's on the newly LZD80/85?
TcoUpload is offline
post #214 of 223 Old 05-05-2008, 05:36 PM
Uncreative.Name's Avatar
So should I pick up a 26" LX70 or a Samsung 26" or last years model (42 or 53h)? I'm probably going to be gaming with a 360 through Component or HDMI until I get a PS3 in which case I'll be watching BD movies.
Uncreative.Name is offline
post #215 of 223 Old 05-06-2008, 04:37 PM
backlight= -30
picture= 0
brightness= +20
color== -5
tint= 0
sharpness= +5
color mode= cool
black level= light
Are you sure this is a product of the TV and not just the HDR lighting being used in the game? It sounds like it's just a lighting effect and not the TV. Halo 3 has a lot of that. Also, I'm thinking of grabbing this TV. Is there any lag when playing games?
post #216 of 223 Old 05-08-2008, 07:23 PM
eeprom's Avatar
I just bought a similar model LX75, it's the LX70 with VGA input. I'm connecting it using VGA cable from my PC's DVI port. The problem is when i set the resolution to 1360x768@60hz, the screen would go blank intermittently for 2~3 seconds, then it comes back to normal. I have not observe any black out at 1024x768 though.
Has anyone makes it work at 1360x768?
eeprom is offline
post #217 of 223 Old 05-21-2008, 10:55 AM
DaBones's Avatar
Uncreative.Name I noticed a little lag when I had video NR on, but after turning it off I have noticed no lag, and I have very sensivitive eyes, so if it was lagging I would have noticed it, all and all it's a great TV, and amazing picture quality.
DaBones is offline
post #218 of 223 Old 06-05-2008, 06:41 PM
Josh68's Avatar
Originally Posted by onward View Post
This model doesn't support firmware upgrades via SD card either.
I've done one on mine. Forget where I got the update, but it was one one of Panasonic's sites.
Josh68 is offline
post #219 of 223 Old 06-05-2008, 06:45 PM
Josh68's Avatar
Josh68 is offline
post #220 of 223 Old 07-29-2008, 02:41 PM
Nero25's Avatar
how do you apply the update to the 32lx70, i dont see a sd slot or usb slot. Can some post a picture please?
Nero25 is offline
post #221 of 223 Old 07-29-2008, 04:03 PM
Dirac's Avatar
It's in a really bad place, on the rear panel of the TV, but it is there. It is marked, but a bit hard to see. The card goes up (vertically) into a small SD card slot. I'll try to get a picture up soon--I can't find one on the web.
EDIT: It's by the HDMI ports. Check page 9 of your manual.
Dirac is offline
post #222 of 223 Old 06-26-2009, 12:10 PM
ericp's Avatar
Thread resurrection:
Anyone here have success hooking the LX70 up as an htpc?
ericp is offline
post #223 of 223 Old 12-31-2014, 08:40 AM
TightLines's Avatar
Hate to bump a very old thread but our TC32 LX70 won't turn on.
I can hear a high pitched whine when the TV is plugged in. Pressing the power button illuminates the light on the front of the TV as if it's turning on but then changes to a slow blink.
I googled both of the discussions below but neither seem to apply. There is no set number of blinks (counted up to 20) and since the screen will not turn on, I can't go about updating the firmware (have to follow on screen prompts).
http://www.justanswer.com/tv-repair/...ctly-when.html
http://www.fixya.com/support/t159207..._will_not_turn
Any ideas here? Hate to throw it out as it's seen very little use.
TightLines is offline
Reply LCD Flat Panel Displays
