Official Sony XBR4/XBR5 calibration thread - Page 12 - AVS Forum | Home Theater Discussions And Reviews
post #331 of 5496 Old 09-27-2007, 09:44 AM
OldPete's Avatar
Originally Posted by kozue25 View Post
Do I need special support on my receiver for 5.1 PCM or can all receivers that can handle pro-logic, DD, DTS etc. output 5.1 PCM because it uncompressed?
I've looked on Yamaha's site and don't see any special PCM specs listed on their newest receiver only the new HD audios.
Good question. Haven't seen anyone on the forum so far reporting success. There was some discussion on the owners thread, but the only test I recall was from someone trying it with the HDMI input. I was unable to test it myself because I can't get OTA signals from an antenna. Sony told me that the receiver would need to support PCM, and the specs for their new ones say "Accepts 8ch linear PCM." I've looked at various receiver specs and not seen clear statements about this.
Have you tried your receiver with the internal tuner?
Pete
OldPete is offline
post #332 of 5496 Old 09-27-2007, 12:59 PM
FCEEVIPER's Avatar
Okay guys I need help,
I'm a bit confused about which settings I should have for Motion Enhancer and Cinemotion when I'm watching HD over the air channels.
Please, please help me out. Thanks in advance.
"Some men aren't looking for anything logical.
They can't be bought, bullied, reasoned, or negotiated with.
Some men just want to watch the world burn."
Dark Knight Saga - 072012
FCEEVIPER is offline
post #333 of 5496 Old 09-27-2007, 01:58 PM
reemas's Avatar
Can anyone explain to the average person what cinemotion does and what the different modes are for? I'm not seeing a difference when swtiching. Does it depend on source content? Does it need to be used along with Motion Enchancer?
reemas is offline
post #334 of 5496 Old 09-27-2007, 02:31 PM
EADGBE's Avatar
That's the 64 million dollar question right now.
52XBR4
55HX929
EADGBE is offline
post #335 of 5496 Old 09-27-2007, 08:00 PM
vumcrab's Avatar
Check out post #269 in this thread. It's probably the best post related to cinemotion and motionflow I've read.
I believe most people say that they get the most benefit when watching 1080p/24 by setting cinemotion to auto1 and motionflow to standard. Most other times, leave cinemotion at auto2 with motionflow = standard.
Someone correct me if I'm wrong.
vumcrab is offline
post #336 of 5496 Old 09-27-2007, 08:25 PM
bplewis24's Avatar
Calibration Settings from the Cnet.com review of the 46XBR4:
http://help.cnet.com/9602-12576_39-0...sageID=2510365
Below you'll find the settings we found best for viewing the Sony KDL-46XBR4 in a completely dark room via the HDMI input with a 1080i source. Your settings may very depending on source, room conditions, and personal preference.
Picture Menu
Picture Mode: Cinema
Backlight: 7
Picture: 85
Brightness: 56
Color: 62
Hue: 0
Color temp: Warm2
Sharpness: 50
Noise reduction: Off
MPEG noise reduction: Off
DRC mode: Off
Advanced Settings
Black corrector: Off
Advanced C.E: Off
Gamma: Off
Clear white: Off
Color space: Standard
Live color: Off
Detail enhancer: Off
Edge enhancer: Off
White Balance Menu
R-Gain: 0
G-Gain: -4
B-Gain: 0
R-Bias: -1
G-Bias: 0
B-Bias: 0
Screen menu
Wide Mode: Full
Auto Wide: On
4:3 Default: Off
Display Area: Full Pixel
Video Options menu
Motion Enhancer: Off
CineMotion: Auto 1
Game/Text mode: Off
Video/Photo Optimizer: Video-A
Video Color Space: Auto
Photo Color Space: sYCC
Color Matrix: [N/A for HDMI]
RGB Dynamic Range: Auto
General Menu
Power saving: High
Light sensor: Off
Also a link to the actual review is in my post in the Owner's Thread:
http://www.avsforum.com/avs-vb/showt...9#post11750769
Brandon
bplewis24 is offline
post #337 of 5496 Old 09-27-2007, 10:37 PM
R.MnTnA's Avatar
Brandon
Nice find thanks Brandon!
R.MnTnA is offline
post #338 of 5496 Old 09-27-2007, 10:45 PM
R.MnTnA's Avatar
Here are my current settings after calibrating it with my Colorfacts Pro and Spyder 2. The white balance is pretty dead on to D65 white point. Remember that all Sony XBR's are not created equal. That is why I would recommend that anyone that wants to get the best picture from their XBR, get it calibrated either by me or a pro.
Picture Menu
Picture Mode: Custom
Backlight: 5
Picture: 79
Brightness: 48-52 depending on connection 52 for SD cable
Color: 55
Hue: 0
Color temp: Neutral
Sharpness: 70
Noise reduction: Low
MPEG noise reduction: Low
DRC mode: Off
Advanced Settings
Advanced C.E: Low
Gamma: Low
Clear white: Low
Color space: Wide
Live color: Low
Detail enhancer: Low
Edge enhancer: Low
White Balance Menu
R-Gain: -1
G-Gain: -1
B-Gain: -4
R-Bias: -1
G-Bias: -2
B-Bias: -3
Screen menu
Wide Mode: Full
Auto Wide: On
4:3 Default: Zoom
Display Area: -2
Video Options menu
Motion Enhancer: Standard or High
CineMotion: Auto 1
Game/Text mode: Off
Video Color Space: x.v.Color
Color Matrix: Default
General Menu
Power saving: Low
Light sensor: Off
R.MnTnA is offline
post #339 of 5496 Old 09-28-2007, 05:34 AM
EADGBE's Avatar
All I know is if you want to see something weird put on an HD movie (can even be from the Cable STB), set Cinemotion to Auto 1 and Motion Enhancer to High.
52XBR4
55HX929
EADGBE is offline
post #340 of 5496 Old 09-28-2007, 05:42 AM
EADGBE's Avatar
edit
52XBR4
55HX929
EADGBE is offline
post #341 of 5496 Old 09-28-2007, 05:47 AM
EADGBE's Avatar
edit
52XBR4
55HX929
EADGBE is offline
post #342 of 5496 Old 09-28-2007, 05:58 AM
slumpey326's Avatar
anyone try cnet's settings yet, how are they,
slumpey326 is offline
post #343 of 5496 Old 09-28-2007, 07:05 AM
grtwhtsk's Avatar
What are most people setting for Motion Enhancer and Cinemotion? I am a total newbie, and so any help would be greatly appreciated. I just want to truly get the best experience from watching my 46XBR4. If you have different settings for movies, hd, sd, gaming, etc., please post those as well. Thanks in advance for your help.
grtwhtsk is offline
post #344 of 5496 Old 09-28-2007, 08:55 AM
OldPete's Avatar
The brightness and color are significantly different from what I got using Avia test patterns, and we don't like Warm2 at all. I like R.MnTnA's settings much better.
Pete
OldPete is offline
post #345 of 5496 Old 09-28-2007, 09:02 AM
OldPete's Avatar
Originally Posted by grtwhtsk View Post
What are most people setting for Motion Enhancer and Cinemotion? I am a total newbie...
See the posts at the top of the page. Very impressive that vumcrab can see in the future and answered the question before it was asked.
OldPete is offline
post #346 of 5496 Old 09-28-2007, 09:57 AM
kozue25's Avatar
Picture Menu
Backlight: 5
Picture: 79
Color: 55
Hue: 0
Color temp: Neutral
Sharpness: 70
DRC mode: Off
Advanced Settings
Advanced C.E: Low
Gamma: Low
Clear white: Low
Color space: Wide
Live color: Low
Edge enhancer: Low
White Balance Menu
R-Gain: -1
G-Gain: -1
B-Gain: -4
R-Bias: -1
G-Bias: -2
B-Bias: -3
Screen menu
Wide Mode: Full
Auto Wide: On
4:3 Default: Zoom
Display Area: -2
Video Options menu
CineMotion: Auto 1
Game/Text mode: Off
General Menu
Power saving: Low
Light sensor: Off
Do you think that running this config for BD playback on a PS3 is optimal or should something be tweaked for that?
If I put this same settings in Cinema mode, will it be different than custom? (I am running custom config for games)
kozue25 is offline
post #347 of 5496 Old 09-28-2007, 10:15 AM
God_TM's Avatar
Well... I have a Sony engineer calling me back within an hour, re: what's the techincal difference between Cinemotion Auto1 and Auto2 (and Motionflow for that matter). Maybe we'll get some non-marketing material answers soon...
God_TM is offline
post #348 of 5496 Old 09-28-2007, 10:21 AM
reemas's Avatar
in vivid mode the image is very bright and clear (although overdone).
why cant this level of brightness be acheived in other modes, like standard or cinema, even after pushing the backlight and picture settings to max??
reemas is offline
post #349 of 5496 Old 09-28-2007, 12:22 PM
God_TM's Avatar
(sort of, but not really anything you don't already know)...
Here's the response I got from Sony... doesn't get into too much technical detail unfortunately:
Below is a brief description of reverse 3-2 pull down technology. Sony's CineMotion adds some additional algorithms to this.
The Auto 1 and Auto 2 settings use these different algorithms. Our engineers told me it is just a matter of preference as to which setting you use.
I have also attached a short Power Point on Sony's Motion Flow technology (Motion Enhancer).
Some video and animation has a shutter or vibrating feel to it and the standard setting smoothes this out.
The high setting is there because some film requires more enhancements to give the video more of a cinematic feel. Again, this setting is a matter of preference and only discerning viewers can really tell the difference between the two settings.
I hope this has been of some help to you.
CineMotion® Reverse 3-2 Pull-Down Technology
Sony's term for a TV circuit that detects a 3-2 Pull-Down sequence and performs the reverse or inverse operation. When film studios release their work on TV, DVD, or videotape, they have to transfer film (which runs at 24 frames per second) to video (which runs at 30 frames per second). How do you get 24 into 30 without speeding up the film? Well, first take note that video actually flashes 60 half frames, called "fields," per second because of its interlaced scan. The film studio has a machine (telecine) that takes one film frame and transfers it to three video fields, then takes the next film frame and transfers it to two video fields-thus 3-2. The technology makes it possible to watch films at home, but creates imperfections and subtle speed shifts in the movie. A Reverse 3-2 Pull-Down circuit looks at the video as it's coming through the television, and in a split second rearranges the fields into whole film frames like completing a puzzle. The surprising thing is that the TV's circuit doesn't have to interpolate, or guess, how the film frames actually started out; it has all the necessary clues and can re-create the film perfectly. Sony's CineMotion® technology takes additional steps to make the image as close to the original film as possible.
Obviously, they're using different algorithms for Auto1 and Auto2, but that's all I could get out of them... Perhaps they're proprietary, and perhaps Sony has some patents on them that explain it in detail, but good luck sifting through all that information.
The powerpoint presentation just explains a bit about what MotionFlow does... I found a copy of it online (as it's too big to post here): http://www.brownbucket.com/buckets/j...Motionflow.ppt
God_TM is offline
post #350 of 5496 Old 09-28-2007, 01:01 PM
CDJayRFU's Avatar
"anyone try cnet's settings yet, how are they"
I love them, personally. Am now finally happy w/ my X3500
Excellent black levels/detail, natural and accuate seeming colours, bright and vivid when called for.
I doubt they're "perfect", but they're a damn sight closer to what I want to see than any other settings I've tried.
Seemed spot on for my 360 using the Halo 3 Limited Edition A/V calibration disc as far as contrast and colour accuracy went. Whilst I also liked R.MnTnA's settings also, the colour section was off compared to the cnet ones w/ this source/test.
CDJay
CDJayRFU is offline
post #351 of 5496 Old 09-28-2007, 01:05 PM
grtwhtsk's Avatar
I didn't realize that vumcrab spoke for "most people." Sorry, couldn't help myself.
grtwhtsk is offline
post #352 of 5496 Old 09-28-2007, 01:43 PM
vumcrab's Avatar
Actually, I speak for everybody, it's just that some of them don't want you to know that I do.
vumcrab is offline
post #353 of 5496 Old 09-28-2007, 01:53 PM
grtwhtsk's Avatar
In that case, you're the guy I'll ask. Do you use separate settings for the motion enhancer and cinemotion for SD, HD, BD, DVD, etc., or do you stick with more of an Overall setting?
Thanks again vumcrab.
grtwhtsk is offline
post #354 of 5496 Old 09-28-2007, 02:48 PM
vumcrab's Avatar
My 52xbr5 comes in tomorrow, but at first, I'll only have it connected to SD/HD via Comcast cable. I'm getting the PS3 a little closer to xmas for BD stuff. A buddy of mine has the 46xbr4 and he uses cinemotion=auto1 motionflow=standard for 1080i content on his HD DVD and auto2/standard-high for cable. On his HD DVD, auto1 does smooth the picture out by getting rid of the judder, but I'm not sure that's what I'll end up doing with my 52". I can't decide if I like it or not.
It seems that a lot of people are struggling with these two settings together and the post I pointed you to was something I had ear-marked for myself to use when my set gets in. Did you read the post above by God ? Seems Sony is saying it comes down to a personal preference. I guess just about every setting does.
Otherwise, how's the color on your set?
vumcrab is offline
post #355 of 5496 Old 09-28-2007, 02:50 PM
OldPete's Avatar
I apologize for getting snarkey. The subject has been discussed extensively on the owners thread as well as this one.
Many thanks!
OldPete is offline
post #356 of 5496 Old 09-28-2007, 03:08 PM
R.MnTnA's Avatar
I wish I could tell you I would have to see it myself to really tell you. My guess would be that the following should be turned OFF for BD and Games since it's in HD-
Noise reduction:
Detail enhancer:
Edge enhancer:
Also I think the PS3 can be changed to output Full Range RGB
My Pioneer DVD player has this as well and I have it set to Full
So I set the RGB Dynamic Range on the XBR to Full and it looks awesome. I would give it try and see if it improves the color of the movies and games.
If you put those settings in Cinema mode some of the settings will be grayed out and you won't be able to select them.
R.MnTnA is offline
post #357 of 5496 Old 09-28-2007, 03:17 PM
R.MnTnA's Avatar
CDJay
Yes the color section probably would be a little off for that A/V disc. Not sure about that disc, but I used the AVIA Pro discs when I calibrated mine. Also I would try turning Off Live Color if you don't like the colors and maybe switch Color space to Standard. Again it's really comes down to personal preference at the end of a calibration.
R.MnTnA is offline
post #358 of 5496 Old 09-28-2007, 03:21 PM
FCEEVIPER's Avatar
Noise reduction:
Detail enhancer:
Edge enhancer:
Hi,
What would you recommend for 1080i Over-The-Air channels? Detail enhancer, Edge enhancer settings they should be?
post #359 of 5496 Old 09-28-2007, 03:58 PM
schlick's Avatar
So i dialed in my 46/4 for upscaled dvd playback via the oppo 981. Little did i know, that the wide/standard colorspace option would burn me as bad as it did. Using Avia, cal'd for the usual (contrast, brightness saturation, and hue) played with the advanced settings until I thought i had achieved a reasonable picture. Then started watching movies (I'm a format war holdout). Looked beautiful. REcently started noticing horrible green push in scenes with limited luminance, particularly chapter 18 in ghostrider. Rechecked black and white balance, saturation and hue, and came up with near identical results. Chapter 18 again, looks the same, if not worse (possibly my eyes playing tricks). Reseat the hdmi connection on both ends, ch. 18 still no improvement. Tried different hdmi cable, no change. Check ch 18. in another non upscaling player connected via component, seems to look as I would expect it too (no excessive green push). Disconnect ac source to Oppo, wait and then try again. Still no change. Recheck with Avia, all is well. Scratching my head as the grayscale patterns on avia don't exhibit this green push. I probably should have tried a different Hdmi input on the set at this point, but I know things didn't look like this initially 4+ weeks ago. Avia being no help at this point, I took the scene where the Ghostrider is on top of the bridge strut and paused it, and systematically went through the settings for what seemed to be the 10th time, but this time with content as opposed to test patterns. Got to colorspace (which I must have changed to wide at some point, but don't really recall). Switched back to standard and the green push disappeared.
So my point is, although you can calibrate using a test disc with the display's colorspace set wherever you want, the push I speak of won't show up in test patterns (as they are mostly static), only playback of encoded media content. I came within a breath of sanity, to learn this. Hope it helps someone else.
Schlick
schlick is online now
post #360 of 5496 Old 09-28-2007, 04:22 PM
R.MnTnA's Avatar
Originally Posted by FCEEVIPER View Post
Hi,
Well since my cable is going directly into my TV which also picks up HD and SD, I just leave it on Low. I don't think you can see much difference in HD, at least I can't.
R.MnTnA is offline
Reply LCD Flat Panel Displays
Sony Bravia Xbr Kdl 52xbr4 52 Inch 1080p Lcd Hdtv , Sony Bravia Xbr Series Kdl 52xbr5 52 Inch 1080p Lcd Hdtv , Lcd Hdtv , Sony Bravia Xbr Kdl 32xbr4 32 Lcd Hdtv
