Official Sony XBR4/XBR5 calibration thread - Page 34 - AVS Forum | Home Theater Discussions And Reviews
Old 11-13-2007, 01:01 PM
vumcrab's Avatar
Guys,
I don't know if you've been following the discussion on the WB settings over in the owner's thread, so I thought I would post the findings here since that's really where they belong.
Yesterday, myself and another poster here reported losing WB settings between different picture_mode settings (i.e. Cinema, Standard and Custom). That is, I would apply changes to my WB settings in Custom mode, then noticed that they had been replicated over in Cinema and Standard. The previous settings I had in Cinema and Standard were lost. All of this is on the same input, HDMI 1.
Bricklayerharp tested it on his set and jrnewquist found what was causing the problem. The illusion regarding WB settings is that you have an independent WB setting for each picture_mode. This appears to be incorrect. These xbrs, in fact, have a WB setting for each color_temp. IOW, if you make your settings in Custom picture mode and the color_temp is Warm_2, then any other picture mode you use that specifies Warm_2 will share the same WB settings as Custom picture mode.
For example, if you setup Custom picture_mode to use a Warm_2 color temp and then setup Cinema and specify Warm_2 there as well, Cinema mode will use the WB settings you specified for Custom because they both share the Warm_2 setting.
If folks already knew this, I apologize. I thought it would be worthwhile to share because, speaking for myself, I thought I had WB settings for each independent picture mode. That's not the case.
vumcrab is offline
Old 11-13-2007, 01:08 PM
Javatango's Avatar
Fantastic information on WB settings Randy, thanks. And big kudos to jrnewquist for the Google spreadsheet.
Javatango is offline
Old 11-13-2007, 01:51 PM
FCEEVIPER's Avatar
Originally Posted by lrstevens421 View Post
Now that it's done I must admit that I do like it. Because of prior experiences I wasn't too enthusiastic about calibration but this worked out for the better. Working in the industry I've seen a lot of displays, this is one of the good ones .
10 1/2 Feet from Display
Power Save Mode: Off
HDMI Sources
Mode: Cinema
Backlight: 3
Picture: 88
Brightness: 49
Color: 62
Hue: 0
Sharpness: 50
Color Temp: Warm 2
Noise Reduction: Off - 1080p / Low - Cable
Mpeg Noise Reduction: Off
DRC: Off
Black Corrector: Off
ACE: Off
Gamma: Off
Clear White: Off
Color Space: Standard
Live Color: Off
White Balance:
Red Gain: -1
Green Gain: -4
Blue Gain: 0
Red Bias: 0
Green Bias: -3
Blue Bias: 0
Detail Enhancer: Off / Low (Personal Preference)
Edge Enhancer: Off
Motion Enhancer: Off with 1080p24. Standard for 1080p60 (Personal preference) - Mines is off
Cinemotion: Auto1
Video Color Space (x.v.color): Off
Color Matrix: Auto
Game/Text: Off
Light Sensor: Off
Display Area: Full Pixel
Component Video Sources
Mode: Cinema
Backlight: 3
Picture: 85
Brightness: 37
Color: 52
Hue: 0
Sharpness: 50
Color Temp: Warm 2
DRC: Off
ACE: Off
Gamma: Off
Clear White: Off
Live Color: Off
White Balance:
Red Gain: -1
Green Gain: -4
Blue Gain: 0
Red Bias: 0
Green Bias: -2
Blue Bias: 0
Edge Enhancer: Off
Motion Enhancer: Off / Standard (Personal preference) - Mines is off
Cinemotion: Auto1
Color Matrix: Auto
Game/Text: Off
Light Sensor: Off
Display Area: Full
Tell me what you think.
Took them 2 hours
Awesome post!
I will try this tonight, Thanks for posting your settings!
"Some men aren't looking for anything logical.
They can't be bought, bullied, reasoned, or negotiated with.
Some men just want to watch the world burn."
Dark Knight Saga - 072012
FCEEVIPER is offline
Old 11-13-2007, 01:54 PM
Bullet94's Avatar
Originally Posted by Teisco View Post
Has anyone gone from a Sharp Aquos 52 to the new xbr4 or 5? I have the Aquos and thinking of trading up if there is a dramatic dif in pic.
I had the Sharp 46" D92U, and now have the 46" XBR5. The Sony is a better set then the Sharp.
"Hence we will not say that Greeks fight like heroes, but that heroes fight like Greeks." - Winston Churchill
Bullet94 is offline
Old 11-13-2007, 01:55 PM
fuzzymyman's Avatar
Originally Posted by vumcrab View Post
Guys,
I did notice this but did not know what the issue was. Thanks.
fuzzymyman is offline
Old 11-13-2007, 02:19 PM
vumcrab's Avatar
No probs, Java.
Now I have to figure out....If I have two calibrations that call for Warm2, can I use Warm1 for one of them and compensate elsewhere in the settings to make up the difference. To me there's a big difference in each step from Cool->Neutral->Warm1->Warm2.
I'd like to have whatever the Sony engineers were smoking when they came up with this one.....
vumcrab is offline
Old 11-13-2007, 02:58 PM
fuzzymyman's Avatar
Just a couple of things all.....I have the 46" Xbr4 and would like to know what the preferred settings are for the Wii. The other question I have pertains to the cloudiness I got when watching the football game last weekend. In the middle of my screen I could see a 1' X 4" vertical smudge or cloud which blurred the middle of the screen slightly. This was not constant. Any suggestions? Thanx
Old 11-13-2007, 03:49 PM
bkb31's Avatar
Mr pasta love your setting would you use them also for hd dvd?
bkb31 is offline
Old 11-13-2007, 04:47 PM
normandy7's Avatar
Does anybody know why when I turn on game mode, the picture mode switches from standard to custom? Custom is then grayed out so that it cant be switched back to standard with game mode enabled. Has anyone else experienced this
normandy7 is offline
Old 11-13-2007, 06:54 PM
redst1300's Avatar
No probs, Java.
haha Randy I agree it's not intuitive at all. From the menu, one would think differently.
One note, if anyone wants to try 2 diff settings that use say "warm2", it's probably easiest to note what the WB settings are, then enter those to "go back and forth" to compare. Kindof a pia, but hey, we're stuck...
Lastly, I was fiddlin with cinema settings, which I forgot are "warm2" and selected "set to default" on the WB. Well my custom was MrLogs settings (also warm2) and wow, really made the colors look better to my eye, after switching back to custom (the default on cinema for wb is to set it all to "0").
regards,
redst1300 is offline
Old 11-13-2007, 06:57 PM
slumpey326's Avatar
redst1300, what does WB stand for
slumpey326 is offline
Old 11-13-2007, 07:07 PM
lrstevens421's Avatar
White Balance
Making the most out of what I got.
lrstevens421 is offline
Viking 29's Avatar
Quoted: 174 Post(s)
Liked: 70
Originally Posted by bplewis24 View Post
Awesome work. Thanks for taking the time to do that. That sorta confirms what I've been thinking: I'm the only one who uses Warm1 color temperature. Has anybody else tried it and not liked it for whatever reason?
Brandon
Hey Brandon, I use warm1 as well. I love it personally, and like a wise man said a few posts back as long as you like it is all that matters. Cool seems a little too blue for my tastes and warm 2 a little too red. Of course, all the other settings in conjunction make a difference.
Viking 29 is offline
Old 11-14-2007, 06:13 AM
bleedblue63's Avatar
Most of what I watch is HD via DirecTV on a 52XBR4. I tried some of the settings on this thread and had mixed results. I like a nice crisp picture that is not overly smooth like film. I want natural colors with little or no over saturation. Please let me know if you try these settings and if you modified anything. I was very impressed with the PQ last night after I did this. I have to say the quality was better than what I could get on my XBR3. Here is what I came up with for my H20 receiver:
Custom: DirecTV H20 via HDMI
Backlight: 5
Picture: 76
Brightness: 52
Color: 55
Hue: 0
Color Temperature: Neutral
Sharpness: 30
Noise Reduction: low
MPEG Noise Reduction: off
DRC Mode: 1 : Pallett 40/60
Black Corrector: off
Advanced C.E.: low
Gama: low
Clear White: off
Color Space: wide
Live Color: Low
White Balance
R-Gain: 0
G-Gain: 0
B-Gain: 0
R-Bias: 0
G-Bias: 0
B-Bias: 0
Detail Enhancer: off
Edge Enhancer: off
Motionflow: Standard
Cinemotion: Auto2
Nothing is perfect if you look hard enough.
bleedblue63 is offline
Old 11-14-2007, 08:08 AM
fuzzymyman's Avatar
still waiting
Old 11-14-2007, 08:55 AM
vumcrab's Avatar
still waiting
I just performed a search on this thread for "wii" and got several hits for calibration.
As for the football game, were you watching SD or HD and on what network? Was the smear on the screen noticable on other channels. Was it raining at the football game? Was the smear noticable from only one particluar stationary camera or all cameras in the stadium? Was it a hand-held camera?
I watch a bunch of football on tv. A bit more info will help.
vumcrab is offline
Old 11-14-2007, 09:05 AM
jamjat's Avatar
Hello: Been reading posts and have really benefited from all of the wonderful knowledge on this site. Thank you all. Hope I’m posting this question in the right area. I was wondering if some one could tell me why my SD reception is noticeably better (sharper and better color) when I tune to digital channel on my 52XBR4 directly (ESPN is 90.7 in my area) than when I bring the same signal into my TV through component jacks from my STB. Is there an up converting that’s happening with coax directly into back of xbr4 that does not happen with component cables, or is my Motorola STB just “not that good”? Not huge problem, but I really knowing where my channels are, and I like the TV guide features of my STB. Issue is not noticeable at all with HD signals. Thanks again and in advance.
jamjat is offline
Old 11-14-2007, 09:52 AM
Agent_C's Avatar
Backlight: 5
Picture: 76
Brightness: 52
Color: 55
Hue: 0
Sharpness: 30
Advanced C.E.: low
Gama: low
Clear White: off
Color Space: wide
Live Color: Low
White Balance
R-Gain: 0
G-Gain: 0
B-Gain: 0
R-Bias: 0
G-Bias: 0
B-Bias: 0
Edge Enhancer: off
Cinemotion: Auto2
These settings are virtually identical to mine. I would point out though, that keeping Cinemotion set to Auto2 disables Motionflow.
A_C
Manhattan Supremacist
Agent_C is offline
Old 11-14-2007, 10:03 AM
bigjohns1997SS's Avatar
Originally Posted by jamjat View Post
Hello: Been reading posts and have really benefited from all of the wonderful knowledge on this site. Thank you all. Hope I'm posting this question in the right area. I was wondering if some one could tell me why my SD reception is noticeably better (sharper and better color) when I tune to digital channel on my 52XBR4 directly (ESPN is 90.7 in my area) than when I bring the same signal into my TV through component jacks from my STB. Is there an up converting that's happening with coax directly into back of xbr4 that does not happen with component cables, or is my Motorola STB just not that good? Not huge problem, but I really knowing where my channels are, and I like the TV guide features of my STB. Issue is not noticeable at all with HD signals. Thanks again and in advance.
Set your STB to allow all resolutions through and pass-through whatever resolution it's being fed. With me doing this my channels looks better through the STB rather than Intergrated Tuner.
Samsung D7000 65"
Onkyo 809
BIH F12
6x Energy RC-10
WMC ceton4 DVR/Media PC
bigjohns1997SS is offline
Old 11-14-2007, 11:04 AM
sciolist's Avatar
Ok I've read through this and the owners thread. Let's see if my understanding of 1080p/24 with 5:5 is correct.
Pulled from an OldPete post, not sure of it's origins.
Cinemotion
AUTO1: Has film compensation turned ON and works in conjunction with the Motion Enhancer setting. The CineMotion effect changes depending upon the setting of the Motion Enhancer.
AUTO2: Has film compensation turned ON and turns OFF the Motion Enhancer setting.
So is "film compensation" 3:2 pulldown, and if so does turning it off provide for 5:5?
Is ME the on switch for 120 Hz, or is it simply that the TV is always 120 Hz and ME is just the motion corrector?
I'm currently under the assumtion that for 1080p/24 source cinemotion does detection and does not apply 3:2 pulldown. And, that ME is not a switch for 120 Hz, but simple a control for the the level of enhancment in the processing.
Anyways, I know this has been discussed countless times, but I just can't seem to put my fingers on a straight answer. Hopefully someone can just say to me, "Hey dumba**, 3:2 is x setting, and 5:5 is y setting." Somehow I doubt it's going to be that simple.
sciolist is offline
Old 11-14-2007, 12:51 PM
jamjat's Avatar
Thank you very much for quick reply. I will see if it's an option and try it tonight. will post answer tomorrow.
jamjat is offline
Old 11-14-2007, 12:59 PM
vumcrab's Avatar
I don't know which STB you have. I have the Motorola 3416 and the default for SD/4:3 output from the box is 480i. You have choices of 480i (default), 480p, 1080i Stretch, and 1080i letter box.
To get to the settings menu, turn OFF the STB, then press "MENU" on the remote and you're in. Once you've made your changes, hit the power button on the STB remote twice (once to get out of settings mode and once to turn the STB back on) and you're back in business.
vumcrab is offline
Agent_C:
Does that mean I'm turning off the 120 Hz refresh rate when in Auto 2 mode? The manual doesn't say that. To be honest I haven't tried Auto 1 yet. Is that what you use and if so what results have you noticed? I watch a lot of hockey and football so the 120 Hz is not something I want to bypass. I really like these settings. Thanks.
Old 11-14-2007, 04:25 PM
Agent_C's Avatar
Agent_C:
Take a look at this post:
http://www.avsforum.com/avs-vb/showt...6#post11791506
Agent_C is offline
Old 11-14-2007, 04:43 PM
OldPete's Avatar
Excellent!
Looks to me like you've got it.
Sounds right to me.
I think that you can say:
5:5 for 108024p source is any setting
3:2 for film(or original 24fps source) at 60hz is Cinemotion Auto1 or Auto2.
Given the Fog of Forum and Sony's terse documentation, it hasn't been simple.
Agent_C:
The only thing you're turning off in Auto 2, I believe, is the motion enhancement for 24fps source material. The reason to use Auto 2 would be if you like the motion enhancement for sports, but not movies. This was my summary awhile back, which I think still may be correct:
  • You like M.E. for TV, but not for movies: Use Auto2. If you like the same M.E. setting for all TV, you don't have to change anything.
  • You like M.E. for movies: Use Auto1. If you don't like your movie M.E. settings for TV, then change the M.E. depending on what you're watching.
Finally, want to bring one of Brandon's comments back:
What gets lost in all this hubub about whether or not the Sony does 5:5 pulldown is that, if you like what you see then go for it. In theory, we all want the best possible picture. What some purists want is 24fps without interpolated frames. Motion Enhancer interpolates frames to give us better handling of motion. If you like the results Motion Enhancer brings then toy with Standard or High and go with which one you prefer. If you prefer the more traditional film-like look without 3:2 judder, then yes, for blu-ray ME can be set to off (or cinemotion=auto2 which disables it).
In the end, we as end users have the choice, which is why the discussion started in the first place. If we want 5:5 pulldown with no interpolation (and thus no possibility of motion artifacts) we have that option, and if we want frame interpolation (reducing motion blur and giving more of a video-like feel) then we have that option as well. That's the important thing.
OldPete is offline
Old 11-14-2007, 05:00 PM
FCEEVIPER's Avatar
Originally Posted by FCEEVIPER View Post
Awesome post!
Never mind, I see you have a 50''.
I have the 40''.
Old 11-14-2007, 05:41 PM
tdhac's Avatar
I'm not sure if this helps? It's from the December issue of Sound&Vision review of the
52XBR5.
Finally, there's the Motion Enhancer, with Standard, High, and Off settings. When off, the TV simply repeats each video frame in a 60-Hz HDTV signal to fill out its 120-Hz refresh rate. When switched on, the Motionflow processing detects whether a source is film- (24 fps) or video-based and interpolates the required new frames instead of just repeating existing ones.
tdhac is offline
Old 11-14-2007, 07:39 PM
sciolist's Avatar
Thanks OldPete!
It's good to have confirmation on this, now I can stop worrying about it and go and enjoy some movies.
sciolist is offline
Old 11-14-2007, 08:45 PM
Captain Sid's Avatar
After looking at everyone's settings, I just had some quick comments and questions.
The purpose of video calibration is to coax your television into reproducing an image as close as possible to the way the original source material was intended to be shown.
With that in mind, anyone serious about seeing the true quality of the original signal should never have Noise Reduction, DRC, Black Corrector, Advanced C.E., Gamma, Clear White, Detail Enhancer, and Edge Enhancer set to anything but OFF for any 720 or 1080 source.
Some of these settings can sometimes help a bad signal (SD cable/sat, antenna, etc.) appear better, and others are just clumsy shortcuts to a result that could better be achieved by properly adjusting other settings.
You may think they improve the signal, but doing things like sharpening edges by artificially accentuating color transitions and contrast is more damaging than it is helpful. To the untrained eye, bright, sharp colors look impressive. That's why these are set to VIVID by default. But as we all know, this is the most affected and inaccurate setting, and nobody should use it. Ever.
I'm not at home, but the settings on my 46" XBR4 are nearly identical to the ones lrstevens421 posted. I have noticed that the black level is much deeper on the PS3 system menus and games than it is on DVDs and Blu-Rays, so I set the brightness higher on the Cinema setting for that HDMI input and use it instead of the Custom when watching movies.
Also, no matter what I do I can't get the Nintendo Wii to look very good on this set. It looked way better on my old 36" Wega. Anybody had any luck? Too bad Nintendo didn't have the foresight to at least have the Wii output 720p...
Captain Sid is offline
Old 11-15-2007, 01:09 AM
Wooterz's Avatar
Could these calibration settings be applied to the V-series/W-series Sony sets such as the 40V3000 and the 40W3000 or would the picture come out off?
Wooterz is offline
Sony Bravia Xbr Kdl 52xbr4 52 Inch 1080p Lcd Hdtv , Sony Bravia Xbr Series Kdl 52xbr5 52 Inch 1080p Lcd Hdtv , Lcd Hdtv , Sony Bravia Xbr Kdl 32xbr4 32 Lcd Hdtv
