Official Sony XBR4/XBR5 calibration thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5496 Old 08-19-2007, 09:00 PM - Thread Starter
niksem's Avatar
I think it is time. Please, post the type of TV you got: 32", 40", 46, or 52" and settings you use. It would also be helpful if agree what kind of channels/HD sources/movies types to turn Cinemotion on or off.
Wiki Calibration link.
http://tjexbr.wiki.zoho.com/HomePage.html
niksem is offline
post #2 of 5496 Old 08-19-2007, 10:30 PM
axmode's Avatar
LOL.
If you start an "official" calibration thread, don't forget to actually post your own calibration settings.
Just a thought
Samsung: 52" 850 / 46" 61 / 40" 61 / PS3 / BD-P1500 / A3 HD-DVD / Format Neutral
axmode is offline
post #3 of 5496 Old 08-19-2007, 10:34 PM - Thread Starter
niksem's Avatar
i will update
niksem is offline
post #4 of 5496 Old 08-20-2007, 12:45 AM - Thread Starter
niksem's Avatar
well, now it is the only xbr4/5 thread
niksem is offline
post #5 of 5496 Old 08-20-2007, 01:22 PM
poiv3's Avatar
Looking forward to seeing some good settings, though I think it will be a while before enough people get their tvs and do some serious calibrations.
P.S. Settings from XBR2/3 thread seem to be quite off for this new generation.
poiv3 is offline
post #6 of 5496 Old 08-20-2007, 03:13 PM
coma426's Avatar
Here are the settings I came up with for my 52" XBR4 after running the Avia calibration dvd.
HDMI Settings (BD playback via PS3)
Picture Mode: Custom
Backlight: 4
Picture: 72* (initially set at 55, upon further testing set to 72)
Brightness: 52
Color: 57
Hue: 0
Color Temperature: Neutral
Sharpness: 30
Noise Reduction: Off
Advanced Settings
White Blance:
R-Gain: 0
G-Gain: -5
B-Gain: -5
R-Bias: 0
G-Bias: -5
B-Bias: 0
Color Space: Standard (Setting to Wide may require further dialing of R-G-B Bias and Gain as it tends to emphasize G and B)
Detail Enhancer: High
Everything else set to Off
(Setting Detail Enhancer to High results in some extremely sharp detail on live action BD material)
Motion Enhancer: set to Off for most BD material, set to High for SD cable
coma426 is offline
post #7 of 5496 Old 08-20-2007, 03:16 PM
slumpey326's Avatar
I think your settings were great come426
slumpey326 is offline
post #8 of 5496 Old 08-20-2007, 04:16 PM
edwyun's Avatar
thanks coma. gotta get home to try those settings. have you fooled around with the DRC Mode at all?
edwyun is offline
post #9 of 5496 Old 08-20-2007, 04:45 PM
coma426's Avatar
Haven't done any tests with the DRC mode yet. I have it turned off so far.
coma426 is offline
post #10 of 5496 Old 08-20-2007, 07:19 PM
HD-Gaming's Avatar
looking forward to trying coma's setting out tomorrow
but my question is will this settings be good for when playing games also?( on both the 360 and ps3?
PSN: Unbreakable21
XBL: xgho5tx
HD-Gaming is offline
post #11 of 5496 Old 08-21-2007, 08:30 AM
edwyun's Avatar
Coma:
The settings worked pretty well. Perhaps slightly too bright for my tastes but other than that, excellent!
edwyun is offline
post #12 of 5496 Old 08-21-2007, 10:18 AM
coma426's Avatar
Edwyun:
think maybe my initial settings were more accurate? I originally had picture set to 55. I think during the daytime with ambient light present a higher picture setting works well but last night watching a movie I felt some eye fatigue as well and dropped it back down to 55. Have you done any tweaks from my settings? I'm still trying to dial it in a bit more myself.
coma426 is offline
post #13 of 5496 Old 08-21-2007, 11:04 AM
HD-Gaming's Avatar
Originally Posted by coma426 View Post
Edwyun:
how do you feel these settings are with gaming?
PSN: Unbreakable21
XBL: xgho5tx
post #14 of 5496 Old 08-21-2007, 11:08 AM
gordong11's Avatar
I finally got mine 30 mins ago will be posting pictures. Looks great. No clouding, no dead pixels, no banding do far. Only hooked up to my XA2 right now.
It's all about 1080P/24 & HD audio
Toshiba HD-XA2
Panasonic DMP-BD30K
Sony KDL-40XBR4
Elite VSX-92TXH (w/7.1)
gordong11 is offline
post #15 of 5496 Old 08-21-2007, 11:13 AM
edwyun's Avatar
Wish I could right now - I'm at work
What I did was use your settings as posted but just turned on "black corrector". it worked well but didn't have time to fiddle any more or check if it was making things too dark.
That DRC palette control looks interesting...
edwyun is offline
post #16 of 5496 Old 08-21-2007, 11:53 AM
MikeDaMan's Avatar
Hi, Coma426 I used your settings for my PS3 and 360. There PERFECT!. I'm using this on a XBR3 by the way.
MikeDaMan is offline
post #17 of 5496 Old 08-21-2007, 12:12 PM
coma426's Avatar
I thought they were good but I only ran the Dirt and Heavenly Sword demos with those settings. (picture set to 55) and didn't have gaming mode turned on. No motion artifacts, just some screen tearing on Heavenly Sword but that's inherent to the demo and not something introduced by the TV.
Also, I started messing around with the DRC settings last night while watching HBO. I'll keep messing with it and post if I think I can get a better picture with it tweaked properly or if its better to have it turned off.
Would've been nice to have two cable inputs on this set. Then I could just use PBP to see the difference while I adjust settings using the same source / different inputs.
coma426 is offline
post #18 of 5496 Old 08-21-2007, 03:06 PM
bogmancometh's Avatar
If someone can post their HDMI connection settings for this tv through Motorola 3416 Comcast box I would appreciate it
bogmancometh is offline
post #19 of 5496 Old 08-21-2007, 05:23 PM
Alex the Great's Avatar
Thank you to share your settings.
Do you have a STB settings? I found it difficult if not impossible to have a common settings for SD and HD channels.
Would be nice to hear your advise on Video Option settings as well.
FYI: I have 3250HD STB connected to HDMI post #1.
Alex the Great is offline
post #20 of 5496 Old 08-21-2007, 05:41 PM
coma426's Avatar
Originally Posted by Alex the Great View Post
Thank to share your settings.
I agree. I adjusted my HD settings and then used them for SD and they need quite a bit of dialinlg for SD to look natural.
Here's a question which possibly nobody can answer. If you're watching HD and SD at the same time using PBP, are you effectively seeing both picture settings at the same time? If so, it would be possible to have a movie playing from HBO on demand (or some other channel) via cable and the same movie via DVD or Blu-ray HD-DVD and dial the pictures together. I think it would require hitting the HOME button to do the dialing on the correct input, and quite a bit of back and forth between dialing and viewing the content PBP but it would be better than just guessing. Anyone care to give it a shot?
coma426 is offline
post #21 of 5496 Old 08-21-2007, 06:06 PM
Looking forward to see your settings after professional calibration. Hopefully you will be able to do it for different inputs and feedings.
Best of luck,
AG
post #22 of 5496 Old 08-21-2007, 09:31 PM
HD-Gaming's Avatar
Backlight: 4
Brightness: 52
Color: 57
Hue: 0
Sharpness: 30
Advanced Settings
White Blance:
R-Gain: 0
G-Gain: -5
B-Gain: -5
R-Bias: 0
G-Bias: -5
B-Bias: 0
what's wrong with having motion flow on? how is it worse?
PSN: Unbreakable21
XBL: xgho5tx
post #23 of 5496 Old 08-21-2007, 09:45 PM
bpmurr's Avatar
Quoted: 125 Post(s)
Liked: 87
Backlight: 4
Brightness: 52
Color: 57
Hue: 0
Sharpness: 30
Advanced Settings
White Blance:
R-Gain: 0
G-Gain: -5
B-Gain: -5
R-Bias: 0
G-Bias: -5
B-Bias: 0
I tried these out and I'm with on everything but the white balance. That is pushing red.
75X850C l 65B6P l P55-C1 l SB4551-D5 l XB1 S l PS4 Pro l LIVE:BPMURR l PSN:BPMURR
bpmurr is offline
post #24 of 5496 Old 08-22-2007, 09:52 AM
coma426's Avatar
I found that watching BD from the PS3 motionflow and cinemotion weren't necessary. With motionflow set to standard or high (while watching 24p BD) there is some artifacting along edges of moving objects. If an arm waves across the screen you might see a sort of rippling effect on the trailing edge of the arm. That is with cinemotion turned off. With it set to Auto2 and motion flow to high I didn't notice it very much at all. I'll do some tests setting cinemotion to Auto2 and motionflow to standard and to high on some fast moving material on Casino Royale tonight and report back, but I think that those settings are better suited to non BD material as the playback with them both turned off was silky smooth. On SD material those settings can smooth out the image nicely.
As for my gamma and bias settings, I agree that its pushing red. I think I had colorspace set to wide when I did my calibration and wide seems to push yellow and green. I think lowering red and green some (maybe -3?) and not blue is a bit more color accurate. Still dialing it in and doing some tests with paused BD material where I switch the input from HDMI1 to HDMI2 and have everything set the same except the color gain and bias as I work on dialing those values.
Has anyone done any dialing for SD content? I'm curious to know if anyone is using a different color temperature setting than neutral for SD.
coma426 is offline
post #25 of 5496 Old 08-22-2007, 02:15 PM
slumpey326's Avatar
gordong11
Posts: 329 Prelim settings
Here is a good setting, but I need to see how it holds up, and what changes it needs. XA2 directly into the XBR4 via HDMI 1.3 cable. Calibrated using LOTR Fellowship, as it's a tough calibration.
CUSTOM
Backlight: 4
Picture: 68
Brightness: 53
Color: 51
Hue: 0
Temp: Neutral
Sharpness: 55
Noise Reduc: Low
Black Corrector: Off
Advanced CE: Medium
Gamma: Low
Clear White: Off
Live Color: Off
WHITE BALANCE:
Red Gain: -3
Green Gain: -5
Blue Gain: 0
Red Bias: -2
Green Bias: -1
Blue Bias: 0
Detail Enhancer: Low
Edge Enhancer: High
Motion Enhancer: Standard
Someone Else give these a whirl, and post your level of happiness. Thanks
__________________
Toshiba HD-XA2
Sony KDL-40XBR4 (Coming Soon, 8/21/2007, appt. confirmed)
Sony KDL-40V2500 1080P LCD
Yamaha YSP-800 Digital Sound Projector
post #26 of 5496 Old 08-23-2007, 11:33 AM
DZL1970's Avatar
Greetings everyone,
I'm glad I found this place.......I have been driving myself nuts for the last 3 weeks trying to calibrate my LCD. I first purchased the KDL-40w3000, and after tweeking for a week decided it had to go back. I originally was using
a 32" bravia S2010, and it looked great I had no complaints. But I wanted something bigger to watch, and of course 1080p 24. So after returing the
W3000 I picked up the KDL-40XBR4, for a price I am still shocked at
I saved a little over 700. So here is my dilema I have been trying to calibrate
the xbr4 for about a week now, using different settings I found on this sight,
and I still can't get the pic to pop like it did on my 32" the only way I get it
close to what I like is through tweeking Vivid.
I am using HDMI cables for both BD 300, and HDDVD XA2. they are running through a Sony DG1000 first and then to the TV (for audio purposes)
I'm okay w/ the pq with both, but they don't look like they did on the 32"
Maybe a little more tweeking. If I have them set to anything but vivid, the
pq looks dull, uninspired, and flat(muted)
The biggest problem I have is the pq that I am getting from Directv HD. I am using the H20, and the H20 700, and both look horrible. Both are directly connected using HDMI, and set to 1080i output. the pq looks horrible, and no where nears the 32" I tweek one channel and the rest look horrible
Could it be the compression Directv uses???
Anyway My apologies for this being long winded, any help or suggestions would be much appreciated!!
The one good thing is my XBR4 has no clouds or stuck pixels so that was a plus
Also the HDMI cables I am using are a mixture of Monoprice, and mid to high end monster.............any suggestions
DZL1970 is offline
post #27 of 5496 Old 08-23-2007, 05:21 PM
speed08's Avatar
My settings
KDL40XBR4
CUSTOM
Backlight: 2
Picture: 80
Brightness: 51
Color: 63
Hue: 0
Temp: Neutral
Sharpness: 50
Noise Red: Off
DRC Mode: Off
Advanced CE: Off
Gamma: Off
Clear White: Off
Live Color: Off
WHITE BALANCE:
Red Gain: -2
Green Gain: -4
Blue Gain: -10
Red Bias: -4
Green Bias: -4
Blue Bias: 1
Edge Enhancer: Off
Power Savings: Off
Motion Enhancer: High
speed08 is offline
post #28 of 5496 Old 08-23-2007, 05:36 PM
Speed 08 what is that setting for dvd? tv? what kind of box if cable...
post #29 of 5496 Old 08-23-2007, 05:46 PM
slumpey326's Avatar
spped8, what do you have cinamotion set to
post #30 of 5496 Old 08-23-2007, 05:47 PM
speed08's Avatar
I'm using the same settings for DVD/Cable box. The cable box I'm using is the Scientific Atlanta Explorer 3250HD.
speed08 is offline
Reply LCD Flat Panel Displays
Sony Bravia Xbr Kdl 52xbr4 52 Inch 1080p Lcd Hdtv , Sony Bravia Xbr Series Kdl 52xbr5 52 Inch 1080p Lcd Hdtv , Lcd Hdtv , Sony Bravia Xbr Kdl 32xbr4 32 Lcd Hdtv
