Need Help Choosing Wall Mount And Cables From Monoprice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-28-2007, 03:07 PM - Thread Starter
jorge007's Avatar
Quoted: 31 Post(s)
I Just bought a Vizio VX37L from Costco. I will be buying 25ft cables and wall mount from Monoprice. Which mount will go with this T.V.
Also I will be going through the wall with 2- HDMI cables which do you recommend... Do I need any extra screws with the wall mount. I purchase.
thanks..
jorge007 is offline
post #2 of 3 Old 08-29-2007, 02:37 PM - Thread Starter
jorge007's Avatar
Quoted: 31 Post(s)
bump
jorge007 is offline
post #3 of 3 Old 08-29-2007, 07:07 PM
Joony's Avatar
The monoprice mounts include all the necessary hardware. All the mounts are pretty much universal, just get one that fits your size.
Monoprice also has some HDMI cables that are rated for inwall installations, not sure if it's necessary though.
Joony is offline
Reply LCD Flat Panel Displays
