Just bought a new Vizio VX32L. No color through component... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 09-01-2007, 06:23 PM - Thread Starter
LightsOut06's Avatar
I have a time warner dvr/digital cable box and I have components going to the tv from the digital box. The picture I'm getting is black and white. I've tried two different sets of cables still no dice. However when I hook the coaxial from the cable out on the box to the tv I get a picture with color. Any ideas? I'm really frustrated because I've called vizio tech support and time warner and they both not been able to help me. There's no HDMI out on my digital box so its either component or bust. Thanks in advance for any help.
LightsOut06 is offline
post #2 of 9 Old 09-01-2007, 06:28 PM
EscapeVelocity's Avatar
Quoted: 571 Post(s)
Liked: 316
Could be your cable box's component out as well as the Vizio's component in.
Epson 8350 / Panasonic AX-200u / Optoma Graywolf 92" / Draper Luma 92"
Samsung 51F8500 / Panasonic P50ST60 / Vizio P502ui-B1E / Sony 50W700B
Sony S790 / Panasonic BDT-220 / Roku 2 XS & Roku 2
Sony NT5 / Samsung F550 / Speakercraft CS3 / Yamaha YAS-105
EscapeVelocity is offline
post #3 of 9 Old 09-01-2007, 06:28 PM
dad1153's Avatar
Quoted: 2110 Post(s)
Liked: 1331
Send a message via Yahoo to dad1153
Havde you tried re-setting/unplugging the cable box? Also, does the box have some sort of menu about the signals it outputs so that it can be adjusted? Hope you get your 32L to work. My sister's 32L (a present from me) is hooked via component to her upscaling DVD player and the picture looks rather good (even if it isn't true HD).
dad1153 is offline
post #4 of 9 Old 09-01-2007, 06:34 PM - Thread Starter
yeah i've tried all that you guys have mentioned. No dice.
post #5 of 9 Old 09-01-2007, 06:44 PM
ChrisDennis's Avatar
Do you have anything else (DVD player or something) that you could plug into the TVs Component inputs (the same ones you are using for the cable box)? If that works, you would then know it's the box and not the TV.
ChrisDennis is offline
post #6 of 9 Old 09-01-2007, 06:51 PM
ElBoricua1's Avatar
I have the same exact TV and haven't had any problems with it. I bet its the box.
ElBoricua1 is offline
post #7 of 9 Old 09-01-2007, 06:56 PM - Thread Starter
only thing i could hook up to the tv is a ps2.
post #8 of 9 Old 09-01-2007, 07:26 PM
HTSS-TR's Avatar
Try this: Swap the green and blue cable on one end only
Instead of:
green -> green
blue -> blue
red -> red
Do this:
blue -> green
green -> blue
red -> red
One of my equiments has the wrong color codes on component in or out ports, the TV has only balck and white video. After I swapped the blue to green I had color again.
HTSS-TR is offline
post #9 of 9 Old 06-16-2012, 08:46 AM
Thalliadruid's Avatar
Thanks! This fix (swapping blue and green on the TV end only) worked for me. Oddly when I bought it the guy at Sam's club said they were getting a lot of returns and told me to make sure not to throw any of the packaging away just in case. I called and asked to speak to him and he confirmed the returns were all for "no color when using the composite inputs". I told him what I did. Maybe that will save some people some frustration!
Thalliadruid is offline
Reply LCD Flat Panel Displays
