Toshiba 32HL67 dvds always in 4:3 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-11-2007, 04:37 PM - Thread Starter
chris98007's Avatar
Hey all,
I posted this in the hl67 board but not getting any info. I just got the 32hl67 and it looks great. My only inssue right now is that anytime i play a dvd it always comes in at 4:3. My dvd, jvc sd connects to the 32 by s-video. I went into the dvd player settings and make sure it was sent 16:9.
however i have to go in and change it to full mode everytime i watch a dvd.
Whats up with this?
chris98007 is offline
post #2 of 6 Old 09-11-2007, 08:41 PM
whitestang06's Avatar
Do you have the "auto aspect" on? I have a recorder/player hooked up through s-video and component, and it does the same (42HL67). I just turned the "auto aspect" off and leave it on FULL. For some reason, it doesn't seem to recognize 16:9 and switch automatically to Full. Works fine through HDMI, but not so much w/ analog.
whitestang06 is offline
post #3 of 6 Old 09-12-2007, 12:39 PM - Thread Starter
chris98007's Avatar
do you think it would change if i ran component instead of s-video? Seems dumb that a tv like this would not recognize a 16:9 signal coming in.
post #4 of 6 Old 09-12-2007, 03:14 PM
ranger8199's Avatar
component is going to give you a better picture anyway.what happens when you press the pic size button on the remote? do you have auto aspect off like stang was asking?
ranger8199 is offline
post #5 of 6 Old 09-12-2007, 03:38 PM
Mine does the same thing through component. It isn't a concern for me, since I just leave it in full mode.
post #6 of 6 Old 09-12-2007, 05:01 PM
ranger8199's Avatar
i know me also, i was just making sure he turned the auto aspect ratio off like you had suggested.
Reply LCD Flat Panel Displays
