Olevia 65 inch 1080p lcd - Page 60 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #1771 of 1786 Old 01-31-2015, 11:02 AM
DNW
DNW's Avatar
I am selling my set:
http://www.ebay.com/itm/Olevia-65-03...-/161581636754?
Worked great, no issues, selling 'as is' good for use or parts. Set is at zip code 10504
DNW is offline
post #1772 of 1786 Old 03-28-2015, 10:29 PM
stevens54's Avatar
Originally Posted by strongarmofthelw View Post
My Woot Olevia 65 inch LCD just finally stopped working. I had to replace the video board 3 times over the years to keep it going but now it is a different issue so I am finally putting it to rest. Last time I was lucky enough to find a place selling the video boards I purchased 2. One I used. and the 2nd one is still new in the box. Anyone interested in purchasing it please email me. I paid approx. $200 for it. Thanks
I may be interested in your video board. How much do you want for it?
stevens54 is offline
post #1773 of 1786 Old 08-14-2015, 03:46 PM
tikicult's Avatar
My set has developed a large dark spot in the center of the screen. Any ideas at what it could be? I'm not in a position to buy a replacement at this time and the spot is very distracting. Thanks!
tikicult is offline
post #1774 of 1786 Old 09-01-2015, 04:18 AM
Liked: 0
Greetings. I hope that someone in this 60 page thread can help me. I was one of the crazies who took the plunge with woot in 2007(?) and bought the 265TFHD. I have been immensely impressed with the set ever since then. But now, I'm having problems. What happened:
  • hooked up via HDMI through Pioneer Elite receiver to Xfinity DVR
  • screen started to freeze every now and then. Thought it was the DVR, but noticed that the sound keep on going. When I turned the TV off and then back on, it would work correctly again.
  • freezing became more common......like three times per hour
  • now, if it has been sitting for a while, it will work......then within fifteen minutes or so, I will get noise on the screen. Once in a while the startup Olevia screen would start up horizontally split and or noisy
I'm sure you guys have experience something similar, as I have read in this thread. Can someone please give me advise as what to look at first? I am handy with electronics, soldering, replacing components, and such.
ID:	918250   Click image for larger version
ID:	918258   Click image for larger version
Motu42 is offline
post #1775 of 1786 Old 09-01-2015, 04:23 AM
Liked: 0
Do you still have the board? Tried to PM you, but seems I'm too NOOB.
Motu42 is offline
post #1776 of 1786 Old 09-01-2015, 05:51 AM
Liked: 0
Just to mention: the Pioneer receiver/Xfinity/DVR setup has been that way for years. Nothing new in the connections or equipment.
Motu42 is offline
post #1777 of 1786 Old 09-02-2015, 06:04 AM
Liked: 0
If anyone has seen this before, and can steer me in he right direction, please? Does this look like a failure of the T-Con control board part number CPWBY3586TPZ? Last night I tried it, and it worked fine for hours. The thing weighs 208 pounds, so pulling it down to look for bulged caps is more than a little poking around. Thanks!
Motu42 is offline
post #1778 of 1786 Old 11-04-2015, 11:58 AM
moonpie23's Avatar
does anyone have a spare HDMI board for this set? we had a thunder storm and now one of the HDMI inputs doesn't work..
let me know...
hit me up at m80@nc.rr.com
thanks
moonpie23 is offline
post #1779 of 1786 Old 11-04-2015, 05:08 PM
hdtv4xmas's Avatar
let me know...
thanks
It would be a whole lot easier and cheaper to buy an HDMI Switch (assuming you still have one working HDMI input)!
OBTW there is no HDMI Board, all the signal inputs go directly to the main board...
hdtv4xmas is offline
post #1780 of 1786 Old 12-23-2015, 02:31 PM
hopper75's Avatar
Liked: 0
Welp, mine kicked the bucket today. Get the banner screen at startup, then nothing. Are these even worth repairing?
hopper75 is offline
post #1781 of 1786 Old 12-23-2015, 09:17 PM
storyid's Avatar
Mine has been doing this for at least 2 years - here's what I do - when it turns on and you get the banner and then nothing, reach around the back and turn off the power at the switch by where you plug it in (don't turn the TV off first). Wait about 5 minutes. Make sure you have all your sources, receiver, etc. turned off (don't be sending any signal to the TV). Flip the switch on, wait about 5 seconds, press the power button on the front...it'll turn on, banner, then you should get "No Signal" and you can then turn on your receiver/sources and life is good. It's a little bit of a hassle, but frankly, no big deal to me - I hope you're as lucky as I am, mine works like this 95% of the time (with the other 5% of the time, it actually turns on and says "No Signal" right from the start)...
Would be really curious to know if this works for you (even if it doesn't). Cheers!
hdtv4xmas and hopper75 like this.
storyid is offline
post #1782 of 1786 Old 12-24-2015, 07:52 AM
hopper75's Avatar
Liked: 0
I'll give that a shot later today, thanks for the tip!
Sent from my XT1055 using Tapatalk
hopper75 is offline
post #1783 of 1786 Old 12-24-2015, 09:05 AM
hdtv4xmas's Avatar
If you haven't done so, you might try to reload the firmware. It might help
post #1784 of 1786 Old 12-24-2015, 10:35 AM
storyid's Avatar
I'd be very interested in both a link to the firmware that works, and instructions on how to do this...without that, I'm just doing the "dance" that I described above with turning off at the power switch on the back, waiting, etc.
storyid is offline
post #1785 of 1786 Old Today, 02:16 AM
andariego's Avatar
Liked: 0
265fhd-t11
Can you help me out with the firmware. I have a Olevia 265fhd-t11 the link you share is not working anymore, thanks
andariego is online now
post #1786 of 1786 Old Today, 02:30 AM
andariego's Avatar
Liked: 0
hdtv4xmas
Here is a link to download the last version of the firmware from the defunct olevia.com website. When installed, the firmware version screen from my set shows (Menu, Setup, Firmware Version)
265TFHD_V63.7.7A17
USE AT YOUR OWN RISK!
hxxp://xxx.megaupload.xxx/?d=JG0T43WS
I believe this will be available for at least 21 days. So, if you want this file, act now. When they're gone, they're gone .
Can you help me out with the firmware, the link is not working anymore. thank you.
Reply LCD Flat Panel Displays
Olevia , Lcd Hdtv , Sharp , Vizio
