Official Sharp Aquos LC-42D64U/46D64U/52D64U Owner's Thread II (No Price Talk) - Page 195 - AVS Forum | Home Theater Discussions And Reviews
post #5821 of 5844 Old 10-05-2013, 06:53 PM
edfick's Avatar
Hello all, sorry, I know this is an old TV, but I had a question if anyone knows the answer.
I am currently using an older receiver which does not have hdmi pass through. What I am trying to do is get my PS3, roku3, cable tv, to pass through the tv to the receiver without having to constantly plug, and unplug devices directly to/from the receiver. Is this possible using the spdif output on the tv, if I plug it directly from the tv to the receiver? So what ever the active HDMI device is on the tv would have it's sound directed to the receiver?
Just trying to figure out if this will work before I start shopping for a new receiver smile.gif
edfick is offline
post #5822 of 5844 Old 10-05-2013, 07:55 PM
BWX
BWX's Avatar
Quoted: 40 Post(s)
Liked: 65
Hook it up and see what happens.
Samsung SMT-H3272 - Nav.7.1.2.1
SA 8300HD (no C) *AZiO ENC311SU41* eSATA- WD black- 1TB - it works!-
-8300HD no more because TWC deliberately made it unusable in my area! :-/ :-(
BWX is offline
post #5823 of 5844 Old 10-05-2013, 08:06 PM
edfick's Avatar
The only spdif cable I have won't reach the tv without moving the receiver, which would be a pain. I was just hoping someone might know first. but I'll try it if not. Or I'll just go ahead and buy a longer cable and try it.
edfick is offline
post #5824 of 5844 Old 10-06-2013, 11:48 AM
johnboy813's Avatar
If you decide to buy a cable try monoprice.com they have good cables at very low prices.
johnboy813 is offline
post #5825 of 5844 Old 10-06-2013, 06:03 PM
BWX
BWX's Avatar
Quoted: 40 Post(s)
Liked: 65
Yeah what you should really do is get a new receiver with 4 or 5 HDMI inputs and 1 output, then hook everything up to receiver, then one output to TV.
I am in a similar situation. I have a PC, PS3, and DVR hooked up to my system via HDMI, but I only have 2 HDMI inputs on my Yamaha receiver so I have to hook my PC directly to TV via HDMI, DVR and PS3 to receiver via HDMI, and use optical cable to aux form PC to receiver for audio. makes it a little bit of a pain to switch to the PC, but it works. I really need to upgrade to a receiver with more HDMI inputs.
Or I guess I could just buy a separate HDMI switcher..
edit- like maybe one of these- but a good quality one that won;t just break in a few months.
http://www.monoprice.com/products/subdepartment.asp?c_id=101&cp_id=10110&cs_id=1011002
BWX is offline
post #5826 of 5844 Old 10-07-2013, 08:59 AM
observing's Avatar
I've done this with a Logitech Z-5500 connected to the SPDIF output of the TV. However, this arrangement does not pass anything but stereo through the SPDIF output. Only the TV tuner output is passed to the SPDIF output as surround sound.
observing is offline
post #5827 of 5844 Old 10-07-2013, 10:05 AM
rdclark's Avatar
Quoted: 348 Post(s)
Liked: 651
That's correct. Much better to connect all the source devices audio via optical direct to the receiver, and video via HDMI to the TV. You'll have to switch both the TV and the receiver separately (unless you have a programmable universal remote), but at least you'll get surround sound.
Remember that HDMI "sees" the audio capability of the input device. Plugged into a stereo TV, HDMI from a player or STB will send stereo. So even if the TV could pass multichannel audio to its optical output, there wouldn't be any (except from the TV's own tuner).
Wide Awake
on the Edge
of the World
rdclark is online now
post #5828 of 5844 Old 10-10-2013, 12:29 AM
edfick's Avatar
Just to give an update. I picked up a cheap spdif cable and tried running it to my receiver. Unfortunately the only audio I can get to 'passthrough' is from the cable box. When I try the ps3 or roku3 I get no sound at all, not even stereo sound. What's strange is the receiver seems to be getting a signal as the led display blinks when it receives a signal.
My tv is from 2007 and I've never updated it's software. I'm wondering if that might help?
Thanks again for the help so far.
edfick is offline
post #5829 of 5844 Old 10-10-2013, 05:00 AM
observing's Avatar
Updating the firmware might help, although I don't remember what effect it had on my LC46D64U. As you continue troubleshooting this problem, keep in mind that you were correct to put passthrough in quotes. The TV has to know what format the audio is in, so it can convert it to stereo before sending it out on SPDIF. If the Roku and PS3 aren't sending the TV a format it understands (e.g. Dolby 5.1 at a specific bit rate), the receiver may be getting garbage. If I recall correctly, the TV will usually tell you if the signal is a total mystery to it, but not when it incorrectly guesses the format.
post #5830 of 5844 Old 10-10-2013, 01:31 PM
jmbissell's Avatar
I also have had my 46" from 2007. From everything I recall, there is no switching of the HDMI input audio out to the optical connection. The only thing output there is the TV sound.
I originally had an old Sony receiver that had a couple of optical inputs but no HDMI. I connected my TiVo and Blu-ray player to the Sony through its optical inputs. I also ran an optical cable from the TV to the receiver. I was lucky that it had 3 optical inputs. I then used a $10 HDMI switch to connect theHDMI video from the TiVo and Blu-ray to the TV. Even this cheap switch would automatically sense the "highest" priority input when power was applied to it and send that video source out to the TV. I had only to turn on the component and switch the receiver to the proper input (TiVo or Blu-ray) to get the sound to the TV as well.
It's a lot easier just having a receiver that supports HDMI but since this TV is too old to support ARC, you still have to run optical audio from the TV to the receiver.
jmbissell is offline
post #5831 of 5844 Old 04-21-2014, 05:31 PM
KevinDGA's Avatar
Hey everyone,
I've got a strange issue after a firmware update to my Sharp Aquos LC-46D64U TV.  Everything before the update worked fine.  The reason I attempted to fix what wasn't broken was that I read the latest (2008) update on firmware took care of some of the weak signal issues this TV is known for.
After the update, my component VCR and component DirectTV cable box work fine.  The TV gets video and audio from them.  No issues there.  The problem is with my digital devices.
The TV will not get video from my JVC DVD player with Composite hookups.  I can hear audio, but Video isn't recognized by the TV.  If I select View Mode on the remote, the TV will say that function is not available.  So, Dot-by-Dot, S.Stretch, etc. aren't present which means that the TV no longer recognized the signals from the DVD player.
My new Sony Blu-Ray player on an HDMI input has the exact same problem.  The TV won't recognize the video signal.
ATTEMPTS TO FIX
Called Sharp and had a very good tech walk me through doing the Init Factory reset (Input Vol. Dwn. Ch. & Vol. Down).  No fix doing that even though I tried variations of having nothing plugged in input-wise during reset, etc.
Tried doing the Software Update again and since it's already on there, the TV just says it's already installed.
I don't know if these TV's support reverts back to old firmware, but I'm thinking short of replacing the board, that would be an option.  The problem is that I can't find any old files online of older pre-2008 firmware versions for this TV.  Also, the TV may not recognize the older version and keep the new one as the default.
Any tip on how to revert the firmware to the factory original firmware?  Any other suggestions for getting the DVD and Blu-Ray video signals to be recognized by the TV?
My only option at this point is taking it to a service tech for the initial investigation and probably (I'm guessing) a board replacement.
Won the TV in a Sharp-sponsored contest, so no receipt that I can claim I purchased it.  Either way, I'll fight Sharp on the fix charges.  Suggestions welcome.
- Kevin
KevinDGA is offline
post #5832 of 5844 Old 04-30-2014, 07:48 AM
johnboy813's Avatar
Originally Posted by KevinDGA View Post
Hey everyone,
ATTEMPTS TO FIX
- Kevin
Kevin,
Given the age of these sets and their know issues you might be better off just 'cutting the cord' so to speak and put the money towards a new set rather than attempting to fix your current set. I know that this is not the answer you were looking for, but sometimes it is just best to 'call it a day' and move on.
post #5833 of 5844 Old 04-30-2014, 11:55 AM
rdclark's Avatar
Quoted: 348 Post(s)
Liked: 651
Originally Posted by johnboy813 View Post
Kevin,
When I think about what I could buy today with the money I spent on my 42d64u... !
Wide Awake
on the Edge
of the World
post #5834 of 5844 Old 04-30-2014, 12:43 PM
BWX
BWX's Avatar
Quoted: 40 Post(s)
Liked: 65
Bought my 52D62U Early 2007 and it has basically been "on" ever since!  Still using it.  Paid a lot back then, but I'm getting a lot out of it.
BWX is offline
post #5835 of 5844 Old 05-04-2014, 03:05 PM
marcingak's Avatar
Hello everyone. I have a Aquos LC42d64u which I bought in 2007 or 2008. Recently, it has started to turn off and on automatically while watching tv through the antenna. It doesn't happen when I am using any of the other inputs, such as when I am playing on my PS3 through HDMI. Only while watching broadcast tv connected to an indoor antenna. It happens maybe once every 2 or 3 days. Any ideas on what might be causing it?
On an (perhaps) unrelated note, I have tried to update the firmware with no luck. I downloaded it from the sharp website, extracted the zip file, and copied it to a USB stick. I connect the USB drive to the tv, open up the update menu, click ok. It checks the drive and asks me if I want to install the update. I click yes. The tv turns off and restarts without installing the update.
marcingak is offline
post #5836 of 5844 Old 05-04-2014, 03:08 PM
BWX
BWX's Avatar
Quoted: 40 Post(s)
Liked: 65
Under "power control", turn both "no signal off" and "no operation off" to disable.
BWX is offline
post #5837 of 5844 Old 05-04-2014, 03:19 PM
marcingak's Avatar
Thanks for the reply but I checked the settings and they were already disabled.
post #5838 of 5844 Old 05-07-2014, 08:21 PM
Xboxonetv's Avatar
Hey guys, I know it's an old set but I hooked my Xbox one to it. In configuring the Xbox I've learned that the picture of the Xbox is much greater than the tv. I got the tv as a hand me down from my brother in law, and no remote. I can't find it in menu structure: is there a way to adjust aspect ratio or picture size? Thank you for assistance. I googled and googled and couldn't find it
Xboxonetv is offline
post #5839 of 5844 Old 05-12-2014, 01:31 AM
KevinDGA's Avatar
Well, it's been an uphill journey with my TV getting fixed, but we're almost there as of this writing.
After dealing with Sharp Customer Service, I took it to a qualified repair shop for them to tell me what I already knew was wrong with it.  They reported their findings to Sharp and Sharp responded (an anonymous response from a Customer Service rep who had not read the case notes, obviously) that the TV was out of warranty - done deal.  Sharp wouldn't pay to fix it.
Since the problem stemmed from their Firmware update entirely, I wasn't happy with that generic response. LONG story short and after 8 phone calls back and forth with Customer Service over the period of a full week, I got the 'final' answer that Sharp would pay for the new main board, but not for labor.  Well, that would mean I'd still be paying over $150 bucks to get the TV fixed.  Still a lousy response considering I did nothing to intentionally ruin the TV.
Still not content with their answer, I wrote the President of Sharp USA, explained the entire case in full detail and got a response very quickly from Customer Service.  Sharp will now pay for everything to get the TV fixed.
I'm posting this because Sharp eventually did come around when all the facts from the Customer Service case were taken into consideration.  This is a good indicator of Sharp being a good company that stands behind their products despite an absolutely awful Customer Service experience to start with (as far as I know, they are working on making sure this doesn't happen for others).
The squeaky wheel gets the grease and now I'm getting my TV fixed.  I'm very happy with Sharp's true final answer.
kerstuff likes this.
KevinDGA is offline
post #5840 of 5844 Old 10-01-2014, 07:37 AM
rocky01's Avatar
Glad it worked out for you KevinDGA. Note to self: Don't go updating firmwares
rocky01 is offline
post #5841 of 5844 Old 12-29-2014, 09:24 PM
craven50h's Avatar
Liked: 0
Smile Sharp Aquos LC-32D74U software upgrade doesn't update version
Originally Posted by c56250 View Post
Does anyone know why my Sharp TV wouldn't accept the new firmware? I used my USB drive, TV goes dark, and comes back. However, it does not update the firmware version.
I formatted my usb drive as "FAT" format. I couldn't find an option for FAT16 as all I see is either FAT or FAT32.
Any thoughts?
Sorry to resurrect an old thread but this was one of the only posts I found regarding the exact issue I was having and since I figured it out on my tv I thought I would leave an answer.
I was trying to update an Sharp Aquos LC-32D74U to firmware S0909081 and got the exact same issue described above. I had originally used an 8 gig thumbdrive formatted with FAT32 without giving it much thought. When I tried to perform the software update the tv would turn off then back on but it didnt't display an error or success screen, it just acted like nothing happened and the software version wasn't updated. So I dug out an older 1 gig thumbdrive (since FAT16 only supports up to 2 gigs) and had to use a 3rd part utility to format it with FAT16 since win7/8 don't support it anymore.
Since the previous user indicated he had formatted his drive with FAT instead of FAT32 maybe it was the smaller thumb drive that actually made the difference, either that or his pc didn't actually format it as FAT16, my understanding is FAT and FAT16 refer to the same thing.
I was going to provide helpful links to the guides I followed and the utility I used but the forum policies won't allow me to include urls.
craven50h is offline
post #5842 of 5844 Old 12-30-2014, 07:18 AM
johnboy813's Avatar
If I remember correctly, the Sharp is very picky about how the thumb drive is formatted. You may need to try and find someone that still has a Windows XP or possibly Vista machine that can format the drive as FAT32 for you. Once the drive is formatted then you can load the update on it and your Sharp should accept it. Good Luck.
post #5843 of 5844 Old 12-30-2014, 12:58 PM
classicrecording's Avatar
Quoted: 46 Post(s)
Liked: 94
Where do you get the update?
classicrecording is offline
post #5844 of 5844 Old 04-17-2016, 09:01 AM
reality intrudes's Avatar
fixed "no sound" on my LC-52D62U
I searched this issue several ways to see if there was a fix for loss of sound on my Sharp LC-52D62U, but I found nothing.
Every so many on-off cycles, I will get no sound coming from my LC-52D62U via DirecTV set-top HD-DVR HDMI output. I tried various hard reboots of the box and tv, and was never sure how the sound would get restored since it didn't happen all that often. VERY frustrating.
Over the past year the loss of sound now might happen after just several turning the tv on & off. My consistent remedy has been:
1) Use original remote to change input to something other than the set-top.
2) Turn off the tv and leave it off until I hear a "thunk" sound.
3) Turn the tv back on and switch back to the set-top box input. Sound!
FYI- I have never done a firmware update.
It is a PIA but I am just trying to keep an otherwise decent set working until I get a HDR + DolbyVision + etc replacement [most likely an LG E6 -or- VIZIO P (once they ship with updated firmware)]. I just want to give back to AVS Forum members who help me with their info, tips and tricks.
krh
Sorry, I put this in the wrong owner's thread that came when I did my AVS search. I will leave it in case this very similar model may be causing the same loss of sound issue.
Moderators: Feel free to delete this is you do not feel it is worth keeping...
Last edited by reality intrudes; 04-17-2016 at 09:09 AM. Reason: wrong Sharp owner's thread
reality intrudes is offline
Reply LCD Flat Panel Displays
Sharp Aquos Lc42d64u 42 Inch Lcd Hdtv , Shrlc52d64u Lcd Hdtv 52 1920x1080 Resolution Black
