Best 40 inch HDTV that will fit into a 40 inch space - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 11-11-2007, 04:35 PM - Thread Starter
jbrandin's Avatar
I am looking for my first HDTV - unfortunately the cabinetry in my family room will only allow a TV with the width of 40 inches and I don't really feel like replacing the cabinetry. I am not really on a budget and would like to buy a tV with the best picture and color that I can with the best technology in it. Being able to connect to a Mac for content is a bonus, but not a must have. I will probably connect both over the air and cable and may put in a Blu ray DVD (but really don't watch a lot of DVDs right now anyway). I started out looking for plasma tvs, but can't really find anything that will fit in the space.
I am considering the Sony 40 inch W3000, but am willing to consider anything else.
Also, sorry for the newbie question, but with the move to HD, will I have to replace my Denon AVR 2807 receiver?
Thanks for your help!
jbrandin is offline
post #2 of 11 Old 11-12-2007, 08:40 PM
mikemikeb's Avatar
The Sony V3000 is cheaper and about the same TV, and the Samsung 4061 is about as good.
As for replacing the Denon, is it 5.1 audio-capable already? How many coaxial and optical audio inputs does it have? Does it have a dedicated 5.1 analog audio input? A dedicated 7.1 analog audio input?
mikemikeb is offline
post #3 of 11 Old 11-12-2007, 11:22 PM
wuzup101's Avatar
Samsung 4065F on amazon now for $1400 with free shipping... pretty damn good PQ. The W3000, V3000, and 4061F would also be good choices. Really in that 40" size point you have a few really good sets to choose from.
Originally Posted by discopaul
Electrons aren't into hype, they stick with the laws of physics.
Samsung 4065F, Xbox360, 40gb PS3, Tosh HD-A2
wuzup101 is offline
post #4 of 11 Old 11-13-2007, 12:12 AM
DFGum's Avatar
Tip: 40" tv's are not 40inches wide :P
DFGum is offline
post #5 of 11 Old 11-13-2007, 04:24 AM
Nmlobo's Avatar
40" is the diagonal measurement of the display. A 40" TV, w/o side speakers and including the frame is pretty close. My 40" set measures 39 3/8 x 29 x 13 (w/stand). You do need to leave some space around the set for cooling/heat dissipation. The recommended area around my set is 6" on the sides and 8" on the top.
Nmlobo is offline
post #6 of 11 Old 11-13-2007, 05:22 AM
margate21's Avatar
i went thru this exact problem. the only 40inch tv that fit my 39.5 inch width entertainment center was the sony kdl 2500v. i believe the newer models are slightly wider.
margate21 is offline
post #7 of 11 Old 11-13-2007, 06:07 AM
gljvd's Avatar
there is the toshiba 40 inch that fits in a 37inch space. Forgot the model number but there is a big thread about it here
gljvd is offline
post #8 of 11 Old 11-13-2007, 06:38 AM
darkninja67's Avatar
Toshiba 40RF350 will do the job
darkninja67 is offline
post #9 of 11 Old 11-13-2007, 06:45 AM
Hooters23's Avatar
I am in a similar situation, except my cabinet is 41" wide. I have been checking out the BF ads and came across the HP LC4276N from BB. It is a 42" television and the specs indicate that it is 40" wide. This is one that I am seriously considering.
Hooters23 is offline
post #10 of 11 Old 11-13-2007, 06:57 AM
mimason's Avatar
Mits also has a 40" that is 37" wide. I don't know how this compares to the Tosh though. I am just starting my short list.
mimason is offline
post #11 of 11 Old 11-13-2007, 07:26 AM
motoman's Avatar
Quoted: 14 Post(s)
+1
I bought one last week.
Jim
motoman is offline
Reply LCD Flat Panel Displays
